Technical Muncie m20 Hurst shifter linkage
Discussion in 'The Hokey Ass Message Board' started by Hotwyr, Oct 17, 2024.
  1. Hotwyr
    Hotwyr
    I'm hopeing someone can help with a Hurst linkage question. I have an m20 muncie with the speedometer cable outlet on the driver's side. Looking for linkage part numbers or an application I can reference for linkage to clear the speedometer cable. Thanks
  2. Chucky
    Chucky
    I’ve used a 90 degree speedo cable adapter in the past on a Saginaw.
    jimmy six likes this.
  3. TRAVLR
    TRAVLR
    Hotwyr,
    The driver side speedo housing Hurst part number is 1052442 for the reverse linkage rod to clear the speedo cable if you are using a Hurst shifter with the correct mounting plate.
    The car in my avatar photo has a muncie m20 with the driver side speedo tail shaft and a Hurst compe***ion plus shifter.
    Edit: 1052442 is the lever part number, the linkage rod number is 2133404.
    I apologize for any confusion.
  4. Hotwyr
    Hotwyr
    Thanks Travlr. Just what I was hopeing to find out. Do you happen to have the numbers for the other 2 rods? My shifter is in the forward mounting holes. No room for the 90 degree adapter.
  5. TRAVLR
    TRAVLR
    The 1&2 linkage arm is part #1052440
    The 1&2 rod is # 2132438
    The 3&4 linkage arm is #1052441
    The 3&4 rod is #2132139
    If whomever needs to know what these are supposed to be for... Tell them a 64-66 Pontiac GTO,Lemans,Or Tempest with a Muncie.
    A lot of the Pontiacs used the driver side speedo housing while a lot of the Chevys had the p***enger side housings.
    I have a 64 m20 out of a Lemans and my Dad has a 65 m20 from a GTO in his 57 Bel Air.
    We did this on purpose so we could run the factory length speedo cables in our cars.
    Also understand that we are using Hurst compe***ion plus shifters in both our cars... If you are using a different style shifter body, the rod lengths might need to be different.
    Chucky likes this.
  6. Hotwyr
    Hotwyr
    Thanks once again. Just the information I needed. Questions answered.
  7. Hotwyr
    Hotwyr
    I changed out the t-5 I had in my car for the Muncie hopeing to get a little better gearing for my application. Thanks again.
