MSD Blaster 2 coil testing
Discussion in 'The Hokey Ass Message Board' started by fatboy tim, May 24, 2009.
  1. fatboy tim
    fatboy tim
    from Edinburgh
    Resistance on coil is 0.9 and 4.2k, MSD spec says should be 0.7 and 4.5k, does this mean the coil is defective.
    Thanks for helping.
  2. Truckedup
    Truckedup
    Sounds like typical ohm values,if in doubt,try another ohm meter.
  3. fatboy tim
    fatboy tim
    from Edinburgh
    Thanks, appreciated.
  4. claymore
    claymore
    Did you zero your meter first?
  5. oj
    oj
    What is the 4.2K? The resistance on a coil is typically .9 ohms, where do you measure for the 4.2K, is that the high tension side?
  6. fatboy tim
    fatboy tim
    from Edinburgh
    Yip, thats the hi tension side.
    Put the coil back in and engine fired up first time!
    Might be an intermittent fault with the coil?
  7. recardo
    recardo
    from Winslow
    Roadrunner is on top of it. All guages are most accurate in the center, so you want to pick a ohm range that sticks the needle in the middle. To read 1 ohm is probably not going to happen with what most people have in their tool box.
    You can put a large resistor in series though. Measure (say) a 1k resistor by itself, and then in series with the coil terminal.
    I'd say the values are within tolerance.
