Technical MU6 Vibro Shear
Discussion in 'The Hokey Ass Message Board' started by Reidy, Dec 25, 2019.
  1. Reidy
    Reidy
    Hello all. I have recently a MU6 Vibro Shear and was curious if anyone has found a manual on how to use this. I sent a reply to a post I found on HAMB but noticed it was not in the correct area.
    Also I would like some guidance on setting up the nibbler function. Mine tends to chew like a ninety year old man with ill fitting false teeth. I am ***uming it needs a sharpen and setup for clearance between the two parts. I will have a play around but some advice may save a lot of heartache.
    Thanks and Merry Christmas from down under.
    Steve
  2. Lloyd's paint & glass
  3. oldiron 440
    oldiron 440
    Could you post a picture of it please?
  4. Reidy
    Reidy
    A MU6 Vibro Shear is a bit like a PULMAX.
    They were made in Japan and mine is from the 60's. The setup would be similar as for a Pulmax nibbler function.
    I can find a few youtube videos but not much on how to use.
    I am ***uming the "Huh" was because I did not explain what a Vibro Shear is.
    The attached picture is one the same as mine, not actually mine. They made different sized ones.
  5. Lloyd's paint & glass
    I was thinking about hair clippers o_O
  6. Reidy
    Reidy
  7. Reidy
    Reidy
    I you put something with hair in their it would get clipped, just not in a nice way.
    Budget36 likes this.
  8. john walker
    john walker
    Someone here converted one into a planishing hammer or mini pullmax or something like that.
  9. Reidy
    Reidy
    Once I work out how the nibbler side of tings work I was going to look into how these go as a mini Pullmax. I am curious what gauge of Aluminium or steel they can handle.
    Steve
  10. Gofannon
    Gofannon
    I have a manual for my MT4 but I have to dig it out. Should be similar tool clearances to your machine.
    upload_2019-12-27_17-10-15.png upload_2019-12-27_17-10-43.png upload_2019-12-27_17-11-19.png
  11. Texas Webb
    Texas Webb
    Looks like a nice machine.Good luck in your search.
    Seems to handle several operations.
  12. Reidy
    Reidy
    Thanks that would be appreciated.
  13. Gofannon
    Gofannon
    I haven't found my manual, but I did find these few scans I had done a while back. I'll keep looking. The angles on the tools are crucial to making good cuts. Clearance will depend on thickness of material.
  14. Reidy
    Reidy
    Thank you very much. This will be a great starting point in learning how to use this. I am itching to get back home from my Christmas stay at my daughters to sharpen up the bits and see if it cuts any better.
    Steve
    Gofannon likes this.
