mustang tank in a truck...how to my way
Discussion in 'The Hokey Ass Message Board' started by brewsir, Jul 21, 2007.
  1. brewsir
    brewsir
    I just got a days work in on my ol 58 ford parts chaser and took a few pics.
    It started with a aluminum fuel cell and a very rusty bed floor. I got a guy to swap me a mustang tank...I think its a 69-ish but the perimeter size is probably the same as a 65-66.
    I cut out the bed floor and cut out some crossmembers that were in the way. Then I trimmed a little (about 1/2") on each side top inner framerails so the tank can slide right between the rails....this is when I realized the rails had pulled together about half an inch so I spread the rails and installed a 2x3 square tube crossmember...this was put in where the rear flange of the tank will sit on it.
    My framerails angled up toward the front and I wanted the tank to sit flat,so I eyeballed a pie wedge cut on the frame and cut and welded it flat,then added a small filler piece of steel where the gap was left.lastly I added a front angle iron piece for support of the front of the tank.
    I have about 4 hours in it so far...next is a small step notch so I can do flip on the rearend and get this thing down another 6 inches!
  2. brewsir
    brewsir
    here's the framework and how it sits today. I still want to figure out a fill tube that's not in the middle of the bed floor.
  3. buick 58
    buick 58
    my buddy did this on his 51 f 100. he has a oak floor bed and used one of those flush mount motorcycle gas caps. it works out really slick
  4. brewsir
    brewsir
    It looks like I can run a tube over to the corner where the stakepocket was and use a small stainless filler from the boat store...just waiting for Tuesday for the place to open. They have some very cool stuff that can be readily adapted.
  5. Roothawg
    Roothawg
    Good idea man.
