Projects my '29 AV8 roadster
Discussion in 'Traditional Hot Rods' started by 2345.coupe, May 6, 2019.
  1. vtwhead
    vtwhead
    Sat. 4 me. I will look you up
  2. dsiddons
    dsiddons
    from Indiana
  3. cut 16'' off the radius rods, then made a cut just before the rear mounting plate at the factory joint. Then cut the front mounting joint eye off at the factory joint and mounted the eye to the front of the shortened radius rod...the front of the radius rods will be mounted to a plate I purchased at HRW hot rod works...... P1040426.JPG P1040427.JPG P1040428.JPG P1040429.JPG P1040430.JPG P1040431.JPG
    also installed the master cylinder with some 10 lb residual valves.....
    1947knuck, JUNK ROD and Stogy like this.
  4. Stogy
    Stogy
    Great build @2345.coupe...you got the old looking real good there right down to the tires...;)
  5. mikec4193
    mikec4193
    Just found this build thread....I am South of you...right off I 87...love to see this stuff getting built in the Northeast...
    thanks for posting on here...I am following along...
    MikeC
  6. thanks Stogy.....
    Stogy likes this.
  7. thanks MikeC....stop in if your in my neck of the woods....
    Stogy likes this.
  8. P1040466.JPG P1040467.JPG P1040468.JPG P1040469.JPG P1040470.JPG P1040471.JPG P1040472.JPG
    mocking the hood and grille up, drag link modified and installed 90 and 90, parallel to the bones. Jump on the front of the frame and the model T steering wheel doesn't budge...... ie ,no bump steer. Next chop the windshield!
  9. vtwhead
    vtwhead
    lookin' good!
  10. thanks vtwhead
    ferus88 likes this.
  11. since I'm not a big fan of paint, I'm coating my 28 roadster boiled linseed oil finish.jpg 28 roadster boiled linseed oil finish1.jpg roadster bare metal body with boiled linseed oil.....the cowl isn't treated yet.....
  12. vtwhead
    vtwhead
    Never heard of that before....what is the down side to that treatment if any?
  13. don't know of any down side yet. Lots of "old" model a guys use it. High voltage electrical wire towers are coated with it to prevent rusting.
  14. JUNK ROD
    JUNK ROD
    Sweet rod! I'll be following your thread!
    Thanks for sharing
  15. thanks JUNK ROD
    Stogy and JUNK ROD like this.
  16. 47streetrodder
    47streetrodder
    Will the rear radius arms be adequate to secure the rear end or will you be adding a torque arm?
  17. she's only 125 hp ,so I'm just going with the radius rods. She's not a tire burner......
    1947knuck likes this.
  18. ct1932ford
    ct1932ford
  19. Stogy
    Stogy
    Just don't use Asbestos for muffler packing...I'll never forget this thrifty Hotrodder running Lakes style pipes at a cruise maybe 4 yrs ago...when I asked him how he baffled them he said he packed them up with Asbestos he had acquired years ago...:eek:
    Moral of the story is I hope your Old School Remedy doesn't harm you...at the least it might lube up the Ole Left Arm on the sill...:D
    brady1929 likes this.
  20. thanks ct1932ford
    good advice Stogy
    Stogy likes this.
  21. vtwhead
    vtwhead
    Nice job on the exhaust. Always takes a bunch of thought and a lot of time. Is that a new drive shaft?
    lothiandon1940 and Stogy like this.
  22. thanks vtwhead......yes its a custom made drive shaft...www.southwestspeed.com...479-646-6988 I think it was around $189
    1947knuck and Stogy like this.
  23. vtwhead
    vtwhead
    I used to get custom DS's from a one man shop out in AZ. Quality product but he will not ship anymore so I have been making my own like back in the day when that was the thing we did. Not that I need many anymore as things have slowed down now in my senior days.:rolleyes:
    Stogy likes this.
