MR SHORTY Returns to Washington after 18 years...
Discussion in 'The Hokey Ass Message Board' started by 53 COE, Sep 3, 2012.
  1. 53 COE
    53 COE
    from PNW
    Rec'd the TANKS gas tank and fit it up - going to fit like a glove in the '73 frame. The angle of the rear crossmember even matches the taper of the tank. Impressed with TANKS quality - that plastic (polyethelene) is really thick - 1/4" thick walls - surprised me - I expected half of that....
    :cool:
  2. Blake84
    Blake84
    this truck is beyond bad***!!!....congrats on getting her back home. must have been a great feeling!
  3. ph8ed4life
    ph8ed4life
    from AZ
    This is awesome! Good luck on the resurrection!
  4. bfreehill
    bfreehill
    from boulder,co
    Mr Shorty is Awesome!
    in the middle of building a 48 dodge coe and thinking of going super short.
    what is the wheelbase on Mr Shorty?
  5. 53 COE
    53 COE
    from PNW
    91" WB
    12-1/2" driveline
    Stands 7' 5" tall
    It was the 1940 Chev COE in the Sept 1989 Street Rodder magazine that inspired my build. Often you can find an issue on eBay:
    http://www.ebay.com/sch/i.html?_odk...kw=street+rodder+1989+magazine+sept*&_sacat=0
  6. bfreehill
    bfreehill
    from boulder,co
    Thanks, you have inspired big changes for my truck.
  7. 53 COE
    53 COE
    from PNW
    Thanks guys - Got the tank all in ... Put 8 gallons of Ethyl in her - and warmed her up for the first time out of the new tank - even backed her out of the garage.
    Exhaust pipes re-routed to clear...
    Up tight and out of sight...
  8. 53 COE
    53 COE
    from PNW
    Little by little,,,, ;)
    First trip around the block today on a cold morning - you can see her breath. :cool:<!--graemlin::burnout:-->
    A little thump, thump, thumpity on the flat spotted tires that sat for a couple decades. Tires and wheels next!
  9. 53 COE
    53 COE
    from PNW
    Took out the old dry-rotted bed wood and found a nice southern California black widow specimen on one of the boards. Had seen a few small black spiders and ****ed them and their tough webs up with the shop vac. But this was the first larger one actually sporting the hour-gl*** marking. He's been in a jar for a week now and is still alive.
    So just in case there were any left, parked her out last night since the temps dropped to the '20's. They are pretty sluggish anyways in the cool Seattle area they have found themselves transported to.
    Here's how the largest WalMart $20 car cover fits her:
  10. Truckeez
    Truckeez
    LOL---"the COE craze is over"
    http://www.jalopyjournal.com/forum/showthread.php?t=219018&page=168
    there MAY be a girlie pic thread here that has a perpetual life like the COE thread:D
  11. 53 COE
    53 COE
    from PNW
    Pics from the early '90's build....
    COE-3 window cab.
    Donor 1/2 ton 5-window cab & Son who is now a graduate student at Emory.
    COE and 1/2 ton comparison.
  12. 53 COE
    53 COE
    from PNW
    5-Window conversion pics...
  13. 53 COE
    53 COE
    from PNW
    5-Window conversion complete and patch panel pics...
  14. belair
    belair
    That's MR. Shorty to you. Great Marty Robbins song.
  15. 53 COE
    53 COE
    from PNW
    Frame pics using '73 heavy half rear frame and front crossmember...
  16. 53 COE
    53 COE
    from PNW
    Paint work - engine/****** $50 donor car on the hook - first time out of the garage ever right after paint.... I had to cut the garage door 11" taller to get her out...
  17. 53 COE
    53 COE
    from PNW
    Liking this thumbnail business - just figured it out. Pics from shows in 1992, **X Rootbeer Issaquah and Puyallup GoodGuys. Ran into the '41 Ford I built in the early '80's, nicest truck I ever built. "Should have kept it".
    My 3 Sons and another donor truck, bought off a guy at work who could not get the rebuild running. Adjusted valves, got it going, used the new parts that came with it, headliner etc.
  18. Tnomoldw
    Tnomoldw
    So is the Street Side Auto great ? or leaky pumps ?
  19. 53 COE
    53 COE
    from PNW
    Yes they had good prices on the Eldelbrock carb etc. I bought a Carter fuel pump at NAPA in the end, works great.
  20. 53 COE
    53 COE
    from PNW
    15 mins of fame back in the day.... This was before the COE craze really took off....
  21. 53 COE
    53 COE
    from PNW
    Bought a gallon of Ospho for about 25 clams at the local Ace hardware. Going to use it to treat the sheet metal after I remove as much rust as possible first (wire wheel, strip disc etc). Thread on Ospho here.
    I did just use it on the rusty rear brake drums just for a test. Getting 5 spoke wheels so the drums will show. Quick once over with a wire wheel on a fast air-drill-motor to get in between the cooling fins.
    Ospho treated them overnight - a little goes a long way, then sprayed 4 or 5 coats of mat black 500 degree engine paint spray bomb. For something I didn't care that much about, really looks good. We will see how it holds up on brake drums. I used the Dupli-kote brand I had on hand, but there are others that might be a better choice like Rust-Oleum.
    This was your typical heavy rusted 30 year old brake drum:
  22. wetskier2000
    wetskier2000
    from NH
    Nice! Don't forget the end of the axle shaft if that's going to show also... Maybe you're running center caps and it doesn't matter...
    FYI: Was watching Wheeler Dealers last night and they had some BMW alums redone.. They farmed it out to a guy that stripped them with acid, cleaned them off, powered coated then painted and sealed. The damn things looked brand new..
  23. 53 COE
    53 COE
    from PNW
    Thanks - Considering the Streeter polished wheels ....... Kinda like American Racing Torq Thrust but with no step lip.
    :cool:
  24. 53 COE
    53 COE
    from PNW
    My first truck..... Then 25 years later – had the chance to buy it back – went and looked at it…… But p***ed because I had just bought another one just like it…. Can you say “mid-life crisis”….. only keep the white one 3 years…. That's my 16 year old Son posing with it in the maroon shirt on the right - could of been his first truck too!
  25. 53 COE
    53 COE
    from PNW
    Rustic bed wood redux in free boards from incoming shipping crates at work. Good enough for now - if I ever repaint the truck will get an oak bed wood kit and new metal strips then....
  26. 53 COE
    53 COE
    from PNW
  27. Yes 53, those artillerys are cool. Really dig your truck. I'm looking for another cabover to play with, a friend has an early 70s eldo fwd that I could get cheap. I'm thinking rear engine, rwd with it and doing a bed like yours. I'm too tall (w long legs) to sit on top of a big block cad comfortably..
    Anyway, glad to see your rig is back with you and it's doing good- fourspeed
  28. 53 COE
    53 COE
    from PNW
    Go for it! :cool:
    Got the mags on - now to work on the stance - needs more rake!
    Before as built with 15 inch wheels and 31's and 33's.
    After with 18 inch wheels and 32's.... Looks like a HOT WHEELS toy now... ;)
  29. 53 COE
    53 COE
    from PNW
    Graveyard at night pic:
