Technical Multi carburetor flathead Ford intake history
Discussion in 'The Hokey Ass Message Board' started by out plowing, Aug 4, 2023.
  1. out plowing
    out plowing
    Who was making multi carb setups prior to 1945 for the Ford flathead?
  2. oliver westlund
    oliver westlund
    Tommy Thickstun in 1930, Vic Edelbrock, Jack Henry, Jim Harrell was right around there although he may have been 1946. Robert Paxton had a dual carb stacked slingshot type of deal that sat on a McCulloch supercharger. Mal Ord made a log style dual carb for lakes use. Weiand was doin their thing... Hilborn made some. I'm sure I am missing a ton
  3. oliver westlund
    oliver westlund
    Ed Winfield...duh!
  4. oliver westlund
    oliver westlund
    Riley too? Pretty sure
  5. Fordors
    Fordors
    Hexagon Tool & Die was a shop that did work for Ford and for the 1935 Miller/Ford Indy cars they produced two carb aluminum manifolds. The original design by Harry Miller was an open plenum, four carb manifold but those suffered from a reversion problem. I don’t know who designed the Hexagon but it was a conventional 180* design with the carbs mounted reversed on the manifold.
    Hexagon was later able to market them and because the carbs were backwards they gave room for the generator.
    Toms Dogs, alanp561, hrm2k and 3 others like this.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    There are pre-war Edmunds intakes for flatheads out there as well. Also, Shanafelt manifolds that came out of Portland.
    oliver westlund likes this.
  7. tubman
    tubman
    1940?
  8. quickchangeV8
    quickchangeV8
    The Ford flathead made it's first appearance in 1932, so how is it possible that Tommy Thickstun had speed equipment available for the flathead in 1930?
    seb fontana and Fortunateson like this.
  9. seb fontana
    seb fontana
    from ct
    Insider info..:rolleyes:
  10. oliver westlund
    oliver westlund
    He said multi carb for flatheads There were flathead 4 cylinder and 6 cylinder engines. Not just flathead v8s...thats how
    alanp561 likes this.
  11. oliver westlund
    oliver westlund
    Lotta smart guys out there who cant read or dont know history or both I guess
  12. oliver westlund
    oliver westlund
  13. banjorear
    banjorear
    If we are talking pre-war ('32-late 30's/very early '40's) to '45 (WWII ended in 09/02/45), there were a few. Early on, guys like Davies, Alexander, Ord, Roof, Jack Henry, Eddie Meyers, Eddie Edmonds (early water heated intake), Hexagon Tool (as someone mentioned, for the '35 Miller front wheel drive Indy cars) made V8 2X2 intake manifolds. The closer you got to the start of WWII, more and better stuff became available like the Wieand high rise, Edlebrock Slingshot, first version Thickstun, Burns intake with detachable risers.
    I'm certain I'm missing some intakes, but these were some of pre-war intakes made. A lot of the really early stuff was made in small amounts and used for their own and their buddy's racing exploits.
  14. quickchangeV8
    quickchangeV8
    Tommy Thickstun never made any 4 Cylinder or 6 cylinder speed equipment in 1930 or ever for that matter. In high school in 1930 he did make one 2 carb intake for a Chrysler straight 8 and in the mid 1930's he made a 2 carb adaptors for the flathead Ford V8. His Thicksun tall intake introduced in 1939 ruled the dry lakes in the late 1930's and early 1940's, as most of the dry lakes racers were running this intake. I can read thankyou very much and it looks like I know a bit of history as well.
    Fortunateson likes this.
  15. oliver westlund
    oliver westlund
    Well you've done a little research and changed your angle since I pointed out something obvious but hey whatever makes you feel better buddy. Thickstun made em pre 1945 as per the original post. He started in 1930 yes with something that wasnt flathead ford I'll concede that point. Regardless flathead ford refers to 5 or 6 different engines and my answer was still correct. In my opinion....I think you just wanted a gotcha moment on me and (forgot?) About 4 cylinders? You then got embarr***ed and tried to make it about something it wasnt to save face. Just how it appears from my armchair. Wish you the best, sorry for not responding kindly to your failed attempt at a gotcha. I generally give back what I get from folks to a degree
  16. quickchangeV8
    quickchangeV8
    I think the OP meant the Ford Flathead V8 in his original post. No mention of 6 cyl. or Banger engines.
    clem, Budget36 and Fordors like this.
  17. seb fontana
    seb fontana
    from ct
    ^^^^ It is pretty much [almost] understood that flathead ford refers to the 32-53 v8.
    clem and Budget36 like this.
  18. oliver westlund
    oliver westlund
    Think or not he said flathead ford and pre 1945. I responded to the question historically not based on personal ***umptions. I was just trying to be a nice guy and help the fella out. Next time ill just shut up and move on. Yall are the reason this site struggles and so many greats have bowed out. Ya start drama and bickering for absolutely no reason. Twenty 8 too, his little yellow car boyfriend. Idk why I try anymore honestly
    scotts52 likes this.
  19. Fordors
    Fordors
    Stu Hilborn was mentioned by @oliver westlund as producing a flathead Ford manifold but he never did. What he ran on his engine before he developed his first injection was a unique manifold designed and made by Eddie Miller. Miller’s design used three single barrel carbs and one two barrel carburetor.
    alanp561 and oliver westlund like this.
  20. Budget36
    Budget36
    Oliver, maybe to have eliminated additional messages-etc, you should have mentioned a L6 ?
    Just my thoughts.
  21. oliver westlund
    oliver westlund
    Maybe i should have. I was just trying to help.
    Budget36 likes this.
  22. oliver westlund
    oliver westlund
    According to the book I have here he collaborated on a quad carb intake with miller. That was the basis for mentioning him
  23. hotrodA
    hotrodA
    Here is a pic. of my Alexander brochure from the 30’s which shows that the “Colonel” made more than just four banger speed parts.
    Here’s his offering for V-8 flathead which sported double downdraft Winfield carbs. One of the single runners and carb is the same as the one for his Alexander Racing OHV banger conversion, that I have.
    alanp561, scotts52, Budget36 and 2 others like this.
  24. twenty8
    twenty8
    Hold up there big guy, don't go dragging me into this. I didn't say a word.
    Someone else questioned your info this time. The smart-***ed comments are over the top............
  25. oliver westlund
    oliver westlund
    You took less than a day to hit the ol like ****on. Anywhere i go on here you are quick behind with either a negative comment or a like for the other guy big boy. Im not making smart ***ed comments, just speaking truths. I can back em up with a sad number of screen shots if you really want to deny it and play games. You are just one of those guys. You could scroll on but wherever you can you take a side against me, you dont let the opportunity p*** you by. Its really quite ridiculous and pathetic honestly. I love traditional hot rods. You love traditional hot rods. Why not just enjoy the hobby, appreciate that I enjoy the same hobby and let it go man. Take an opportunity to spread some good in the world, hell in our hobby on our forum! Im floored by how many want to bicker on here over nothing. A fella asked a question, I took a bit of my time of which I have extremely little and tried to help him out and get a bunch of grief for it. I get it, guys flick ****, on my build thread, jn response to my questions, sure thing, whatever. However when I am trying to help a guy out I cant fathom why anyone would want to take time to try and bicker over minutiae. We want more activity on here and a growing hobby, not a dying one
    scotts52 and hotrodA like this.
  26. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Certainly not the oldest, but one of the more rare setups I HAD in the middle of my flathead collecting days. Have 60 years experience with flatheads and everything is NOW for sale. Stock to hot rod —what do u need??You can call with needs —-scammers not welcome John in Texas 979-fiveninefive-73two4. IMG_2472.jpeg IMG_2473.jpeg
  27. tubman
    tubman
    Oliver : I have hit the "Like" ****on on all of you posts, just so I could have the pleasure of then hitting the "Unlike" ****on (yes, there is one).
    Nobody likes whiners.
  28. oliver westlund
    oliver westlund
    Hey tub, really stop and think about how petty, small and sad what you just said is. Youre a weird cat....you realize I would never even get notified of that right? So you dislike someone you dont even know soooo much that you go through all of that for? Self gratification? Get a life man
  29. tubman
    tubman
    It's a good thing you weren't around in the early days of the H.A.M.B.
    You would have been excoriated.
  30. Budget36
    Budget36
    This thread made an odd turn…
    scotts52 and oliver westlund like this.
