moving bumpers closer?
Discussion in 'The Hokey Ass Message Board' started by plmczy, Jun 3, 2004.
  1. plmczy
    plmczy
    Anybody have any tech on moving bumpers closer to the body? I'd like to eliminate the rear gravel pan and get the bumper closer the same with the front also. Do you need to shorten them any when you do this? TIA, later plmczy
  2. MercMan1951
    MercMan1951
    Moving the bumper in is usually as easy as re-drilling and relocating the mounting points inward. Most likely, you'll find that if you move the bumper closer in to the body that it will appear to stick out on the sides of the quarters too much. It depends on the model year of the car, but I'd suspect for aestetic purposes that you may want to section your bumper to get the tight fit (I****ume) you're looking for. Hope this helps.
  3. stealthcruiser
    stealthcruiser
    you better buy that grille before you go shortening any bumper!
    just messin' with ya',but don't wait too long.
    later
  4. plmczy
    plmczy
    Mercman, ya thats what I was after, thanks. later plmczy
