Multi-Carb Setup post by Vintakes-Retold. Carb Tech-linkage, jets, etc..
Discussion in 'The Hokey Ass Message Board' started by Dreddybear, Nov 7, 2009.
  1. Dreddybear
    Dreddybear
    This is a highly informative, excellent post by vintakes on multicarb setups: linkage, jetting, and so on. It was a bit hard to read so I edited it a bit, added periods and paragraphs. Alot of recent questions can be answered here. Enjoy.
    Multi-carb tips and suggestions
    BY VINTAKES
    GREETINGS! First off I’m NOT the Barry Grant of multiple carb set-ups this article is written from my personal experiences building units, articles read in OLD car magazines and the installation instructions -tuning tips from old speed shop dealer bulletins. This article is directed at STREET driven vehicles
    SELECTION sizing and number of carbs very important for good crisp street driving. Yeah it’s cool to show off your 283 with six Rochester 2 bbls with straight linkage on a log intake, auto trans, and 2.76 rear end gears, but drivability will be very poor unless of course you "dummy the end carbs". I fell if ya got them they all should function, so I will not address dummy carbs.
    It’s basically all about air speed in your carbs. Turn on a garden hose and watch water flow, then put your thumb over the hose end. The water’s going faster, right? The same applies to your carbs. Your engine is a large "air pump", the more air it can pump the more carb CFM"s you can use and be able to handle and still keep good air speed. Sizing also depends on the RPM range you run your motor. There was a dyno test on stock 350 Chevy motors and the 2bbl motor made more HP and torque up to 4,500 rpm than the Q-Jet one!!
    Going back to our 283 – 6x2. If you have an 11,000 rpm 283 drag motor the 6 Rochester’s would be too small- you would need more carb CFM’s. I’m basing these suggestions on a 350 with 9.1 compression ratio, mild cam- 110 - 112 lobe centers, 260 duration or less with a 5,500 rpm red line (bigger motors and motors that operate at higher rpms can use more cam).
    NOTE: Here building a fresh car / motor with multi-carbs?? Install a stock 2 or 4bbl carb to fire fresh motor and break in. Work out all "bugs" with the stock stuff FIRST then install your multi set-up. You now have a performance baseline to judge by when you install the multi unit. This also removes any possible excuses from your engine builder, like "Hey the tri-power caused your cam to fail, ain’t my fault!" and other misc. B.S. Sure its cool to have your rod sound like a AA/GAS car at the show but extensive cam duration severely lowers motor vacuum [air speed], hampers street-ability immensely, and will cause problems with the power valve circuits. So try to plan first, keeping in mind the TYPE of actual usage. I’ve seen guys build a rump-ity – rump motor for there ride and then use 2.76 gears with a overdrive trans saying "In OD I’ll be turning 1,200 rpm at 70 mph great!!" But in reality there’s no HP or torque at 1,200 because there’s very low engine vacuum NO AIR SPEED so they will not be able to use OD on the highway but they can brag they have OD. My recommendation for SBC street motors 327 – 350"s is a exact copy of the 64 corvette 327 300 HP hydraulic cam it gives smooth idle power from 600 rpm to 5,000, great torque and decent fuel economy, and good air speed. I think I’ve seen these "blueprint cams" in JEGS. I’m not at all fond of the RV cams they seem to lessen low-end power and mileage, so choose carefully.
    Next up trans kick down cables. I’ve seen many 700 R tran’s without any cables at all. These aren’t only kick-down down shift, but also control valve body pressure (throttle pressure) and as such should not be eliminated. Installing a shift kit STILL requires a cable (unless you have a full compe***ion manual valve body). Yeah it takes some doing to hook to carb, especially on 4 carb direct port intakes (man-a-fre style). Also if you swap out intakes for different looks, etc.. you will have to go thru making new brackets.
    Pain? Yep! Answer: hook trans cable thru firewall to gas pedal. If you don’t want to spend time engineering or want a pattern, go to local salvage yard and look for a ‘74 Chevelle/Olds cutl*** with 350 trans. These have factory kick down cables thru firewall hooked to the gas pedal. Simply remove gas pedal ***embly and cables and install in your car. This also makes for a neater looking intake system without excessive cable brackets. Show off your multi carbs.
    NOTE: 350 TURBOS DO NOT REQUIRE A CABLE to be hooked up. It's only for foot operated p***ing gear.
    Distributors will also need attention. Your advance curve is important to work with your multi-carb unit. I personally like the Spalding flame-thrower distributors. They look cool and work great once set up properly (you can find set-up instructions for these in my web site). The old Mallory dual point dist are also good units (see article in my web site).
    You can also have your dist advance curve changed by dist shop. Or you can purchase kits from Summit, Jegs, etc.
    If you’re using 97’s no vacuum advance port is available on the carb unless you drill one.
    94’s have ported vacuum port but a weaker-than-gm-requires vacuum signal. For ease of set-up run a full centrifugal advance dist.
    Rochester’s obviously compatible with gm dist and vacuum advance unit.
    Fuel pumps. I recommend using stock motor driven pumps 4lbs – 7 lbs. You don’t need high-pressure pumps for the STREET. 94 and 97 style carbs will need fuel pressure regulator set around 1 ½ - 3 lbs. Holley makes a good one. Also the "dial face" type will work. Rochesters don’t need reg with stock pumps, electric pumps only. Electric pumps and Stromberg carbs don’t work well together. Yes you can crank the pressure regulator down till carbs stop dripping at idle, but you’ll run out of fuel mid – top end. If you want maximum performance with 94’s – 97’s I’ve "worked out" a fuel byp*** system that will work with a Holley 7lb 6 valve performance pump. You will need a return line to your gas tank. E-mail me for details.
    Ok enough of motor stuff lets get to the carbs.
    The basic tri – power: Use either small base Rochester 2 bbls with progressive linkage or the larger 94’s. Smaller 94’s and 97’s will work well but you may run out of steam around 4,800 rpm. Don’t be afraid to mix carb sizes- larger centers, smaller ends, etc. The smaller the carbs the more low-end power (street power) you will have as well as more air speed through the carbs and better fuel atomization. As carb size increases so does the useable rpm range but the low end power suffers because the air speed is diminished at low rpm (remember the garden hose test).
    Now, you can run the center carb and progressively tip in the end carbs the standard way [1x2]. If you are using factory tri-power carbs or the conversion style carb bases with NO IDLE CIRCUITS you must set-up this way. With regular carbs you can run the end two carbs and progressively tip in the center [2x1]. If you’re using regular carbs I feel this is the better way [both 1x2 and 2x1 are ok]. It will give more exhaust noise and slight mid range torque / HP improvement especially if your using 97’s or 94’s. Part of the problem with 1x2 with regular carbs is you really can’t get the throttle plates to completely close, so you always have an "air-leak" at each carb (yes the air leak is compensated for with the idle mixture screws). Sometimes you may have trouble getting engine to idle slow enough because you have two air leaks which need to be equal (end carbs must be synchronized), the center can be different.
    If using the 2x1 set up (this was common place in the early 50’s, I have factory eelco linkage instructions which show how to do this with many different types of carbs)
    simply close the center carb (as far as it will close) and use the balanced ends for idle speed. I feel it’s better to have one air leak in the center than 2 closer to the valves- you decide.
    On all set-ups [except fact 3x2 and conversion bases] you need to keep, use, and adjust the idle mixture screws on ALL carbs. On secondary carbs I eliminate the power valve. On 94’s you must put the power valve in the carb [under the base] but bock off vacuum port in base. You can get a old lead wheel weight, cut off a piece and gently tap into vacuum hole.
    NOTE: the valve on the outside of some 94’s is NOT the power valve!! It’s a spark delay valve used in conjunction with the old ford vacuum advance only distributors. Install valve, or plug the hole with a holley power valve block off plug. Also if you using one of these stock old ford distributors, do your self a large favor THROW IT OUT!! And replace at least with a 57 and up vacuum and centrifugal advance unit.
    On Rochester’s you must keep the br*** valve located between the main jets in the center section and remove the spring-piston ***embly from the top carb section. Also block off the vacuum port in the carb base with lead (use piece of old wheel weight) Be careful not to block off the idle circuit holes.
    As a rule of thumb when the power valves are disabled (Rochester and 94’s) you will need to increase the main jets sizes around .006 – .008.
    NOTE: On 97’s just leave the pump rod off and increase mains .002. I use a numbered drill set for my jetting increases but purchasing actual numbered jets would be better.
    4 carb units: My favorite for SBC here is the Weiand staggered intake with 4 small 94’s or 97’s. These units look cool and street-perform very well with progressive linkage. The old set up instructions say to use the outer pair of carbs for primaries and the in-board pair for secondaries. I’ve run these both ways (inner pri, outer sec) and have noticed no difference in setting up or performance. Linkage here is not for the weak at heart but well worth the time. You need to have a machine shop make shaft extensions for the 2 carbs mounted on the p*** side of the motor. All linkage is mounted on drivers’ side. You also need to make a support bar that fits over all 4 carb shafts to support the long extensions. Here pri carbs need to be synchronized together and sec carbs together. The pri and sec don’t have to be the same.
    4 carb direct port man-a-fre style units: Be careful using these. These must run straight linkage only so low-end power is gonna suffer ESPECAILLY with large Rochester carbs. Even the small rochesters will be touchy. Small rochesters will work on lighter weight stick shift cars with lower rear end gearing (higher numerically) and/or light cars with 3,000 stall converters and lower gearing. You have to keep the rpm’s up to keep decent carb air speed. 1 or 2" risers will help to increase air speed. Later in this article I’ll give you rochester jetting recommendations from man-a-fre service bulletin. 4 small 94’s or 97’s are best for street use. Here again use risers. On all these units all carbs must be synchronized exactly the same. I think speedway sell a synchronizing gauge but you must use a gauge on these at idle speed and part throttle. Idle synchronizing is done with idle stop screws and above idle sync done by adjusting the connecting linkage rods.
    Tip here: if you only use one carb throttle plate stop adjust screw per side, leaving the other two carbs without idle stop screws, you can synchronize carbs with the idle stops on two, and connecting linkage rods on the other two. This should be all you need but still check at above idle. Un-synchronized carbs can cause burnt valves, pistons, plug washing, and the backfire thru carb and maybe a real fire! HINT: carry fire extinguisher with you.
    5 carb this is of course limited to inline chevy/gmc motors: I have no experience with these but common sense would say don’t run straight linkage on the street and use all carbs only on larger inch motors here you can run 3x2 or 2x3 and or dummy the others hey they sure look cool!
    6 carb: My favorite here is the Edelbrock X-1 cross ram with small 94’s or 97’s and progressive linkage. If you have a fairly healthy large motor [NOT CAM] you can run the end 4 carbs for primaries and dump in the center two for secondaries. I have some old linkage installation sheets that show 6x2 units set-up this way. This will give power increase in the mid range. For the rest, use centers for pri, ends for sec. Try both ways to see what’s best for your car. If using log style intakes, again 1 – 3" risers will help low end power and make it easier to linkage carbs. All sec carbs should be synchronized together and all primary carbs separately. Primary carb synchronization doesn’t have to match sec carb synchronization. 6 deuce set-ups are not a good choice for 283/305/307 and stock 327 motors unless stick shift or high stall converter and 4:11 – 4:88 gears are used (depending on car weight). You can however dummy the secondary units if you require that "look".
    Linkage: Ball bearing – swivel type is the easiest to use and set-up. Some carbs will need extended throttle shafts. I usually set arms to move between 10 o’ clock and two o’clock or vice versa. Sec arms should have the same angle at idle on all carbs. Make sure all sec arms are the same length (eye to eye), the same goes for the primaries. On 6x2, secondary tip in point should be the same on both sides. Straight pin style linkage takes more time to set properly but is well worth the extra time spent. Install carbs loosely on intake with ALL accelerator pumps disconnected so carbs flop open and closed (like ****er).
    When I do 97-94 style carbs I just loosely install the bases only. Start with the two (pri or sec) that work together, install rod /pins in arms. Now open and close linkage. Smooth? Maybe. This is the key factor. Twist the loosely installed bases in and out, left and right until there’s absolutely no drag (binding). Tighten bases and recheck for drag. Do the same for the remaining base or bases. Secure linkage arm bolts and install centers-tops. Another major problem with multi-carb units is "gas pedal over-pull". This will cause your carb linkage to slip causing very frequent linkage adjustments and bending of rods. Make sure when your gas pedal is "floored" you are not trying to pull carbs PAST full throttle. Also check for full throttle. If you can’t change overpull condition by adjust pedal linkage install a hood bumper stop (the adjustable ones used on early 50’s/60’s cars) thru the floor-board under the gas pedal. Now you can adjust the bumper to regulate how close the pedal comes to the floor-board and prevent over-pull.
    TIP: On 94 style carbs replace the ¼" base screw with a bolt so you can install centers/tops AFTER the bases are bolted down and linkage is set-up. This will enable you to also change carb jets without disturbing and having to re-set the linkage. Be careful here not to strip the threads.
    Dual Quads: Cross rams, tunnel rams, and inline low risers. My pick here is the M/T staggered carb, round cornered crossram. It has nice flow and an equalizer tube built in. I haven’t tried the two-piece crossram (offy, edelbrock, or camaro) so no comment here. If using a tunnel ram for street with front facing carbs you can run progressive linkage, same with inline low risers. I feel the best carbs for 2x4 are two 400 cfm AFB’s or Holley 390 – 450 cfm with vacuum secondaries. Beware of the 450 holley mechanical sec carbs. These have no secondary squirters and will cause low end full throttle problems.
    Next up jetting. These are only guidelines. Temperature, al***ude, cams, and compression all have a factor on jetting
    3x2:
    rochesters 1x2 or 2x1 pri 059 sec 057
    94’s [15/16 bore size] pri 053 sec 057
    97’s pri 046 sec 045
    4x2:
    weiand staggered
    94’s [15/16 bore] pri 052 sec 056
    97’s pri 045 sec 045
    6x2:
    edelbrock X-1 cross ram
    97’s pri 045 sec 044
  2. brigrat
    brigrat
    from Wa.St.
    I will wait for the movie................
  3. strombergs97
    strombergs97
    Good job..It might be a little techy for some..Lots of really good info..
    Duane..
  4. 28chevrat
    28chevrat
    Good info...thanks
  5. Abomination
    Abomination
    RIGHT THE **** ON!!!!
    Thanks for editing that - I'd meant to do it, but life got in the way! You rock, man!!
    And yes - there's some stuff that might be a little techie for some, but honestly, this made my day. Why I don't do this for a living eludes me.
    Guys, why DON'T I build multi-carb setups for a living? Somebody tell me not to do this...
    ~Jason
  6. HotRodFreak
    HotRodFreak
    VINTAKES aka Johnny O has mucho hands on experience building and rebuilding carbs and multi carb setups. He drives his hot rods and is a p***ionate drag racer.
    You will see him running at Antique nats, Nostalgia drags, Mooneyes xmas, etc.
    You have seen him selling cool NOS stuff at HHR, March Meet, Father's Day, and Big Three.
    Here is the engine in his chopped and gold 34 coupe.
    Deuces and kidcampbell71 like this.
  7. 58_Ford
    58_Ford
    from Phoenix
    Great info . My new 58 Ford 390 has 3x2 rochester on a f-380 edelbrock mani. It had been sitting for 3+ years.
    Got it running but the idle is messed up,dies when in gear, cant run without choke closed and smelly exhaust everywhere. Almost put the set up on ebay until I read this. It looks too cool not to try.
    Thanks!!!
  8. holeshot
    holeshot
    from Waxahachie
    DAMN DREDDY...war and peace was a shorter read! just kidding my friend. they should have paid you for the rewrite. it's VERY GOOD WORK. thank's for your work and effort. not many people are as thaughtfull...POP.
  9. 58_Ford
    58_Ford
    from Phoenix
  10. boutlaw
    boutlaw
    Excellent read, and appropriate now that i will be running a 2X4 M/T crossram intake. Still trying to locate some 390 CFM carbs that won't break the bank. 600 CFM carbs can be found for almost half of what the 390's cost. Thanks for taking the time.
    Outlaw
  11. Bad Daddy
    Bad Daddy
    Nice. Have three deuces on the coupe. This helps take the mystery out of tuning them.
  12. AAFD
    AAFD
    from US of A
    Good stuff!
  13. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    thanks for the post.
  14. Deuces
    Deuces
    Buy 2 sets of secondary spring kits for the 600s from Holley and install the heavy "black" springs in the pods.... That should keep secondaries from opening at low to midrange rpm's....
    Also get a set of pod caps with the vacuum balance fittings and hook up a piece of vacuum tube to connect the 2...
  15. 1olflame
    1olflame
    Great article I am runing three carbs now but just picked up a six carb set up for the 36 going to plAy with it this winter
  16. brady1929
    brady1929
    Great information.
  17. IowaMercMan
    IowaMercMan
    Thanks Dreddy! Glad I found this
  18. Tim_with_a_T
    Tim_with_a_T
    Bumping from the dead. I used to enjoy going over to the vintakes site and reading all the tech info, but the site is long gone and this post is all that remains of all that wealth of knowledge…
    Quoting the original post, “If you want maximum performance with 94’s – 97’s I’ve "worked out" a fuel byp*** system that will work with a Holley 7lb 6 valve performance pump”, does anyone by chance have the details on this?
  19. Abomination
    Abomination
    You could try DMing the guy direct, here:
    https://www.jalopyjournal.com/forum/members/vintakes.1636/
    Tim_with_a_T likes this.
  20. Abomination
    Abomination
    Here’s the last archive of the Vintakes webpage from 4/18/2022:
    https://web.archive.org/web/20220418165703/http://www.vintakes.com/
  21. Tim_with_a_T
    Tim_with_a_T
