Muncie shifter help
Discussion in 'The Hokey Ass Message Board' started by 65ssnova, Feb 10, 2013.
  1. 65ssnova
    65ssnova
    from Tulsa OK
    My 65 nova ss currently has a worn out hurst comp plus shifter that in my opinion is beyond repair, its sloppy at shifts and hangs up etc. My oem replacement shifter is on its way from cl***ic. What all do i need to do to remove the hurst shifter, i have all the linkage disconnected, does the shifter gate box unbolt from the shifter mount bracket?
  2. Hotrodbuilderny
    Hotrodbuilderny
    It should, there should be a 3/8 bolt on bottom, 7/16 bolt on top and it should come right out. 9/16 and 5/8 wrench.
  3. woodypecker
    woodypecker
    Don't throw out the shifter it can be rebuilt.
  4. 65ssnova
    65ssnova
    from Tulsa OK
    Alright thanks for the info. How much is the hurst worth needing rebuilt?
  5. Rich Rogers
    Rich Rogers
    You probably could have fixed that shifter for about 10 bucks. It sounds like it only needs a bushing kit and re-adjusting
  6. slowmotion
    slowmotion
    ^^^^ what he said. Don't toss the old one, especially if it's original to the car. A bushing kit can possibly save it.
  7. bobss396
    bobss396
    Any speed shop used to sell the kits with the steel bushings. You can probably find one online in 5 minutes and enough information to do the job yourself.
    I took a fast look and came up with this tutorial, looks like it should help you. I learned something new about setting the detent bolts!
    http://www.automedia.com/4-Speed_Shifter_Tech_Tips/ccr20060801st/1
    Bob
  8. Mr48chev
    You can also send a Compe***ion Plus shifter back to Hurst for a factory rebuild for a fee of course. http://www.hurst-shifters.com/?page_id=17
    I wouldn't get rid of it until you are positive you are happy with the oem style shifter as the originals were pretty sloppy and that is why guys almost always pulled them out and replaced them with the Hurst shifter.
  9. rugger
    rugger
    from Colorado
    Thanks for the link. I need to adjust mine the next time it is out of the car.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
  11. saltflats
    saltflats
    from Missouri
    I though that was when thay started to work realy good after new bushings and an adjustment.
  12. 40FordGuy
    40FordGuy
    What all the other guys said !
    4TTRUK
  13. propwash
    propwash
    from Las Vegas
    You don't adjust them when they're out of the car. You adjust them when they are mounted solidly and hooked up to the shifter arms on the fork shafts and in neutral. Find a Phillips screwdriver or an allen wrench that fits snugly into the alignment hole in the side of the main housing of the shifter. If it won't go in all the way, you'll have to disconnect the shift rods from the fork levers. Let the rods hang down and jiggle the shifter levers back and forth until the alignment tool (your Phillips or Allen wrench) will go all the way through the shifter unit. Once you have the shift arms aligned, then take each rod in hand and re-attach them to the fork shafts, screwing them in or out of the Hurst shift levers until they will drop into the fork lever holes without forcing them. Start with the inside rod first and work your way to the outside one. Once you have them lined up and bolted up, then set your stop screws (if present) and the double-nuts to ensure the adjustments stay as permanent as possible. This is AFTER you've replaced all the bushings and snap rings with new. I always used the carbon steel bushings, plastic wears out too quickly. Hope that's descriptive enough, and if I've missed a step or mislabeled a part, I'm sure the Mensa members will step in and straighten us out.
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    Your Hurst shifter is much better than the Muncie shifters........guys who were serious back then pulled out the Muncies and put a real Hurst in their cars.
    As the guys said, Hursts are easy to rebush and adjust and are pretty much bulletproof. Mine is over 25 years old and shifts like brand new.
    Don
  15. Torkwrench
    Torkwrench
  16. rugger
    rugger
    from Colorado
    Thanks for those.
    Sorry that I was not more clear. I can't work on the shifter/rods while the transmission is in the car. I have to pull it while attached to the engine. I'm building a new tubular subframe, so the next time the engine is out to install the subframe I will take a look at the shifter. It may be an original Muncie unit. Meanwhile, I have to decide if I'll replace the 4 speed with a 6. I'm tired of being slow on the straights due to limited top end.
  17. lht
    lht
    if you pull drive shaft drop cross member ****** will swing down enough to work on might have to pull dist or cap because it may hit firewall
