Actually, Mufflers do have a bearing, of sorts. The newer cars (past two decades) have male and female hemisperical shaped connecting surfaces between the manifolds and head pipes and the pipes and mufflers allowing the pieces to move slip slide and rotate without leaking when their parts move independently of eack other during motor torque movement keeping parts from stress cracking. These joints are usually held tight enough together by a collared bolt, spring and lock nut that applies enough tension to stop exhaust leaks while still allowing bearing surface movement. Now for the practical left handed smoke shifter description...
[ QUOTE ] looks like it's time to sell my NOS set. [/ QUOTE ] Shortbus, Why do you have a stock of *** bearings... Is there something else in your closet?
[ QUOTE ] I need a lower radiator hose for 77' Super Beetle..... [/ QUOTE ] That's aftermarket stuff... for a remote oil cooler radiator
Wow!! I threw out all my old muffler bearings a while ago, never thought of e-bay! Maybe there's a market for the rest of the fratastat-comodulator's i have here, or even the gimbal gears i've got lying around. This auction is olmost as good as the guy that sold an apple on e-bay..no joke!! Rat..
I noticed the location was Leavenworth. I think a big prison is there,Could this be a scam.????? This is a correct bearing as a Muff does have radial and axiel force placed on them..
[ QUOTE ] Did you mean besides your bound & gagged wife? did I type that out loud? oops! [/ QUOTE ] In your dreams!
I wonder if they would buy antique air?we could sell them an old tire [blown up in 1948] and a short hose- to transfer the "vintage" air into their newer tires......... big opportunity here guys.
[ QUOTE ] Actually, Mufflers do have a bearing, of sorts. The newer cars (past two decades) have male and female hemisperical shaped connecting surfaces between the manifolds and head pipes and the pipes and mufflers allowing the pieces to move slip slide and rotate without leaking... [/ QUOTE ] DrJ, you lovable geek. That's like saying clutch belts are legit because Ford did have a belt, of sorts, in a Model T ******. http://www.kalecoauto.com/general.htm --Matt
I know my ***le to my 1983 vette is around here somewhere. When I find it maybe I can get my tag updated. Reverend Jake
Leavenworth federal prison. Shipping out of there probably expensive, have to pay off a couple guards. BUT you are safe, notice how he (or she) wears rubber gloves. Wont catch nothin.
