Technical Muncie Tear Down, What’s Junk, What Can Be Reused?
Discussion in 'The Hokey Ass Message Board' started by lewk, Mar 11, 2023.
  1. lumpy 63
    lumpy 63
    I have built several , Never had any front bearing issues.As far as I remember they all take the same bearing.... Thats frustrating for sure.
    SS327 and lewk like this.
  2. DDDenny
    I think Paul Cangialosi (fivespeeds.com) did a tutorial on the misfits on the early Muncies.
  3. justpassinthru
    justpassinthru
    Just curious, it looks like you have a mix of Torque Lock (back cut) and OE style (straight cut) gears. What sliders are you using?
    Bill
  4. bobss396
    bobss396
  5. It’s not your fault exactly,,,,that’s a different bearing part number,,,,which explains why it is a different bearing and won’t fit .
    The Reputable Vendor should have caught that .
    Tommy
  6. lewk
    lewk
    from Mt
    I watched the majority of his stuff on YouTube and it’s been super helpful. I’m not sure if I watched that particular one, but I know 63s have a smaller diameter bearing on the Muncies, T10s and 3 speeds. I dealt with that on my 63 Impala when I went from 3 to 4 speed.
    This is a low buck endeavor and I’m using what I come up with. I have an Italian 3rd mixed with Asian gears and an OG cluster gear. I’m using torque lock sliders. I hope 3rd doesn’t give me any grief. I know this isn’t best practice, but I’m really focused on driving the car this summer.
    Gotta dust your shoulders off and keep going.
    I should have put new next to old and caught it. I usually do. The vendor should have know too. Oh well. I should see a new bearing from a different vendor, Paul, who confirmed his are the correct width, on Tuesday. I should have ordered from him in the first place!
    Desoto291Hemi likes this.
  7. SS327
    SS327
    So, driving by July?
  8. lewk
    lewk
    from Mt
    If it’s not, it will all be because OF THIS BEARING
    bobss396, 427 sleeper and SS327 like this.
  9. SS327
    SS327
    You’ll get it, Patience Gr***hopper!
  10. bobss396
    bobss396
    With my background in machined parts, I tend to measure anything and everything even as a sanity check. I measured up my old axle bearings while they were still installed, did my research on bearing sizes so there would be no surprises. I brought my caliper to the shop that did my press work, before I plunked my cash down.
    Deuces and lewk like this.
  11. Beanscoot
    Beanscoot
    Despite the age of these transmissions, the bearings are typically metric. Measure up the old bearing or pieces it fits and look up the bearing number online from these dimensions, or post the dimensions here.
    There's nothing special about the bearings in these transmissions, you can just get a quality bearing of the correct standard industrial number (unshielded), probably locally, and use it.
    The specialty suppliers just do this anyway and mark up the part.
    lewk likes this.
  12. lewk
    lewk
    from Mt
    80mm OD, 35mm ID, 17mm W for the correct bearing. Unsheilded with a snap ring groove. The incorrect one is 21mm wide. They seem to be medium duty bearings. I fooled around on the Motion Industries website a little, but their prices were high enough that I didn’t bother calling the rep I use through work. Maybe he could have worked his magic for me, but I didn’t want to call in a favor for a personal project. I just ordered one through 5speed Paul.
    bobss396, SS327 and Deuces like this.
  13. lewk
    lewk
    from Mt
    I got the new gaskets and correct bearing mid week and got everything ***embled. Things went pretty well aside from a finicky bearing retainer. It would fit great dry, but as soon as I put sealant on things, it would make a rubbing sound. I finally got it happy after about 6 cycles of dis***embly/re***embly.
    I wound up reusing the case, tail shaft housing, side cover, mainshaft, and ***orted little stuff like shift levers and fasteners.
    enloe, bobss396, SS327 and 3 others like this.
