Projects My 1931 Model A build thread
Discussion in 'The Hokey Ass Message Board' started by clockwork31, Sep 24, 2013.
  1. clockwork31
    clockwork31
    Here's the build thread of my first hot rod, it's been 3 years since I found my 31 model A in a barn near Hawksburry,Ontario, I've been working on it since then, with a young family I knew it would be a part time project and my plan was to take it out this summer but I moved and had too much work to do on the house. So I hope it will hit the road next summer! I will post a lot of pics! Enjoi!
    Specs:
    2x3 tubing frame
    model A front crossmember
    Lucky 7 complete front end
    chanelled 5" in front, 3" rear
    3.5" chop
    the engine will be a 1962, 327 SBC 300hp (NOT from a VETTE:p)
    offy intake and triple deuce holley carbs
    4 speed saginaw
    lake headers from Matt @ gear drive speed and custom
    18" Brockman mellowtone mufflers
    GM blazer 3.73 diff (might change for 3.42)
    Roof skin fro a early 90 cherokee
    Seat from 90s sidekick
    had 15" WWW Coker tires and changed for 16" gennie wheels and Excelsior Radials
      120.5 KB
      68.8 KB
      81.6 KB
      65.8 KB
      64.5 KB
      74.5 KB
      100.2 KB
  2. clockwork31
    clockwork31
    more
      52.1 KB
      77.2 KB
      58.9 KB
      392.6 KB
      456.3 KB
      383.8 KB
      344 KB
  3. clockwork31
    clockwork31
    ...more
      339.2 KB
      349.1 KB
      278.4 KB
      332.3 KB
      330.9 KB
      299.1 KB
      334.1 KB
  4. clockwork31
    clockwork31
    ....more
      382 KB
      321.7 KB
      315.3 KB
      354.3 KB
      339.9 KB
      326.2 KB
      360.8 KB
  5. clockwork31
    clockwork31
    .....more
      345.9 KB
      314.6 KB
      355.1 KB
      313.4 KB
      269.1 KB
      330.1 KB
      289 KB
  6. HOTRODPRIMER
    HOTRODPRIMER
    Looks like you have made some good progress. HRP
  7. clockwork31
    clockwork31
    ......more
      222.2 KB
      242.4 KB
      330.5 KB
      284.3 KB
      362.5 KB
      241.2 KB
      285.4 KB
  8. clockwork31
    clockwork31
    out for sandblast and changed my mind for the tires!
      388.3 KB
      288.6 KB
      236.2 KB
      195.4 KB
      281.7 KB
      196.2 KB
      243.3 KB
  9. clockwork31
    clockwork31
    that's about it for now, last pic is from last friday.
      260.2 KB
      128.6 KB
      231.1 KB
      291.3 KB
      487.8 KB
      77.6 KB
      228.7 KB
  10. hotroddonnie
    hotroddonnie
    Nice build! Friend of mine used the roof off a Volvo wagon no problem. I'll be 3 years as well and I'm about 2 weeks till I take mine out for the first time.
  11. bcarlson
    bcarlson
    Very nice! That'll make a lot of memories for your kids!
    -Ben
    http://www.drillist.com - Hot Rod cl***ifieds done right.
  12. clockwork31
    clockwork31
    thanks man, bad*** '57! Wow!
  13. clockwork31
    clockwork31
    thanks Ben, the kids are always around me when it comes to put new parts on the hot rod! they love it
  14. BRAINS!
    BRAINS!
    nice work man
    keep it up!
  15. clockwork31
    clockwork31
    Finally, after a long winter here's a little update on the project, some repair done to the steering wheel and I'm planning to slide the engine in next week end.
  16. Jersey Joe 67
    Jersey Joe 67
    from J Town
    Looking pretty sweet man.
  17. Bruskie
    Bruskie
    If your body is not bolted down yet you should turn your shock bolts around because you wont be able to get them out to get your shocks off. Seen it happen before.
  18. clockwork31
    clockwork31
    Yes I already did, I figured it out before fixing the body to the frame, thanks!
  19. djust
    djust
    from Oklahoma
    Nice build going there clockwork.
    Your roof looks alot like mine except your sheetmetal skills are better.
  20. rawcjw19
    rawcjw19
    I haven' t checked on you in awhile. Looks Great nice job!
  21. scrap metal 48
    scrap metal 48
    Sedan looks good.. Has a great profile...
  22. rawcjw19
    rawcjw19
    I couldn't tell from your pics, did you put a wood header back in, or wood around the roof opening? I was wondering if I could leave that out with the steel roof
  23. clockwork31
    clockwork31
    No wood at all but I left the braces that were already sticked to the roof skin plus the steel one originally in the sedan, I'll use these to fix the finition panels later. As for the header I plan to put a piece of wood.
  24. clockwork31
    clockwork31
    here's a little update, engine is in, steering is done, brake lines and insulation almost finish.
  25. rawcjw19
    rawcjw19
    looking great! man you are close to driving.
  26. gecko54
    gecko54
    from Sumner, WA
    Looks cool. I have three quick questions. 1) did you end up with swinging pedals? I see both swinging and through the floor in the pictures. 2) Did you find 5 lug hole 16" gennies or are those 10 hole? and last, where is your fuel tank?
  27. clockwork31
    clockwork31
    1) Yes I did end up with swing pedals, it gave me about 5 inches more of legs space and I needed it, my knees were touching the steering wheel, I had not enough space under the car for the underfloor unit it was to tight with the clutch slave.
    2)No they're 10 holes gennie from Wheel vintique.
    3)Tank is behind the rear seat, not installed yet.
  28. rawcjw19
    rawcjw19
    Let me know how the brakes work when you get her going I may want to switch to those pedals also. Can we see a pic of the tank when you get it mounted? Thanks for sharing all your info, much appreciated
  29. Nice car, reminds me of my last two years. I use a master cyl under the floor, but i'm running an automatic so with no clutch pedal i have more room. fuel tank is also behind the rear seat.
  30. gecko54
    gecko54
    from Sumner, WA
    Thanks for the reply. I'm planning on a tank behind the seat in my sedan project as well, thats why I asked. I will be running caps as well but those ten hole wheels just bug me for some reason.
