MPG issue
Discussion in 'The Hokey Ass Message Board' started by yblock292, Oct 6, 2013.
  1. yblock292
    yblock292
    My newly build 51 shoebox kustom, rebuilt .030 over 302, 1984 lincoln AOD, 3.0 rebuilt mavrick reareand, been running great but gas mileage really ****s! Seems to hesitate between gears, 2nd to 3rd, 3rd to OD, have had it to 2 different shops to set the TV cable, each came up with a different setting.Ran the numbers on her today, 12 miles to the gallon! And that is mostly highway speeds.Any ideas?
  2. Joe H
    Joe H
    To much gear with overdrive. Try driving the same route without overdrive and see what it gets.
    Joe
  3. bobkatrods
    bobkatrods
    from aledo tx
    My opinion is that with a 3.00 gear and O D trans, that the engine is running well below a efficient rpm, kinda dogging it,,***uming the Od is maybe .25-.26 that would give you a final ratio in the low 2's .
  4. mustang6147
    mustang6147
    from Kent, Ohio
    I always ran 3.08 for rear end, and normally got 18ish.
    Whats your RPM at 70mph?
    Hesitation between gears is a problem, does it shift hard when it does or is it sloppy. If its sloppy, the cable is off, if its hard, its an electronic malfunction with the lock up converter...
    I have seen an irregular diode pattern out of the alternator play havoc with electronics like the converter
  5. yblock292
    yblock292
    good point, its sloppy, non electronic OD, not sure how i should adjust the stop on the tv cable, move it futher out from the carb or closer in
  6. 1930 A
    1930 A
    AOD needs no electrics for lockup or overdrive. In overdrive the ratio is .67 to 1. Third gear is direct drive 1 to 1 ratio with no torque convertor slip. With 3.00 gears your probably only turning about 1500 rpm in overdrive. I agree with Joe H in that you'd probably get better mileage in 3rd gear.
  7. dirty old man
    dirty old man
    With all the screwball overgearing you have, I also dobt the accuracy of the odometer.
  8. FrozenMerc
    FrozenMerc
    #1: Get the TV valve pressure set right. It is not that hard, plenty of step-by-step videos on YouTube and lots of info here. If it is not right, you will burn the trans up pretty quick. And by pretty quick, I mean within 100 miles.
    #2: Your rear gear ratio is too low, You are probably running below your torque convertor's stall or lockup speed in OD. This causes the transmission to turn into a very inefficient hydraulic pump that creates way too much heat causing you to burn up gas and trans fluid.
    Fix those two things and report back to us.
  9. luckystiff
    luckystiff
    i've actually been crunching numbers on the subject today doing theory for my 62 unibody set up.
    while 3.00 may not be optimal Ford put 5.0 and 4.6/ aod(e) in a bunch of stuff and it was effiecient enough. as said around town don't bother with od and you'll probably yeild better mileage.
    my digging is based on the only jag rear i have access to is the matching one to the front suspension in my truck from the same donor and it's 2.88.
    it's got me tossing either using a mark viii rear which is 3.08. or forgoing irs and running a 3.55 or 3.73 explorer rear.
    all this would be behind a carb'd 351 from a mid 80s f150 most likely....
  10. greybeard360
    greybeard360
    The majority of later model Fords use a 3.27 gear set. I would verify the speedo and odo are accurate first thing. Download the Ulyses speedo app for your phone, it is real accurate.
  11. 1955IHC
    1955IHC
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    This video is from a member of the 52-59 Ford social Group many of us have done 302/AOD swaps in our Fords,check it out:http://www.youtube.com/watch?v=jZwsQViZilQ Also one of the best AOD sites is here: www.clickclickracing.Common rear gear ratio for Mustang & T-Bird AOD cars was 3.55's shift point for overdrive was between 45-47 MPH in my '91 T-Bird,bottom line you need more gear.
  13. Cerberus
    Cerberus
    My "Special Construction" roadster has a '84 Crown Vic 5.0/ AOD with a 1978 Mustg II 8" rear end with ring & pinion ratio 3.00. Overdrive is useless driving less than 65 mph because the ratio is lugging the engine. Several vendors on eBay sell MOTIVE Gear Performance Differential Ring & Pinion for various Ford applications. Some ratios are:3.08, 3.25, 3.40, 3.55, 3.80. I plan to install the 3.55 eventually. Price is about $199.60, plus shipping.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    My '54 with a 302/AOD at 70 MPH in OD is about 2450 RPM with it's stock 4.10 rear which was original behind the 223 and 3 speed w/OD.
  15. Dan Timberlake
    Dan Timberlake
    cam? ignition? carburetion?
    "seems to hesitate betwen gears" sounds like a separate issue.
  16. abodyjoe
    abodyjoe
    Is the engine completely stock other then the overbore? You running efi or a carb? If carb what carb? Where's the timing set? Stock converter?
    The shifting sounds screwy to me. Almost sounds like more the a adjustment issue.
    My 87 mustang has a 2:73 rear gear with an AOD trans. Goes into od around 45-50 mph. I leave it on od position all the time and let it shift when it wants. The car gets around 19mpg
  17. yblock292
    yblock292
    great info guys, gonna take it to a buddy of mine who has a ****** shop, best in town, let him check it out sounds like we are leaning to changing rear gears. It is a carburetored motor, edelbrock 600. Will drive today, not in OD and see how she does.
    Thanks, Jack
  18. The components do not match
    The biggest culprits apparent right now are the OD Trans and 3.0 gears.
    There may be more like. cam, converter rpm ranges etc.
    With a 3.0 rear gear your engine and trans thinks it sees a much heavier weight to move Especially in 1 2 3rd gear. You've taken the mechanical advantage away by the numberically lower gears. Its working harder & This lets you see mpg that reflect pulling that weight. Then in OD you compound the problem by reducing the RPM below optimal range.
    Now the speedo off and mpg calculation needs some thought.
  19. brokenspoke
    brokenspoke
    ^^^^^what he said^^^^^^
  20. hotroddon
    hotroddon
    Interesting - according to Ford literature for 1987, stick shift cars came standard with 2.73 and had an optional 3.08, while all automatics had a 3.27 gear.
    Engine 5.0L (302cid) OHC V8 (iron block- 2 Valve Heads sequential fuel injection
    Displacement 302 cid
    Horsepower 225 @ 4000
    Torque 300 @ 3000
    Compression 9.5.1 to 1
    Fuel Premium (91+ octane)
    Exhaust aluminumized steel. LX models featured chrome tips
    Transmission 5 speed T-5 or 4 speed automatice AOD
    Final drive ratio 2.76:1 , 3.08:1 (Optional), 3.27:1 (automatic)
  21. abodyjoe
    abodyjoe
    yup.. they didn't come with much gear. maybe to boost the mpg numbers or something. i also had a 90 years ago that also had a 3.73 gear and that one used to get over 25 mpg. not sure why this 87 doesn't get that much. rumor is that the 87 had a hotter cam, but the 90 has m*** air instead of the speed density like the 87. not sure if either of those are the difference..
    i'll tell ya though. 2.73 gear and the aod is awesome in the highway. 80mph at under 2500 rpm.. :)
  22. The 351 should have enough torque to pull that (if you build the motor that way) as a OT Jag XJS I had with a LT1/4L60E did fine if not being a hard accelerating car. I knocked down low to mid 20s mpg.
    That is the downside to the Jag rear; almost everything they built in the 80s had 2.88 gears. And because Jag used a weird ring gear and carrier, you can't swap only gears. But you can install Dana 44 gears and carriers into them by mixing and matching bearings.
  23. luckystiff
    luckystiff
    yeah i'm seriously considering a explorer rear. i'd love to do the full jag set up but with the truck being built to be my daily and it may do some light towing/hauling i just don't think the 2.88s would be optimal.
    so with that theory i started looking around today. i did find a late 70s v12 jag unit which could fairly commonly be 3.53 an hour or so away but no response from the seller on ratio. seller wants $225.
    then theres a 96 t bird irs that should have 3.08 in it an hour or so away for $100.
    then theres the other option of keeping it solid axle and with that theory i started calling local yards looking for an explorer disc 8.8. most were asking $300+. the pullapart in charlotte has 15-20 and they are $135 but its an hour away and saturdays are my only possible day to even attempt that. Then i found a localish yard that has one from a '98 donor with 90k miles with 3.55 gears for $200. it's getting tempting to just use the explorer and us the focus i was going to put in the irs elsewhere.....
  24. Thriftmaster
    Thriftmaster
    from Canada
    I was in the pick a part checking out an 88 lincoln town car 302, Aod with 3.08 gears in the rear end. Next to it was a 91 Thundebird coupe 302, Aod and it also had 3.08 gears in the rear. The 8 teeth different between a 3.00 and a 3.08 is vertually nothing. So if they both come stock from Ford with those of ratios I personally don't see that 3.00's would make that big of a difference with the Aod ******.
    But in all fairness I have very little experience with Ford Aod trannies. However I have run 3.00 with a 700R4 / 350 SBC setup with no issues.
  25. Before I got crazy with the gears, I'd make sure the odometer is right, (free and easy, check with GPS or mile markers) if that is good, take it for a ride with OD locked out, just for a comparison, (bet it won't make 2 MPG difference) then start looking at your engine tune, timing, vacuum leaks, etc. That is all pretty cheap stuff so it should be done first. When you are sure the engine is right, then you can start fooling with gears.
    A while back I had a 460 in a Studebaker pick-up, got 12 MPG on the highway with 2.75 gears, thought I had too much gear. I went to 3.50s still got 12 MPG, gave up and enjoyed my 12 MPGs
  26. mgtstumpy
    mgtstumpy
    I work on the premise that optimum RPM range at 60mph is around 2K rpm give or take (1.8K - 2.1k rpm) with the correct ratio rear end to suit your tyres. Keeps engine in power band so it is not labouring unnecessarily.
    My 35 with 305, 700R, 235:65:15 and 3.54:1 turns 2.2Krpm at 60mph. Gets around 28mpg on the highway
  27. RPM
    RPM
    I'd be for checking the timing and making sure the vacuum advance is working like it should.
  28. Gary Addcox
    Gary Addcox
    With that 3.0 rearend, your car is geared WAY too high for that AOD. My steel '32 Highboy runs a Vortek 350, 700R4 trans, Ford 8"posi with 3.73 gears and 31" Hoosiers 13" wide. At 70-72 mph, I get an honest 24 mpg around 2100 rpms. Although I seldom get into it, off the line is very strong (and just for fun). MAKE SURE your TV cable is properly adjusted or the trans will say "Bye, bye", soon.
  29. Window Licker
    Window Licker
    Also don't forget tire diameter plays into the equation. If stock vehicles came with an AOD / 3.00 gear and a 25 inch tall tire, and you are running the same setup with a 29 inch tall tire that may be your issue.
    25/29 * 3.00 = 2.59
    So running a 29 inch tire with 3.00 gears is like running a 25 inch tire with 2.59 gears. You need to be concerned with the final drive ratio not just the gear ratio.
    PISTON JAMMERS C.C.
  30. oldsman41
    oldsman41
    check your oil and see if your dumping gas. something is really wrong here. check all the fittings on your gas lines. fords were never real great on fuel but that is even low for a ford. the worse I ever did was my 428 motor and I got about 16 on the highway.
