Mustang II front ends.
Discussion in 'The Hokey Ass Message Board' started by Ole Pork, Sep 5, 2006.
  1. Ole Pork
    Ole Pork
    Hey Guys, Thanx for the w/s info. What all does it entail to put a Mustang II front end on '49-
    '52 chevs? Do you have to stub it, or just change cross member, spindles, etc.? Pork
  2. Sik Shifter
    Sik Shifter
    Pork... shouldn't be anything more then hackin out the old cross member and stickin in a new one with what ever kinda suspension you wanna run (air, coil overs, etc) check out http://http://www.fatmanfab.com/06page4.htm those guys cover dang near any kinda application out there. Fatman Fabrications phone number is 704-545-0369.... hope that helps some... sik
  3. Ole Pork
    Ole Pork
    Thanx, w/do....Pork
  4. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    im an alliance vender fatman dealer
  5. kropduster
    kropduster
    i've heard rumors about the fatman (and others) tube style a-arms giving away....do a search. this has been covered many times. not trying to discourage, just a heads up brother
  6. This site is a must for anyone with a 49-54 Chevy http://50chevy.com/
    It'll answer a lot of your questions, as will the old threads here on the HAMB.
    Bryan
  7. old beet
    old beet
    RB's Obsolete has a bolt in kit.........OLDBEET
  8. Sik Shifter
    Sik Shifter
    kropduster... heard the samething... but they do offer one piece stainless arms now, thats what i would probably run, imagine those would be purdy strong.
  9. old beet
    old beet
    I have stock Ford arms on the F-1...Big block Ford...135K miles..strong enough for me!....OLDBEET
  10. AZAV8
    AZAV8
    from Tucson, AZ
    Porky4,
    On Mustang II frontends, read this thread started by Elpolacko first.
    http://www.jalopyjournal.com/forum/showthread.php?t=115209
    Some manufacturers have some problems with their kits. If you have any other questions talk to Steve directly as he is very knowledgable about all types of ch***is suspension systems.
  11. AllSteel34
    AllSteel34
    I'm running the stock Ford arms on my '49 Chevy P/U and my old man is using them on his '36 Ford P/U. Both have Chevy small blocks and no suspension problems thus far.
    Chris
  12. 49ratfink
    49ratfink
    the original suspension drops out in one piece. just drill and punch out the rivets.
    MII's had a problem with certain bolts breaking. never heard of the tubular arms breaking, though I could have missed it.
    it is a fairly easy thing to do... measure and square everything twice... tack it in.. install the suspension at ride height without the springs...measure again and put a fender on and see where the tire sits in the fenderwell.
    as a matter of fact.. see where the tires are with the original suspension before you even start... maybe you want to adjust it a bit.
    I like the ultra low for 49 - 52 chevys
  13. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    thats how rumors get started
  14. zman
    zman
    from Garner, NC
  15. 53sled
    53sled
    from KCMO
    For a little extra, you could have corvette parts.
    http://www.progressiveautomotive.com/sweet.htm
    If I were doing this, I'd think real hard about spending a few extra bucks.
  16. 50chevy
    50chevy
  17. we have a 51 wagon with the Ch***is Engineering kit in it. It has pluses and minues - like all I would guess. Biggest so far is the way you can only use a manual rack. We have done cars with both manual and power. Power is way better.
  18. speedaddict
    speedaddict
    from Austin, Tx
  19. zman
    zman
    from Garner, NC
    Actually no... all the problems have not been addressed... Some kits from some of the manufacturers have had updates others have not. I believe TCI has addressed more of the issues than the others... Maybe reading the full thread would help, someone just installed a Fatman kit a month ago and som eof th issues are still present.
