Mouse Removal Technique's - Help!
Discussion in 'The Hokey Ass Message Board' started by AutoArt66, Apr 26, 2011.
  1. daddylama
    daddylama
    i use mint.
    some mint oil on some cotton balls here and there, and the mice are gone and stay gone... plus it doesn't smell like moth balls. it's had the added benefit of helping to keep mildew at bay, as far as i can tell as well.
  2. MOTRUBL
    MOTRUBL
    5-gallon bucket filled halfway full of water.
    somesort of board to act as a "plank".
    cover the top of the water with birdseed or sunflower seeds.
    the mice will think that it's full and that they can jump out of the bucket, but once inside they drown. just leave the door open and maybe have the "plank" go from the door to the bucket. This works GREAT for getting rid of ground squirals and chipmunks too. just besure to stirr the water around a bit before sticking your hand in to dig the dead one's out. Keep count of how many you get.
    long term... Irish Spring soap.
    best of luck!!
  3. yardgoat
    yardgoat
    Might as well spray for other insects,some eat mouse **** and might bring home stuff you wont see.MOTH BALL IT,DRYER SHEET IT,INSECT SPRAY IT,WAIT ONE YR TO WORK ON IT.Maybe a month,good luck.If all else fails feed them so they get big enough to put a rope around them then pull em out..............YG
  4. Nemosgarage
    Nemosgarage
    Mouse magic use it all the time,keeps mice out and smells minty
  5. Bug bomb also works. those that don't leave croak.
  6. rainhater1
    rainhater1
    from az
    I disagree, I have used the electronic units since the 80's have them in all my garage's motor homes and the house,s. Have never had any problems since. The professional peope don't want you to know they work or they would be out of business. older and wiser
  7. DRYER SHEETS!:D
    Am I the only one to fall off my chair laughing?:confused:
    Doc.
  8. Bruce Lancaster
    Bruce Lancaster
    Chemicals, noise, traps...only a CAT offers long term deterrence, automatic reset, sustained attack, and adjustable intensity. The adjustment is handled by cutting rations if cat gets lazy...
    I hope all upholstery in there is ****, because I think there is no alternative to ripping out anything soft and washing the hell out of the metal.
  9. 41fordor
    41fordor
    Mice don't like people. If the car is being loaded on a trailer and towed down the highway they will bail (the living ones anyway). Its the leavings that are hard to get rid off. Before taking it inside your shop, stop by the big box home improvement store and get a couple gallons of muriatic acid and mix it in a 5 gallons bucket with some water. Use that to decontaminate the interior surfaces. Just wear plenty of eye and lung protection and use low pressure water to rinse to avoid splashback.
    Thats an old trick I learned from an Emily Griffith Opportunity School instructor in the 1970s when they restored old aircraft that have been sitting. I was just a kid and I always wondered later that it didn't damage the aluminum but it must have etched it nicely for zinc primer. I've since used that trick to clean scale out of aluminum radiators also with a baking soda rinse afterward.
  10. burl
    burl
    from Minnesota
    I agree with the traps.I have used the dryer sheets in my boat when its put away for the winter and all i seam to find in the spring is all kinds of mouse **** on them and chewed up wiring insulation from their winter partys.Im not convinced the dry sheet do anything but take care of the fish smell left over from the summer before.
  11. heywacha
    heywacha
    from Orange, CA
    Call this guy...
  12. heywacha
    heywacha
    from Orange, CA
  13. He looks cross.............X
    Doc.
  14. Google Hantavirus , the poop from those little critters can be nasty.
  15. nummie
    nummie
    bug bomb the ever-loving **** out of it...2 or 3 of them in the cabin, one under hood, and one in the trunk. works for me, its instant, and relatively cheap. just dont stay inside the car.
  16. Timbo from Mempho
    Timbo from Mempho
    from Memphis
    Call Billy!!!
  17. willymakeit
    willymakeit
    Walmart carries them
  18. bgbdlinc
    bgbdlinc
    ....if you go this route, remember when mixing this corrosive stuff to add the bad stuff last (i.e. add the acid to the water). Doing it the other way around makes the water boil and splatter instantly and you will look like the 'Elephant Man'....beware
  19. What ever happened to the humor in the HAMB, I sooooooooo miss the old HAMB.
    Doc.
  20. R Frederick
    R Frederick
    from illinois
    I was going to use Moth balls, but I couldn't get their legs apart. I have had good luck with an old overflow tank with some antifreeze in it. They go in through the open cap, and either can't get back out, or are poisoned anyway. I accidently left one in the garage and discovered five mice in it, dead and embalmed.
  21. Francisco Plumbero
    Francisco Plumbero
    from il.
    Maybe you had female moths.:D
  22. Standard gas&oil
    Standard gas&oil
    from USA #1
    I own a pest control company and if these electronic plug in devices worked I would use them. Think about it, I would not have to use expensive rodent baits and spend time using traps. I find people all the time using dryer sheets and what we find is that it makes good nesting material for the rodents. Last fall one of my customers swore by dryer sheets in a cl***ic 1966 Ferrarri untill rats and mice chewed up the seats,door panels,carpet and wiring. Not a chance I would take in my shop, I always use a few snap traps set in the shop just in case. Mothballs are used in our industry to drive out snakes in certain areas not to be used as a rodent repellent. Good luck.
  23. Ramblux
    Ramblux
    Lots of great info here. I had the same issue a couple of months ago with a truck I brought home. The mice were gone by the time the truck got here, but the engine bay was full of their leftovers.
    To tell you the truth, I didn't want to deal with it (and had read about the health risks), so I just paid an automotive detailer to come over with his pressure washer and take care of it. He did a much better job than I could/would have, and the engine looked brand new when he was done. Best $100 I ever spent.
  24. RayJarvis
    RayJarvis
    hi, make sure you use a good breathing mask when cleaning out that car even after the mice are gone. hantavirus is a nasty side effect of mouse droppings and mouse dust, and can get pretty serious in a hurry, even fatal. Ray
  25. Standard gas&oil
    Standard gas&oil
    from USA #1
    X2 well said.
  26. How about a couple (like 5) road flares?
    Light em up someplace inside where they dont burn the car down & see what happens.
    Close all doors & windows....you tube it.
    :eek:
  27. Engine man
    Engine man
    from Wisconsin
    We've had the "professionals" in to get rid of mice and they build nests in the nice plastic bait stations. I picked up some "Just One Bite" poison. Put it out one Friday night. Came in Monday and there were dead mice all over the floor. They were dried out.
    We had tried D-Con and the mice loved it. They got up on the shelf and chewed through the box to eat it all.
  28. carcrazyjohn
    carcrazyjohn
    from trevose pa
    smoke them out .No animals like smoke /Its either that or lure them away with cheese and then shoot the pests.
  29. Some great stuff Hambers! Makes me think the old Caddy might have a chance. I like the 3 sticks of dynamite idea.... should I put the convertible top down or leave it up?
  30. rainhater1
    rainhater1
    from az
    I know what works and I understand that you have a company that you have to support, but I will stay with the electronic units. :confused:
