Muncie question
Discussion in 'The Hokey Ass Message Board' started by The Shocker, Jan 1, 2009.
  1. The Shocker
    The Shocker
    I did a search and didnt find the answer ,so im asking.I found a Muncie M20 cheap and thought i would buy it as a backup .The only thing is one of the 4 mounting ears has been broke off and welded back on.Is this a problem? The weld looks good and the guy told me it was used for a year or two after the repair and held up fine.I know the bolts arent what centers the trans to the bellhousing ,the flange on the trans does.I have heard of them breaking the top left ear before ,but havent heard of them being repaired with success.What do you think?
  2. aerorocket
    aerorocket
    from N.E. P.A.
    As long as the rest of the transmission is ok this is not a problem
  3. 302GMC
    302GMC
    from Idaho
    Countershaft bosses & thrust surface are known to beat out, both can be repaired.
  4. The Shocker
    The Shocker
  5. mottsrods
    mottsrods
    Ya need to pm marylandmuscle , he rebuilds alot of them and is very knowledgeable.
  6. Gearstix
    Gearstix
    Are the M2x series manual or automatic?
    I love the sound of the gears.
  7. The Shocker
    The Shocker
    Muncie's are 4 spd manuals out of 60's and 70's GM muscle cars. M20's are the small block versions with a 2.56 low and M21's are BigBlock 2.20 low .M22's are the ones called "Rock Crushers " and they were suppose to be the strongest one due to the straighter cut gears and 26 spline input shaft and turbo 400 type rear yoke.They are also the ones that make the whine that i think you are refering to .I have one in my 56 Chevy and it sounds like a gear drive.This is info off the top of my head ,so dont quote me on it ,cuz i will be corrected if im wrong ...
  8. scottybaccus
    scottybaccus
  9. scrape
    scrape
    i think you answered your own question.....
    buy it and if you dont use it ill buy it from you.....lol...
  10. 283nova
    283nova
    from spokane,wa
    muncies breaking ears off was actually pretty common.
  11. badlefihand
    badlefihand
    Muncies are not at fault,rather installer useually broke the ears off trying to pull transmission in with the bolts for the last 3/8" when pilot bearing was not lined up properly with clutch.Those that knew muncies would bump the clutch with a pry bar. A lot of muncies are welded and are no problem.
  12. fms427
    fms427
    I've broken several, welded them, and continued using in a race car. As long as the welding is strong, no problem ! I'll second the fact that it is fairly common. You can also break if you ground out the engine and trans on a curb.............:D:D
