Technical Mufflers and such
Discussion in 'Traditional Hot Rods' started by dsiddons, Feb 2, 2026.
  1. dsiddons
    dsiddons
    from Indiana
    I’d like to get some opinions from you all. I’ve had a slew of hot rods and all but one nailhead was all flatheads. All of them had short straight pipes also. Anyway I’ve got this coupe now and bought some really *****en exhaust tips here on the HAMB so now I’m kinda gonna have to run the exhaust out the back. I’ve been on YouTube with the volume up of course and would like some input. Start with the motor. 283 with some double humps and L79 cam. Now let’s talk about exhaust and mufflers. I’m reading a 2”-2.25” exhaust is about what I need for the best performance. I’d bet that doesn’t matter much so my questions are . What’s the best sound for this little V8? I’ve been listening to everything from short to long cherry bombs to the small flomaster super 10’s. If I can say preference I don’t like ratty sounding exhaust but on the other hand I don’t want it quiet either. Any inputs would be appreciated and considered. Oh 5 spd transmission. Check out these ***s! I mean tips.
    Thanks
  2. klawockvet
    klawockvet
    Porters sounded great on my last flathead
  3. Just Gary
    Just Gary
    14" steelpacks; either Porters or Brockmans.:cool:
  4. hrm2k
    hrm2k
    my old coupe had 1 5/8 pipes with an insert to break up the sound. It sounded hot rod.
    My rpu is a 283 4 deuce with a 5 speed. I'm doing 1 5/8 on that as well.
    IMHO, when you get more than 2 inch pipe, it starts to sound muscle car
    dsiddons likes this.
  5. dsiddons
    dsiddons
    from Indiana
    Well now that’s interesting to know. I appreciate that input.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    1 5/8? surely you mean 1 7/8 don't you?
    gasshole and 05snopro440 like this.
  7. RMR&C
    RMR&C
    from NW Montana
    1 5/8" is a good header primary tube size....
    I prefer chambered mufflers on a hotrod. Nice rumble sound. 2 in pipes would probably work fine for a mild 283
    05snopro440 likes this.
  8. marfen
    marfen
    from sask
  9. Bandit Billy
    Bandit Billy
    I am glad the HAMB is finally getting around to a discussion regarding mufflers.
  10. wuga
    wuga
    I am running Porters on my banger, on my Studebaker V8 and on my 300 cu in aluminum Buick V8. All sound great. All 2" in and 2" out.
    Warren
    winduptoy and Tow Truck Tom like this.
  11. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    I rarely see the Cherry Bomb steel packs mentioned here, but I’m real happy with them on my banger. Scallops installed facing the exhaust, if you wanted them probably a little louder you could install them the other way.
    winduptoy and Driver50x like this.
  12. Jalopy Joker
    Jalopy Joker
    H.A.M.B. friendly is loud and ratty, for some. mild out to rear of car for others to enjoy good too. do you want to hear exhaust inside past insulation with windows up and radio on?
    guthriesmith and DZ like this.
  13. NoelC
    NoelC
    Me to...I'll start. Somehow improved performance has been equated to loud noise.I'd like to take a moment and share my opinion. It isn't.
    I'm curious about the "best performance" part,. How do you define that? What exactly were you reading? Why is the word performance the criteria? Why not comfort? Or...driving pleasure? All around purpose? Listening pleasure? Driver friendly? But you want performance... The word attached to loud vibrating teeth rattling extra second gaining flat out high revving output free flowing hope to win races neighbor annoying noise makers.
    You do have a choice you know, you can pick a different word. One that says, the rumble is real, the ride enjoyable, and if need be, all systems still go. That word is behaviours. What exhaust will when used on my car will allow it to exhibit it's best behaviours?
    2.25 duals, balance tube, factory ovals and tail pipes with those ***y tips.
    alanp561, 05snopro440 and Just Gary like this.
  14. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    It tickles your innards.:p
    Adriatic Machine likes this.
  15. Blues4U
    Blues4U
    from So Cal
    I've really enjoyed this exhaust system, it's loud, but not too loud, it's throaty, not ratty, it doesn't have that decel rap like gl*** packs do. It is a 283 with lakes headers with Speedway spiral baffles inserted and the tips turned out sideways. At any car show or rod run it's not the loudest and certainly not the quietest one there. I know the OP is not looking to use lakes pipes because he has those new tips he wants to use on the back, but a fella could insert the spiral baffles in a header collector then choke the pipes down to 2" and run them out to the rear. The sound wouldn't be the same, but it wouldn't be far off.
    alanp561, HemiDeuce, Robdski and 9 others like this.
  16. chopolds
    chopolds
    from howell, nj
    I prefer Brockman Mellowtones on all my Kustom builds. Just sounds authentic 50's hopped up. They can make them in different levels of loudness, by length of muffler, or what packing you use, fibergl***, steel, or nothing. But they are all going to be louder than stock!
  17. Nailhead Jason
    Nailhead Jason
    that engine combo is very similar to my 39, 283 10 to 1 compression with an 097 cam. I run fenderwell headers and 2 inch straight pipes into little Kick Stand style lake pipes I made. It sounds great is really not loud and sounds like i'm making a lap at Riverside Raceway in 1963 when i wind it up to 6000 rpm. Id build the whole exhaust with straight pipes and if its too loud you can always put mufflers into a straight section later. I'll try and attach a video to this thread of it running later. or you can look on my instagram there are some on there from a while back @Jacobs_Hotrods
  18. Tim
    Tim
    from KCMO
    @wuga id love to hear that Stude!
    but to the OP I would say the most “traditional” cars are running a porter for the deeper tone but still a good cackly hot rod noise.
    I have smithys which are also very traditional but quieter.
    on the cherry bomb type route if you go check out iron Traps you tube videos damn near every one of those cars are 1 3/4 ish pipes with a store brand/ super cheap/ cherry bomb 12” gl*** pack.
    granted sound out of your phone or computer is never gonna get it exactly accurate but it gives you an idea.
    a lot of the characteristics and tone come from the muffler but a fair amount comes from the size and design of the rest of the system as well.
    based on your question and car id say you’d probably like the porters
  19. Moriarity
    Moriarity
    SUPER MODERATOR
  20. Moriarity
    Moriarity
    SUPER MODERATOR
  21. Moriarity
    Moriarity
    SUPER MODERATOR
  22. Moriarity
    Moriarity
    SUPER MODERATOR
  23. Blues4U
    Blues4U
    from So Cal
    That sounds great! That's what a traditional hot rod Chevy V8 is supposed to sound like. Love it!
    porkshop, Just Gary and Moriarity like this.
  24. jim snow
    jim snow
    Corvair turbo’s are my go to. Been using them a long time. Snowman ⛄️
    porkshop, winduptoy and Jalopy Joker like this.
  25. DDDenny
    Yet after 217 pages there will still be no consensus!:rolleyes:
  26. Nailhead Jason
    Nailhead Jason
    here is a vidoe of mine after the Kick Stand lakes were added.. no mufflers, just 2 inch pipes out of fender well headers.
  27. theHIGHLANDER
    theHIGHLANDER
    Some of us are old grey *******s, I certainly am. In my youth I enjoyed loud, but I was raising a family and running a business so long trips in the toys didn't happen near enough. I'll go on record to say I could die happy if I never heard another ****in Flowmaster. When it comes to mufflers it's akin to someone with a speech impediment. Not to dis folks with such, just sayin. I've heard so many cars with gl*** packs it's hard to cypher what's under it. Well, unless it's a legit Thrush from the 60s-70s. NOTHING sounds like that, but I digress. I never understood why we'd pay over $100 for a name like Porter or Smitty just to say it when asked. Compression makes em all sound good. Nothing else helps, and putting such things on a stock motor sounds like you took your mom's car out and dropped the muffler for the night. At my age I want a clean sound. Sound alright, but an incessant drone for hundreds of miles gets old fast. Went fron Detroit to Indy n back in 85 with good ol turbo mufflers on a 70 Cuda with a 383 and purple shaft cam. It was take a chance at 70 (was still 55) or below 60 for comfort. I didn't learn. Had a 5.0, and yes, I put Flowmasters on it (used to like em) and the same ****. 65 or 80 MPH, otherwise the drone was maddening. I'd crank the CD with some White Zombie or Metallica to cancel it. Any gl***pack fed some compression will sound good. An equalizer or balance tube will smooth it out and remove the rat-a-tat-tat on decell (I didn't even like that in my youth). If I was doing this, I'd get some cheap Walker gl***packs (mine were $25 each but 6yrs ago) run em for a while and see if something better or more $$$ was worth doing. No, I haven't run mine yet, I know what it's gonna sound like with fresh stock flatty. Yes, leaving my heat risers open. Feel free to convince us that $300 shipped is worth spending on Porters, or $250 shipped for Smitthys. Seems speedy to me, especially when you can't really tell. After a lifetime of street and track racing, restoration and hot rods, I know exhaust sound is almost as important as stance. What do I think is the best sound? Magnaflows. Nice and pleasant performance tone cruising, almost obscene at WFO. Best of both worlds and they'll find a home under my GTO.
    The OT rod I built has em. Nearly perfect. My opinions which are worth whatcha paid for em;)
    INVISIBLEKID, 6sally6, treb11 and 2 others like this.
  28. DDDenny
    In the early 70's I was a ****er for these kind of marketing ploys, hey, I was just a kid.
    These were the ones that were deemed illegal (loud), people knew you were coming long before they saw you.
    They still make them but they have been "neutered" considerably.
  29. Bandit Billy
    Bandit Billy
    I try to explain to people what it feels like to have this Meniere's disease flair up that has had me sidelined since September. Your video (cool by the way) is what I see when I drive or ride in a car. No stabilizer at all, just bouncing.
    As for car exhaust, I don't care for straight pipes. I have tried them and those horrible, chambered pipes that were options on 69 Camaros (barf). To each their own. I run 22" Smittys on my blown flathead and they sound nice, a little too loud as they burned in to be honest. I put 22" Porters behind the Desoto, it doesn't have much more than break-in miles on the clock, but they are already very loud! The Desoto is 10.5:1 so it barks. My 442 (11:1) has magnaflows that have been on there for over 20 years, they sound nice still to this day. I liked that so much I installed them on my 2020 Silverado (6.2L, 11.5:1 CR), Sounds mean pulling a trailer and my wife always knows when I get home! My dune buggy has flow-masters and sounds like an old, fat lady walking on a foggy pier, farting with every step...wearing tin can undies.
    alanp561, Blues4U, Toms Dogs and 4 others like this.
  30. Tim
    Tim
    from KCMO
    I’ve got 36” smithy’s on my 46 behind a sbc and they did get considerably louder as they aged but the tone is still good. Pretty quite at idle
    neilswheels and porkshop like this.
