Technical mufflers
Discussion in 'The Hokey Ass Message Board' started by gdrummer, Mar 29, 2024.
  1. gdrummer
    gdrummer
    hi ya'll. i have a few questions and i know this is the place to go for my answers so thanks in advance for all the replies.
    i'm working on my 1951 crown vic with a 50 8bA
    where can i go for a step by step procedure for setting the engine up after break in? looking for info on timing, dwell, etc.
    also, i have the ford factory type headers and i was thinking of going with smittys. should i have a pipe between the headers and the mufflers? how long should it be?
    i also have a question pertaining to a duel carb set up. i seem to remember being told that i can use a 59A intake on a 8BA but it seems to me that won't happen. is that correct?
    thanks again.
  2. jimmy six
    jimmy six
    Unbelievable…The holy grail of Fords….a prototype 51 Crown Victoria …4 years before the CV was available the public.
  3. MAD MIKE
    MAD MIKE
    from 94577
    Do you mean Victoria?
    That would help with the noise.
    Should be the length of the header collector to the muffler.
    Do you mean a crossover pipe?
    Best to proof read and clarify what you mean. None of us have the car in front of us. You do.
    mad mikey and X38 like this.
  4. gdrummer
    gdrummer
    sorry about the bad info.
    it is a 1951 vicky with a 8BA and a 3 spd O.D.
    thanks for your help
  5. If you want a 50's sound use cherry bomb or Smitty mufflers and put them forward to get more wrap or rearward to get less wrap,
  6. Hillbilly Werewolf
    Hillbilly Werewolf
    I love my Brockman Mellowtone steel packs.
    Supports a US mom & pop, and their service can't be beat.
    Call him up and talk to him about what you have and what you want. He will make recommendations for length, crosspipe, and general placement.
  7. RodStRace
    RodStRace
    Set dwell or at least point gap before starting. Then set timing static before starting.
    https://www.jalopyjournal.com/forum/threads/flathead-timing.1193605/
    I'm sure there are a lot more and as mentioned in this post, lots of youtubes.
    To make sure that first start goes smoothly, read up on what others have done.
    https://www.jalopyjournal.com/forum...t+start&o=relevance&c[***le_only]=1&c[node]=5
    I don't have personal knowledge of this exact setup, but most manifolds/headers point down and back. Connecting a muffler directly to them would cause the muffler to point down and hang below ground level or point to the firewall. In some cases, the end of the header is even with the frame and level. You can bolt a muffler on the end for a first fire, but will want more exhaust in most cases.
    JohnLewis likes this.
  8. greybeard360
    greybeard360
    Remember the auto shop cl*** your guidance councilor tried to get you to take in high school? It would have been real handy about now.... auto shop taught basic skills.
  9. Petejoe
    Petejoe
    from Zoar, Ohio
    Your stock distributor will not allow you to use dual carbs. That setup must be attached to ONE Holley94. Dual carbs won’t provide the proper vacuum signal for your advance.
    To run dual carbs you’ll have to change your distributor. A 59A intake will work on that engine but it will cut off your ventilation flow within the engine. The only way to accomplish that would be to install a PCV setup.
    Lots of info on the hamb on how you can accomplish these things. Do a thorough search.
  10. custom_lettering
    custom_lettering
    from Wall, NJ
    100% Love the Brockmans on my Merc
    Hillbilly Werewolf likes this.
