Muncie 4 speed question
Discussion in 'The Hokey Ass Message Board' started by hopped up, Mar 26, 2010.
  1. Mr48chev
    Quality brand 80-90 gear oil is all I ever ran in any of the M-21 trans I had including the one that I ordered new in my 69 Cutl*** S.
    Putting a concoction in the trans for slicker shifting when racing or for extreme cold conditions may work but
    Oldschool, there is a ton of info on Muncie M-21 / M22 Id on the net. A google search brings up more info than a guy wants to read.
    here is one example which is pretty straightforward http://www.yearone.com/updatedsinglepages/Id_info/muncie.asp
  2. Fitzworld
    Fitzworld
    Since hopped up used motor oil (10weight at that) instead of the recommended 90w, it would seem that there is only two possible outcomes. 1. Replace the 10 weight with the proper 90w and if that doesn't rectify the situation. 2. Replace the synchronizes, bearings, bushings, shims and the small parts kit.
    Good luck
  3. Buck Sharp
    Buck Sharp
    from nebraska
  4. lippy
    lippy
    from Ks
    My opinion, use 80-90wt and check that clutch adjustment. Sounds like the clutch is hanging a little, not disengaging completely, Lippy
