Muncie 3 speed tranny ???? Help?
Discussion in 'The Hokey Ass Message Board' started by bobbleed, Apr 5, 2004.
  1. bobbleed
    bobbleed
    from Awesome
    The RPU has a cool old muncie 3 speed. I am setting up the shifter and need some answers.
    I have it so the linkage arms point up after they are bolted onto the tranny.
    So, if I pull the rear arm back is it in 1st gear or reverse?
    I am trying to figure out what the shift pattern will be if I set it up this way. Do I want to make the arms bolt to the tranny and point down? Sometimes I get confused.....
    Thanks, Bob
  2. Bruce Lancaster
    Bruce Lancaster
    Pull lever all the way back and turn input shaft. Push lever all the way forward and turn again. One way the rear shaft will turn backwards--that's reverse.
  3. bobbleed
    bobbleed
    from Awesome
    I thought of that, but the tranny is bolted to the engine and I don't have any way to release the clutch.
    I haven't gotton to the clutch linkage yet.
  4. deuceguy
    deuceguy
    My levers point down. It goes into reverse when the lever is pulled back, so I guess that would be forward to you.
  5. Hey Bob, try getting ahold of JYD he has a 3 speed in his coupe and could tell ya where reverse is.
    DAN
  6. Bob, I'm sittin here, looking at my muncie 4 speed sitting on my bookcase. rear lever back on mine is 1st. But your reverse is where first is on a 4 speed so ...lever back with em sticking up would be your reverse.
  7. bobbleed
    bobbleed
    from Awesome
    Cool, that's what I was hoping.
    So if the lever is back, the shifter would be forward and my shift pattern will be:
    R 2
    1 3
    Right?
  8. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    post pics of it... i know its lookin titty...
  9. Paul
    Paul
    Editor
    and if it don't work turn the handle upside down with the knob at the bottom [​IMG]
    seems to me my Muncie short shaft 3 speed circa 1967 had the levers up???
    I did some searching but couldn't find any 3 speed pix..
    here's a four, but I could swore my 4 speed had the levers down?
    either way if it's wrong it's pretty easy to flip them the other way!
    Paul
  10. Hope this helps, I have a Muncie 3 speed in my truck(with a big hole in the floor so I could see everything) and the levers are pointed up on mine. I have an aftermarket shifter on the floor, and the shift pattern is:
    R 2
    1 3
    It seems to work good in my truck,Larry
    Oh, yeah the reverse arm is the rear one,closer to the tailshaft [​IMG]
  11. So if you pull the arm back it is in reverse(Pushing the shifter forward)
  12. bobbleed
    bobbleed
    from Awesome
    Perfect, that's what I wanted. This push pull stuff gets confusing..........
    Thanks, Bob
