Hot Rods MSD ??
Discussion in 'The Hokey Ass Message Board' started by 27 Tall T, Feb 11, 2022.
  1. 27 Tall T
    27 Tall T
    from Butler Pa.
    I never saw one of these. Does it take the place of a MSD box? 20220211_144556_resized.jpg
  2. squirrel
    "Ready to Run", it does not need a separate amplifier box.
    Fabulous50's likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    ^^^ yes PIC is the first generation MSD ready to run,( Blue module)
    The modern / later two plug wire connector MSD box required ,the modern / later three wire plug is also a ready to run distributor.
    squirrel likes this.
  4. 27 Tall T
    27 Tall T
    from Butler Pa.
    Thanks for the answer. I thought that was what it was, but never saw one, I bought a unfinished Altered project , and it was on it.
    Any idea of when it was made?
  5. 19Eddy30
    19Eddy30
    from VA
    I believe from what I remember seeing 90 ish mid 90s & the blue represented marina, , around same time Accel. Had a Gm HEI module on out side of cap on housing, & I believe conversion kits for other brands from points for small caps .
  6. 19Eddy30
    19Eddy30
    from VA
    There is no points in side the cap correct?
    Its a ready to run electronic ignition,
    Small cap / Compact.
    With module on the outside ,the blue box ,
    No 4 or 5 (80s box up grades for stock ignition) & no ,6.7 box Required but can be used.
