my 32 roadster chassis
Discussion in 'The Hokey Ass Message Board' started by 32dude, Jul 2, 2008.
  1. here are some pictures of my roadster chassis. it's been along time comming,but i can finally see the light at the end of the tunnel.it has a built ZZ-430,tremec tko600 5-speed,real halibrand mag. quick change,15x4 mag.sprints,16x13 american "bear claws",drilled i-beam,hand made stainless hairpins,and ladder bars.
    see what you think of it.let me know if you have any questions.
    -bruce
  2. HotRod_Joe
    HotRod_Joe
    Looks great! However, to me, the engine looks out of place. Are you planning to put on some dress-up pieces to make it look more "period correct"?
  3. Jeem
    Jeem
    Alliance Vendor
    THIS, I like!!
  4. Sparkswillfly
    Sparkswillfly
    from Colorado
  5. Stunning craftsmanship, absolutely beautiful work - it will almost be a shame to cover it, but if this is the foundation, I expect the total vehicle will be one that wins all the prizes. Just hope the owner actually drives it and enjoys it more than only at shows.
  6. thewildturkey46
    thewildturkey46
    from Rice, MN
    very nice job............................Dale
  7. The Brudwich
    The Brudwich
    Great looking chassis! Dig the sway bar setup, along with all your tabs, brackets and mounts. It's pretty clear that everything was very well thought out. I can't wait to see what the rest of the car looks like.
  8. jusjunk
    jusjunk
    from Michigan
    Damn thats sweet. Nice attention to detail..
    Dave
  9. Bruce,
    What color is that? What are the little notches in the rear crossmember?
    The chassis is gorgeous.
    JH
  10. 54MEB
    54MEB
    Great job from a fellow Houstonian!
  11. i am the owner,and yes it will get driven.:D
    glad you like it.
    -bruce
  12. Thirtycoup
    Thirtycoup
    extremely nice job, what are those rear wheels?
    thanks, mike
    p.s. please keep the updates coming!!
  13. OK, fess up.............where did you score the BFGs!? NOS?
  14. Stevie Nash
    Stevie Nash
    Do you eat off of the floor? Nice looking frame, I would be afraid to drive the car when it's finished....
  15. hotcoupe
    hotcoupe
    who does your floors? oh, nice chassis too!
  16. narducci
    narducci
    Beautiful !
    Hope mine comes out that nice
  17. Deuce Roadster
    Deuce Roadster
    I for one ... like the engine ... :)
    But then ... I may be biased ... I have two of them in 1932 Fords ... #216 and #430 of the only 430 ever
    built by General Motors.
    I also have a third one in pieces ... that I will someday put back together :D
    Bruce ... your chassis LOOKS GREAT ... and I love all the neat hard lines and details. That 430 will really push a 32 Ford ... and they are not all
    that rough on fuel. ( mine gets 15 - 17 MPG on the highway ) ... less in town because it feels so good when you mash on it ... :)
  18. qzjrd5
    qzjrd5
    from Troy, MI
    That chassis is beautiful!!
    I will ask the same question - what color is that?? Very cool.
    Mike
  19. Stunning work. Very tastefully done. I especially like the exhaust. I have the same motor trans combo in a deuce highboy. ZZ430 #267 with tremec TKO 600 and Randy is right it will push your 32 very well. I can run at 80 MPH all day and get 20 MPG. I ended up keeping mine looking "right out of the box" because I run hood sides and don't have it open often.
    I didn't see a serial number on the valve cover of your motor? Is that one from Sallee Chevrolet?
  20. Harrison I started out with 1939 Ford Gull Gray but when i took the color outside it washed out bad so i had Sean Ornduff (OHR281 on the hamb) add some green to it. Ornduff Hot Rods of Tomball Tx. does our paint work. The notches are to clear the gas tank flange. The tires i have had since they first made them as i brought those wheels over 30years ago. The rear is a Culiver City that i brought about 25 years ago for $75.00.I have some nice parts for the roadster that i have brought over the years 25 louver hood, early hood downs,60's S-W guages . This car may not have a chopped top as i have a nice orginal top , non't know yet. This car will be driven unless someone comes alone and has to have it . I can always drive the roadster pickup.
    Thanks for asking.
    Bruce
  21. vendettaautofab
    vendettaautofab
    Very nice, I like it....well built and executed, tasteful... all that
  22. I've been staring at too many paint chips.
    That's what I would have guessed. :eek:
    I love it.
    JH
  23. scootermcrad
    scootermcrad
    Beautiful!!!
    Question.... what rear spring clamps are those? I've been looking for something a little more accurate for my Model A crossmember/spring and those would fit the bill.
    Very nice work and worth of showing off indeed!
  24. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    Ditto all the superlatives that have already been said!!!!!
    I am building my first deuce, also running a quick change, and expect to have a very similar exhaust routing out the back. Do you feel you have sufficient clearance for suspension movement?
    Thanks
  25. 3wLarry
    3wLarry
    from Owasso, Ok
    ok bruce, come clean...did danny build it?...:D
    kidcampbell71 likes this.
  26. bluesman
    bluesman
    from spring tx
    Theres no flys on this chassis seen it in person and thats what you call passion hats off to 32 dude.......Randy
  27. I have been working on it for so long i'm not sure what part that i did, but i did do something like throw hundred dollar bills at it. I then had to part with a nice closed cab and parts for his new pickup. All kidding aside i did make a lot of the brackets,motor mounts rear sway bar mounts weld up the rear end and install rear crossmember but most of the neat stuff was done by the pro. I wonder who taught the pro?
    Bruce
  28. Orginal crossmember and spring clamps 1931
    Bruce
  29. I think that I have enough clearance because we have ran 3" exaust
    over the rear end and this is just 2 1/2"
    Bruce
  30. Mike Paul
    Mike Paul
    Do you have plans for a rear panhard bar?
