Mustang II front suspension?
Discussion in 'The Hokey Ass Message Board' started by 56townsedan, May 23, 2005.
  1. Need help on adding a Mustang II front suspension to my '56 Fairlane Town Sedan. What kits would I use and how to do it. It's probably easy for you guys, but I have never done one and I want to do it myself.
    Thanks
  2. jalopy43
    jalopy43
    That's a heavy car for a MII. What is wrong with the stock front end?? Sparky:D
  3. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    If you are set on a MII, I can suggest FatMan from experience. Easy to install and it rides great.........
    Have you thought about doing a complete rebuild and upgrading to disk and dual master cylinder. A rebuild of all the rubber compoments does wonders adding disk and potentially a sway bar will make it stop and handle a whole lot better.........
  4. i'm not sure who all makes mustang ll crossmember kits for `56 ford , if any....Fatman Fabrications makes a complete frame stub , which be some major work....their catalog states the original frame design doesn't allow for the easy installation
    i agree jalopy43 , keep the original front suspension.....kits for disc brakes , power steering , and drop spindles/springs are available and can be done with simple tools by the average guy
    http://www.fatmanfab.com/
  5. Thanks guys. This idea sounds better than doing the whole MII thing.
  6. Try these guys, http://www.jamcosuspension.com/ Been around for some time now. May not be the cheapest solution but may be the easiest to do.
    Also a company called Gearhead Cruiser products has been advertising in Rod & Custom. Mixed results so far, one very happy and the other not so. But they do offer a bolt in Saginaw 605 conversion!
    The night prowler also offers dropped spindles and disc brake conversions for your car.
    Other options include using the Ford Granada/Lincoln Versaille's spindles with some minor modifications to achieve disc brakes and a bit of drop.
    That said I like Mustang II suspensions in general but there is a limmit as to what they fit best under.
