Technical Muncie pros
Discussion in 'The Hokey Ass Message Board' started by Tnee27, Jul 15, 2021.
  1. Tnee27
    Tnee27
    Picked up 63-65 m20. Pretty straight forward on the id. However, on the p***enger side below the casting number, there is roughly and faintly cast roman numeral lv (4) and v8. Anyone seen this or know what it means?
  2. squirrel
    pictures?
    Looks like the foundry did various things in that location, without seeing exactly what you're talking about, we can guess...and even seeing it, probably will still have to guess.
  3. Deuces
    Deuces
    Like he^^^^^said.... We need pictures.....;)
  4. DDDenny
    Check the cluster shaft fit in the case, should be 7/8", they are known to get loose from years of abuse, the case can be machined for a new 1" replacement shaft.
    Deuces likes this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    The case can also be machined for a bushing that allows you to re use your current ,shaft. Bearings & cluster gear..
    Deuces likes this.
  6. DDDenny
    Correct.
    2OLD2FAST and Deuces like this.
  7. Tnee27
    Tnee27
  8. squirrel
    I doubt you'll find out anything about that without talking to someone who worked on that line, 50+ years ago. Good luck!
    Deuces likes this.
  9. Tnee27
    Tnee27
    Not that important, just curious
    Deuces likes this.
  10. squirrel
    The round thing with the numbers in it is a date code. The roman numeral thing looks like it was engraved in a mold, probably a note to someone who worked there about something...and not something that would have been do***ented anywhere, most likely.
    Deuces and Joe Blow like this.
  11. Joe Blow
    Joe Blow
    Later M20's had mold pattern numbers that were faint and in that spot on the trans. Don't think they were Roman Numerals though.
