moving leaf to inside frame ?
Discussion in 'The Hokey Ass Message Board' started by bodyman, Sep 19, 2011.
  1. bodyman
    bodyman
    from east tx
    im moving the leaf springs on my 50 chevy truck to the inside of the frame . im trying to get some ideals on how to do the rear shackles ? anyone done this & have pics ? thanks
  2. choptop37
    choptop37
    swap the fronts right to left after boxing the frame..rears you should plate and box the frame so you have the flat surface to mount the rear brackets to.. just did a simmilar thing on a 54, but no pix.
  3. bodyman
    bodyman
    from east tx
    what to use for the rear brackets ?
  4. bodyman
    bodyman
    from east tx
  5. Mr48chev
    I take it you have a 3/4 ton frame as the springs are under the frames on 1/2 tons.
    A photo of what you have might help but if you have the 3/4 ton setup you can probably put a plate on the inside of the frame and swap the front brackets side to side and build a crossmember to hold the rear brackets/shackles.
  6. bodyman
    bodyman
    from east tx
    i have a 1/2 ton . im wanting to get it low ?dont have any pics right now ?
  7. hrm2k
    hrm2k
    Ok ! We did that before.
    Here are 3 pictures of our 51 Fleetline way back when. I know it's not a truck but the same methods could be applied.
    We made new 2" X 3" thickwall tubing rails. we built new front mounts which you can see if you look through the floor boards. If you look close enough at the front mounts, you can see that we drilled a lot of mounting holes. This would allow us to adjust the height of the front mount position to allow us to lower and raise the car in small amounts
    We made a new cross member in the back and made shackle mounts inside the frame.
    I'll look around and see if there are other pictures of the front mounts.
    anyone else ? :cool:
  8. hrm2k
    hrm2k
    Couldn't add to the first post so here are some more. There are several more where you can see the mounts. If this doesn't get you what you want, drop me a PM and I will send them to you separately
  9. hrm2k
    hrm2k
    SHIT !! I forgot the rear spring perch mount.....sorry :eek:
  10. bodyman
    bodyman
    from east tx
    thanks hmr2k thats what im looking for . anybody else ? thanks
  11. bodyman
    bodyman
    from east tx
    anybody else have pics ?
