Projects My 1950 Buick Sedanette rebuild officially kicks off!
Discussion in 'The Hokey Ass Message Board' started by 1950_Buick, Jun 13, 2014.
  1. 1950_Buick
    1950_Buick
    Looks great, but you can always make it better!
    10259470_10152844639074358_4533676293402673826_n.jpg 10341474_10152844632204358_8743346857250377898_n-2.jpg
  2. 1950_Buick
    1950_Buick
    Block is going to the machinists this weekend.
    The donor block and crank is from a '04 Suburban.
    5.3, boring out to a 5.7.
  3. 1950_Buick
    1950_Buick
    Rods and Pistons going into the engine.
  4. rockable
    rockable
    Subscribed. Good luck on your journey. I look forward to the suspension work. Collecting ideas for my '49.
  5. ausbuick
    ausbuick
    I'll be watching this one.
  6. 1950_Buick
    1950_Buick
    Well after sending the block away to the machinists, we finally have it back - they are super busy and have a large backlog. We sent it to Thunder Works Engines, who specialize in building High Performance engines. http://www.thunderworksengines.com
    The engine is now a 383 ci. Thunder Works decked and O ringed the block, bored & honed the cylinders, align bored the block, assembled the bearings, rods, pistons. Installed a new 4" stroke forged crank, new oil pump and balanced the engine.
    1002528_10153210000432656_2077753877808521939_n.jpg 1525677_10153210000487656_6855343576992256534_n.jpg 10636031_10153210000542656_1828737855316251610_n.jpg 10641225_10153210000627656_7386227733311679694_n.jpg
    ausbuick likes this.
  7. I used to catch a ride home from high school in one that looked just like that. Wonder if it's the same one. L.A., Ca.
  8. 1950_Buick
    1950_Buick
    The car wasn't in LA back then but if you said Fresno or Marin County, than it just might be
  9. 1950_Buick
    1950_Buick
    The Heads for the Engine - PRC As-Cast 225cc LS1/LS2 Cathedral Heads from "Texas Speed and Performance" http://www.texas-speed.com
    photo 1-3.JPG photo 3-3.JPG photo 2-4.JPG photo-92.JPG photo 2-3.JPG photo 1-5.JPG
  10. ausbuick
    ausbuick
    Engine porn right there!!!!
    Check out my 49 Buick sedanette build
    1950_Buick likes this.
  11. mgtstumpy
    mgtstumpy
  12. dniemi
    dniemi
    Subscribed, I love those cars.
  13. 1950_Buick
    1950_Buick
    Picked this LS1 LS6 Holley Weiand Cathedral Port High Flow Intake w/ FAST Billet Rails, 36lb Injectors, & Stock Throttle Body off of Ebay. Needs a little bit of a clean up. Will be replacing the injectors with higher lb ones and selling the 36 lb ones.
  14. Hot Rod Cowboy
    Hot Rod Cowboy
    Great looking car! Just a heads up though, you are going to get hammered here for that ls engine. I am personally a fan, but they don't really belong on a traditional forum and I'd hate to see this thread get deleted. Focus more on the traditional aspects of the build and maybe you will be ok. Can't wait to see the rest of the build.
  15. oldwood
    oldwood
    from arkansas
    Eight in a row .... I've had a couple '50 Buick's and will own another someday. Nice car!!!
  16. 1950_Buick
    1950_Buick
    Thanks, but I'm unsure why it would get "hammered" as it's tagged as "customs", which by definition is what this is, i.e. upgrading the engine as well as the whole car!?
    I do plan to cover the whole build in detail, it's just right now I'm working on the drive line as I get ready to take the body off the frame.
  17. 1950_Buick
    1950_Buick
    just to mix up some of the engine build pics, here's some previous work we did to convert the non existent front drum brakes over to disc brakes... used the scare bird kit that you can get off of ebay.
    photo-57-3.JPG photo-56-2.JPG photo-55-2.JPG photo-54-2.JPG photo-53-2.JPG photo-58-2.JPG photo-52-2.JPG
  18. F.C.Fury
    F.C.Fury
    You'll get hammered because its not a traditional engine. This site is for traditional builds only i.e. built like it would have been before 1965.
  19. F.C.Fury
    F.C.Fury
    Cool car by the way!
  20. 1950_Buick
    1950_Buick
    sorry newbie here, where do you suggest i put the thread not to offend anyone? Clearly my definition of what a custom is, is different than what's expected here, i.e. mild to wild - (i will be completely customizing the car from the frame up). I did change the sub heading to projects, but I'm guessing this might still not work!? Appreciate any suggestions.
  21. F.C.Fury
    F.C.Fury
    Your definition of custom is not the issue. The term custom can be applied to a lot of things, it just needs to be a traditional custom. Where you posted is fine but you need to either change your power plant or just not post much about the engine itself and focus this thread on the rest of the car (assuming that it will be traditional styled). I'm kinda of a newbe myself as far as post counts go but I've been a lurker for a few years now so I have some knowledge but don't have all the answers.
  22. 1950_Buick
    1950_Buick
  23. F.C.Fury
    F.C.Fury
    Oh and stuff like the modern disk brakes I don't think is a big deal just the motor is the main issue.
  24. 1950_Buick
    1950_Buick
    I thought I would post some history on this car. I bought it May 2013 from the daughter of the 2nd owner. Apart from the first owner and first year, this car has been in California since then (Fresno then Marin County). Prior to that I think it was in NC. So it wasn't subject to the ravages of salted roads.
    Here's one of the first pink slips for this car from 1956.
  25. 1950_Buick
    1950_Buick
    By 1982 this car needed some TLC and the first restoration work was begun by the owner.
    Here are some pics and notes/invoices for the body/paint/rechroming work.
    1982 Buick 1.jpg 1982 Buick 2.jpg 1982 Buick 3.jpg Paint and Bodywork Cost Sheet.jpg Chrome Plating Cost Sheet.jpg Electoforming 1.jpg Electro Chroming 2.jpg
  26. 1950_Buick
    1950_Buick
    The first movie this car was in was "Shadow of a Doubt" a made for TV movie released in 1991. Here are some of the articles on the movie.
    Here is the film promo material...
  27. 1950_Buick
    1950_Buick
    Pics of the car on the set of "Shadow of a Doubt"
  28. 1950_Buick
    1950_Buick
    Pics of the owner the Buick with the lead actors from "Shadow of a Doubt"
  29. 1950_Buick
    1950_Buick
    His commission checks for the use of the Buick in the movie...
  30. 1950_Buick
    1950_Buick
    The next movie the Buick appeared in is "Inventing the Abbotts" (1996)
