MSD Distributor ID?
Discussion in 'Off Topic Hot Rods & Customs' started by Malcolm Elvy, Oct 16, 2024.
  1. Malcolm Elvy
    Malcolm Elvy
    Can anyone ID the application for this MSD Distributor...no drive gear like a Mopar part but has a slot rather than a machined down surface at the bottom...Larger GM type body..Thanks for any help...Mac msd1.jpg msd1.jpg msd1.jpg msd2.jpg
    Deuces likes this.
  2. squirrel
  3. Deuces
    Deuces
    Slant six mopower I think...:confused:
  4. squirrel
    No, it's a long ways from fitting a slant 6.
    Deuces likes this.
  5. big duece
    big duece
    from kansas
    Small block Ford?
  6. squirrel
    you can use google images to search for pictures of your guesses, to see that they're wrong, before posting the guess here :)
    19Eddy30, Moriarity and Deuces like this.
  7. big duece
    big duece
    from kansas
  8. Malcolm Elvy
    Malcolm Elvy
    It is for an 8 ....it looks like Mopar but has a slot instead of a cut down area on the shaft....
    big duece likes this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    what keeps the shaft from going up from the bottom? normally there is a collar and a pin thru the shaft. I have never seen anything like it
  10. big duece
    big duece
    from kansas
    There looks to be a lock collar, set screw or roll pin is on left side, hard to see.
    Moriarity likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    I see it now....
  12. Deuces
    Deuces
    Sorry.... My bad!... :(
  13. squirrel
    no worries. I come up with all kinds of possibilities, but I eliminate them all by checking...
    19Eddy30 likes this.
  14. RmK57
    RmK57
    Sure it’s MSD and not a cheap knockoff? Pro Comp comes to mind.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    I looked on the MSD website (holley) and looked at every single dist and there was nothing like that, also MSD distributors have a part number on them....
  16. Harv
    Harv
    from Sydney
    I tried searching the other way (from the oil pump), looking for something with a tang drive the opposite of normal. Couldn't find anything... closest was VW (kind of...) but not in an 8.
    Old Hilborn pumps had that kind of drive before they moved to hex.
    Cheers,
    Harv
  17. Malcolm Elvy
    Malcolm Elvy
    Thanks guys...I talked to MSD and they didn't know either.....
  18. 19Eddy30
    19Eddy30
    from VA
    Where did you inquire the distributor?
    Some of us cut , dice & Machine things to fit our needs,
    Possibly modified to fit a inport
