Projects My 30 Sport Coupe Banger First Time Build
Discussion in 'Traditional Hot Rods' started by fadingfastsd, May 22, 2023.
  1. HomemadeHardtop57
    HomemadeHardtop57
    Here's the top from a 32 sport coupe I did recently. feel free to message me if you need any help
    20230514_190953.jpg 20230514_191002.jpg 20230514_190947.jpg 20230514_163412.jpg
    Tim, 1stGrumpy, fadingfastsd and 2 others like this.
  2. 282doorUK
    282doorUK
    That's very impressive, the smooth black top and the skirts really help to give it a quality look,
  3. fadingfastsd
    fadingfastsd
    Wow, that is killer. Really nice job. I wouldn't mind some ideas on how to the do the rear window, will get getting around to that soon. Will message you. Thanks!
    HomemadeHardtop57 likes this.
  4. the oil soup
    the oil soup
    from Tucson,AZ
    I really like this sport coupe also but thought the top appears like a roadster so the door should mimic the roadster window opening, it helps to soften the look. Has this been done ? 7EE733D4-7952-4CDE-B121-DA5519C90AF0.jpeg
    Tim and 282doorUK like this.
  5. 282doorUK
    282doorUK
    It has almost, I've seen a pic of a turquoise one on the HAMB, full fendered if I remember right, with the door tops rounded off but not such a large radius as that. I usually save any pics like that but for some reason I didn't, been searching but can't find it again.
  6. fadingfastsd
    fadingfastsd
    Been a little while, been making some more progress.
    Finished securing the top the supports, and cut in a back window. Used safety wire to keep it tensioned. Top will work for now, but I plan on building a better version with what I learned from this one this summer.
    Put on scalded dog finned side plates, and modified a 4 barrel carb air cleaner to fit the weber.
    Replumbed my fuel line:
    Added a tach
    And installed window gl*** and regulators. Still need to make some door panels.
    Also resealed the motor, new gaskets everywhere. Was sick of the oil leaks from the 20 year old gaskets on it.
    Still trying to figure out a new exhaust for it that will fit with the weber intake. Any suggestions?
    Tim, 282doorUK and Jeff34 like this.
  7. fadingfastsd
    fadingfastsd
    Been working on some old motorcycle projects so haven't done a ton lately on the car. Put the hood on and made up some hood straps from leather belts and rivets, and been working on some striping. About ready to get on the road for spring.
  8. winduptoy
    winduptoy
  9. fadingfastsd
    fadingfastsd
    Finished up some door panels. I also made some kick panels that match, forgot to take a picture. She's about ready to hit the road!
    winduptoy and Zax like this.
  10. nutrocker
    nutrocker
    This is mine. Sport coupe with a heavy chop
    Jim the Sweep, Tim, burl and 4 others like this.
  11. Just found your thread, I like what you've done. I really enjoyed building my full fendered '29 Tudor banger a few years back. My engine was pretty much like yours but I went with a later transmission, it made it a lot easier to drive. Keep up the good work, I'm gonna follow along...
    winduptoy likes this.
  12. fadingfastsd
    fadingfastsd
    Right on, thanks! What transmission did you use? I wouldn't mind swapping at some point. This car has always had a clutch chatter in 1st gear, I need to tear into that at some point, but no rush as its not getting any worse. I'll keep posting as I keep messing with this thing!
    Ordering up a Reds header now, will be making a new exhaust for it soon.
    winduptoy and roadwarrior84 like this.
  13. I used a '38 transmission with late '39 gears, I also had a lightened flywheel and it was drilled for a V-8 clutch. Check out my thread
    https://www.jalopyjournal.com/forum/threads/starting-my-29-tudor-rebuild.994229/
    It has alot of the details on what I was thinking and doing during the build.
  14. fadingfastsd
    fadingfastsd
    Right on, thanks. I will check out your thread!
  15. fadingfastsd
    fadingfastsd
    Well haven't updated since the spring, and been driving the **** out of the car all summer. Some more updates.
    Put on a cast iron header, sounded much better and got some more top end out of the motor.
    Then made a pipe for it. Got some tubing, a short cherry bomb gl*** pack, and made a rad snake pipe.
    Sounds great and looks cool on the car.
    J.Ukrop, winduptoy and Tim like this.
  16. fadingfastsd
    fadingfastsd
    Finished up the paint finally.
    J.Ukrop, winduptoy and 1stGrumpy like this.
  17. fadingfastsd
    fadingfastsd
    Got sick of adjusting the generator output for charging with lights. Switched to a 6V pos ground single wire generator. Works much better.
    And then went to an FSI ignitions distributor curved for the high comp head. Really woke up the motor.
    Since then, just driving it most days and havin fun.
  18. Tim
    Tim
    from KCMO
    Thy snake pipe cracks me up, can we get a photo of it on the car?
    winduptoy and fadingfastsd like this.
  19. fadingfastsd
    fadingfastsd
    haha sure. I don't think I took one of the complete pipe on the car. I'll take one tomorrow and post it. It's my favorite part at this point.
  20. Nice! Ya did good.
  21. Grumpy ole A
    Grumpy ole A
    I agree the snack pipe looks good.
  22. ModelAMitch
    ModelAMitch
    I love the paint! Looks awesome.
    Was the FSI pretty much a bolt on piece or did it take some messing around to get it running right?
    I'm wanting to purchase one myself, just waiting for the funds to do so.
  23. fadingfastsd
    fadingfastsd
    Easy bolt on. It dropped right in place of the original. I have a NuRex timing kit on the motor, so I just eyeballed it to get it started. Then put a timing light on it and fine tuned it for base timing. Super easy and love it. I have a 6:1 high comp head, and their curve for that works well.
    ModelAMitch and winduptoy like this.
  24. I put one on my '29 and loved it! Simple drop in, well worth the money.
    ModelAMitch likes this.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Looking like a ton of fun. Great work making the car your own and enjoying the ride!
  26. fadingfastsd
    fadingfastsd
    Thanks Joey! Your killer thread on your build during covid was my whole motivation to do one myself. Thanks again dude!
    J.Ukrop likes this.
  27. fadingfastsd
    fadingfastsd
    Finally grabbed a few pics of the pipe today. Had a ton of rain and **** weather lately so haven't had it out of the garage in a few days.
    AndersF and Tim like this.
  28. Tim
    Tim
    from KCMO
    That’s fantastic
  29. fadingfastsd
    fadingfastsd
    Well nothing new! Put down lots of miles in the car this summer. Still driving it until the snow hits here in CO. Oil burning is getting steadily worse, but still runs great. Gonna need to figure that out soon, but not real motivated until it causes a problem. Though I'm adding a lot of oil regularly at this point....
    I'm watching for another local A motor to buy and swap in to run while I tear down this numbers matching engine. Since I ***led the car with the engine number (car had no frame number so I stamped the engine number in the frame) I want to keep it as the primary in the car. Anybody know of a running A motor in Northern Colorado?
    ModelAMitch and Tim like this.
