Well muscled this ****er off a bit too much. Any idea where I can find a replacement? Or repair? 1955 Chevy 2nd Series Muncie 318 transmission
The one I have is still on the main shaft It’s yours if it survives removal Wonder if the Muncie 4 speed ones are the same Those are EZ to find Any hamb folks know?
Before Anthony goes through the work to get his gear off the shaft. Give me the tooth count and id and I will check my stock of gears Monday when back in the shop. I believe they are the same as early Muncie 4 speed and Borg Warner. Let me know. Bill
As long as it's not cracked, I'd be going to work on those damaged areas with my small needle files and clean it up. The driven gear normally doesn't engage that close to the edges of the worm anyway.
