my 34 3 window coupe build
Discussion in 'The Hokey Ass Message Board' started by JustplainJ, Apr 11, 2010.
  1. JustplainJ
    JustplainJ
    from so.cal.
    NO, CW moss screwed up my order....... parts will be here today.
  2. RancheroMan
    RancheroMan
    whats the story on the Indian Motorcycle sign??
  3. ss34coupe
    ss34coupe
    I like that steering box installation. Very innovative, and shows you can go traditional on a boxed frame.
  4. general gow
    general gow
    MODERATOR
    looking good. nice turn around.
  5. HotRodMicky
    HotRodMicky
    Very cool project!
    34corner WAS an english company. Rodline today.
    I think you have an F1 steering box and no F100.....
    Michael
  6. JustplainJ
    JustplainJ
    from so.cal.
    that makes sense now.... as the car was set up for right hand drive.
  7. titus
    titus
    You can use a 40 ford (other years are the same also) pitman arm and ditch the ball end of the f-1's, just a sugestions.
    Cool project, ive always wanted to make a gl*** car look "correct"
  8. JustplainJ
    JustplainJ
    from so.cal.
    OK, got my order cw moss today.... so I got the radiator in, radiator support rods and radiator rod firewall brackets in. mounted headlights.
    also put in new rear shackel bushings and vern tardell lowering shackels.
  9. JustplainJ
    JustplainJ
    from so.cal.
    I have both... I just like the mechanical look of it....
    thanks for the pos. input.
  10. titus
    titus
    I totally hear you there, my excesive compulsive takes over and tells me both ends of the drag link should be the same!
    Lookin real good!
    jeff
  11. Bad Bob
    Bad Bob
    from O.C. Baby
    You just can't beat this look!!!!! NASTY....
    texkbc likes this.
  12. HotRodHighley
    HotRodHighley
    from cincy, oh
  13. DaveyJonez
    DaveyJonez
    from Houston
    Man, that thing sits nice-
    That is going to be one fine 34.
    I guess the "Boyd would be proud" guy isn't impressed?
    Some people just don't know what a Hot Rod looks like.
    And some are just Knobs.
    Keep up the great work!
    Dve
  14. kaui
    kaui
    from SJC calif
    Outstanding car, love the stance also. I can see why Bob is jealous, me also.
  15. JustplainJ
    JustplainJ
    from so.cal.
    Ok, more stuff done today..... tail lights were installed, got my 6x2 caddy manifold and found and installed the radiator grill.
  16. That's turnimg out NICE!! Awesome project.
  17. Bad Bob
    Bad Bob
    from O.C. Baby
    It just keeps getting better and better!!!!! Like your choice of taillights too,Jim.
  18. Roadsterpu
    Roadsterpu
    Looks fantastic Jim.
  19. Bad Bob
    Bad Bob
    from O.C. Baby
    Okay.....where's todays update?????
  20. Pete
    Pete
    very cool! Looks like it belongs on the salt.
  21. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Ha! That's ****ing killer!!!!
  22. johnnykck
    johnnykck
    Very nice, I always wanted a '34 coupe.
  23. JustplainJ
    JustplainJ
    from so.cal.
    so I converted my model A to open drive a few months ago....
    I had bought a open drive trans from a hamber and used it in the A
    so I thought I would convert the old 39' trans out of the model A to open drive for the 34' project.
    I found a tail piece and main shaft to change it to open drive and worked on it today... but after putting it back together the pilot shaft had a ton of play in it! I'm like WTF! so I can't find the problem untill I took it apart for the 3rd time and see the case has a huge crack in it where the main bearing goes..
    so the only spare case I have is my mock up case with the big hole in the side of it! so I Mig welded it up and did the JB weld insurance for leaks and will put it back together tomorrow.
  24. lorodz
    lorodz
    beautiful car ....
  25. fab32
    fab32
    It's 3 am here and i can't sleep. You need to drag your *** out of bed and do an update. You can sleep after the car is finished.:eek:
    Just kidding, but seriously I can't wait for the next installment. This should be written up in one of the mags as how to turn a STREET ROD into a HOT ROD.
    Frank
  26. OoltewahSpeedShop
    OoltewahSpeedShop
    Subscribed..... Looking great.
  27. Flying Tiger
    Flying Tiger
    from Japan
    looks really good! The stance is right on
  28. Bent
    Bent
    from Canada
    Love the taillights, car looks bad ***.
    Subscribed!
  29. X38
    X38
    Great turn around!
    One thought though, that rear coilover x member looks pretty feeble for the transverse spring, considering the weight is supported in the middle - the easiest part to bend. ?
  30. Lookin' good, but I have to echo X38s comment on the spring X member.
    Doc.
