Technical Multi-carb setup
Discussion in 'Traditional Hot Rods' started by jerdan, Apr 3, 2023.
  1. jerdan
    jerdan
    When setting up a Holley 94 multi-carbs, with the extended shaft how do you handle the accelerator pump?
  2. guthriesmith
    guthriesmith
    Adriatic Machine and ramblin dan like this.
  3. jerdan
    jerdan
  4. Model A Gomez
    Model A Gomez
    The extension on the shaft is on the opposite side of the carb and the accelerator pump runs just like a stock shaft.
    guthriesmith likes this.
  5. Adriatic Machine
    Adriatic Machine
    I’m tinkering with the dual 1904’s on my 223 I-6 and first thing I learned is to set the accelerator pumps on “winter” for a shorter throw. Should have two or three holes in the A/P lever. Use the one that is farthest from the end
