Technical MSD Blaster 2 Blasted?
Discussion in 'Traditional Hot Rods' started by MikeG5211, Jun 19, 2020.
  1. MikeG5211
    MikeG5211
    From what I can gather this thing seems to be shot.
    Can I replace it with just a generic one they're mostly all the same right? I'm not running anything fancy. Thanks
  2. wheeltramp brian
    wheeltramp brian
    Aren't you supposed to test between the 2 terminals?
  3. squirrel
    What's wrong with that reading?
    Did you test another coil, and compare?
  4. Penetrator
    Penetrator
    from SK CAN
    You're on the wrong terminal.
    Positive terminal to coil tower - spec is 4.5K OHMS
    Positive terminal to negative terminal - spec is .7 OHMS
    MikeG5211 likes this.
  5. Mike VV
    Mike VV
    from SoCal
    To answer the question, yes, you can replace that coil with a "stock" (whatever that is) coil.
    And no, that type of oil filled can comes in many flavors. I've seen them from 32,000 volts to 48,000 volts and various miliamp outputs. To run a stock engine, without any power adders or high compression, yes, most any coil will work fine.
    Mike
    firstinsteele likes this.
  6. MikeG5211
    MikeG5211
    I get the same reading from positive terminal, So I ***ume it's no bueno then.
