Technical Muncie M20 for dummies
Discussion in 'Traditional Hot Rods' started by Eth727, Oct 15, 2024.
  1. Eth727
    Eth727
    Hey guys so I just bought a Muncie 4 speed M20. I don’t have a clue about these things. The guy I bought it from said it came off a Pontiac and that’s all he knows. I have a 3 speed column shift manual 1963 impala that had a Saginaw in it. I know enough about that ****** since I removed it and opened the inspection cover. So now that I’ve got this 4 speed M20 muncie sitting and waiting to be installed what do I need to do to get acquainted with it? The previous owner did open the inspection cover to take photos of the inside however it was reinstalled with the shift forks in the correct positions.
    So I’m the dummy . How do I know if this ****** is good to go? What should I do next? I plan on putting this in my ‘63 impala in the next couple weeks when I get all the stuff to properly install it.
    Thanks
  2. SS327
    SS327
    I would talk to the guys at Medtronic’s and get a bearing and syncro kit for it and do those and a good inspection at a minimum.
    SilverJimmy, ydopen and Mr48chev like this.
  3. Mr48chev
    First question, did it come with a decent shifter? A new Hurst compe***ion plus and linkage and correct shift handle won't leave much for a beer and a burger out of 800 bucks if you can get it for that.
    brigrat, ydopen, seb fontana and 3 others like this.
  4. Happydaze
    Happydaze
    Learn from the master. Check out gearboxvideo on YouTube. You might be some time! Buy Paul's books too.
    Chris
  5. 427 sleeper
    427 sleeper
    If you believe the pictures you were given, fill it with gear lube and install it. If it doesn't shift for ****, pops out of gear, growl's or howl's like a banshee, it's time for a rebuild. At the minimum, I'd reseal the speedo bullet and replace the rear seal, just incase it is good. Then you can see if the counter shaft is leaking in the front of the case.
  6. chevy57dude
    chevy57dude
    The all important tailshaft bushing is inexpensive and keeps your driveshaft from wobbling and tearing up the seal. Got any pics of the inside when it was open?
  7. bobss396
    bobss396
    I bought an M20 here. The pictures looked good. Opened it up when I got it home. Innards looked fresh. New synchros, etc.
    So I put it in my car. I already had a shifter for it. It shifted well. I glossed over the fact that yhe countershaft pin was recessed quite a bit and it leaked.
    Ultimately I broke it and I had a good manual guy go through it. It needed some new parts and it was modified for a 1" pin and a 2.52 1st gear. The builder said it was garbaged together and was surprised I said it shifted so well.
    Lesson learned about used Muncies. I would buy a new one before another "good" used one. While yours is out, it should be gone through. All told I am into mine for around $1400.
    SS327 likes this.
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    Haven't done it for a while , but I made good side money starting in the late 60's " Frankensteining" muncies together out of used parts , bushing cases , mixing & matching parts, welding ears back on , at the rate guys broke them back then , it was a good gig . With a little effort , even factory shifters could be " tuned up" to work really well , I gotta admit ,I always had a thing for the reverse lock out finger hooks shifters . With the quality Italian gears available now , muncies can be rebuilt reasonably , there was a time when parts were scarce ,now they're pretty easy to source .
  9. joel
    joel
    Early 4 speeds are not to be feared, however I would dissemble and thoroughly inspect and replace warn parts. The cluster shaft can be worn along with the thrust washer. The synchro teeth on the first through fourth gears can be worn badly or missing and even with new br*** blocker rings, will not work well.
    Definitely find a good Hurst shifter. They also can be dis***embled, cleaned and re-lubed . The shift rods kit with correct trans levers is important and new lever bronze bushings are required.
    SS327 likes this.
  10. Eth727
    Eth727
    It has a hurst shifter and linkage minus the knob. That’s part of the reason why I got it. If I remove the cover without it being in neutral how do I get it closed back up?
    saltracer219 likes this.
  11. 427 sleeper
    427 sleeper
    Slide everything back into the neutral position and put the cover back on.
  12. Boneyard51
    Boneyard51
    You will need a short dummy shaft to put the transmission back together. I had one made out of steel , by a friend. But you can use a wooden one . Makes ***embly way easier. Other than this putting that transmission back together is fairly easy.
    Bones
    Budget36 and Wanderlust like this.
  13. TRAVLR
    TRAVLR
    Paul Cangialosi has a great book on Muncie 4 speeds and how to rebuild them, if you are interested? Book is really detailed.
    Auto Gear in NY has hooked me up in the past with the Italian gear sets and locking sliders.
    Had to use one of their cases on a rebuild a few years ago to replace a cracked original one.
    SilverJimmy, Budget36, SS327 and 3 others like this.
  14. Happydaze
    Happydaze
    Yep, and great YouTube vids, as Gearboxvideo, mentioned above.
    Chris
  15. slowmotion
    slowmotion
    I put a Muncie M20 or 21 in '62 Impala, 3 on the tree, some years ago. I remember shortening the driveshaft by an inch or two. Just a heads up...
  16. wheelguy
    wheelguy
    I don't think you should have had to shorten the drive shaft, same length overall (???)
    2OLD2FAST likes this.
  17. TRAVLR
    TRAVLR
    The regular 3 speed in the 58-64 chevy full size cars was a short version of the muncie 318. So it would make sense if he had to shorten the driveshaft. If the OP has a Muncie 319 (overdrive) it is about the same length as a muncie m20 or m21 4speed.
    FWIW, the chevy 1/2 ton trucks up to around 1965 used the same short muncie 318.
    SS327 and slowmotion like this.
  18. saltracer219
    saltracer219
    Muncie 4 speeds have to be in second gear before the side cover can be removed or installed.
    2OLD2FAST and TRAVLR like this.
  19. Eth727
    Eth727
    Yeah I saw Paul’s book on Amazon and I’ve glanced at some of his videos. Seems kind of daunting the way he rebuilds them. Aren’t muncies supposed to be the best trannies? How can someone wreck one? A dumb*** not having oil in it?
    GlassThamesDoug likes this.
  20. SS327
    SS327
    A833 cast iron case Chrysler was the best 4 speed. Muncies, not so much.
    TRAVLR likes this.
  21. oneratfink57
    oneratfink57
    from Wisconsin
    Anybody ever fix the leaking countershaft themselves? My understanding is you need to dis***emble, and have a steel bushing installed in the case?
  22. SS327
    SS327
    Only if it is wallowed out of round do you need the case bored and a sleeve pressed in.
  23. TRAVLR
    TRAVLR
    That is the only way I know to properly fix the leak. I've never seen a steel bushing used (I guess it would work fine) I've seen bronze bushings used many times. You also need to put a bushing in the mid plate also when putting one in the main case.
    bobss396 and oneratfink57 like this.
  24. oneratfink57
    oneratfink57
    from Wisconsin
    Is there another reason it would leak? Truth be told I have one that was leaking, so I replaced it and it’s sitting under my bench. I just never got around to inspecting it further
  25. oneratfink57
    oneratfink57
    from Wisconsin
    any concerns with doing this by hand, or is it best sent to a machine shop
  26. 427 sleeper
    427 sleeper
    The countershaft location is kinda' critical, I think I'd leave it for a machine shop.
  27. TRAVLR
    TRAVLR
    Agreed 100%
    The counter gear pin needs to be parallel to the main shaft so the cluster gears are running on the main gears for normal wear. That is why the mid plate needs to have a bushing in it also. I would take the case and mid plate with the counter gear pin to a machine shop.
    oneratfink57 likes this.
  28. TRAVLR
    TRAVLR
    Muncie 4 speeds are great transmissions, but you have to remember they are around 55-60 years old now. Most, if not all have been rebuilt with other used parts.. So most of the time they have been patched together.
    If you properly rebuild one with quality parts and the driver doesn't abuse it, they are usually very reliable.
  29. bobss396
    bobss396
    Mine had the 7/8" pin. It walked backwards and it spun, dug up the mid plate like a giant lathe bit.
    So the builder I used went with new Italian gears, bored the case for the 1" pin. My old one was perfect somehow. He also used some good used parts like the mid plate, yhe reverse idler, etc. I had already replaced the side cover with one from Auto Gear.
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    Find me a vintage Muncie 4- speed case that's not wallowed out !
    oneratfink57 and 427 sleeper like this.
