my 34 3 window coupe build
Discussion in 'The Hokey Ass Message Board' started by JustplainJ, Apr 11, 2010.
  1. JustplainJ
    JustplainJ
    from so.cal.
    1/4 wall box tubing have the same thing on my model A.....
    over 35000 miles no problems......
  2. Gotgas
    Gotgas
    from DFW USA
    Man... that kicks ***. I like that you're using the busted '39 case! All real hot rods have some 'iffy' parts on them! :D
  3. hotrodjeep
    hotrodjeep
    J,
    Was the option of a replacement steel firewall ever considered? Like what HotTurkey did on his '32.
    I think he switched his cause it was flat, yours seems to have a more 'correct' style to it.
    But just wondering if you thought about it. Great work, 2,010 % better then what you started with.
    Jeff
  4. JustplainJ
    JustplainJ
    from so.cal.
    it's the stock style fire wall with a 3'' setback perfect for what I'm doing....
  5. hotrodjeep
    hotrodjeep
    Atleast its not flat, most flat firewalls ruin the look for me.
    Jeff
  6. JustplainJ
    JustplainJ
    from so.cal.
    I agree with you 100 percent...BTW hot turkey did a killer Job on his 32'
  7. Crafty B
    Crafty B
    I like everything about this car....
  8. freebird101
    freebird101
    awesome
  9. Harms Way
    Harms Way
    I agree 100% :D,..... Hey Frankie !, you can't sleep, because, except for the engine choice (which I thoroughly DIG !), he is building the car you described to me,that YOU wanted to build for decades !,..... Maybe it's time to get "Itchy".
    As they use to say,.....
    "Wrap your A** in Fibergl*** !":eek::D
  10. Bad Bob
    Bad Bob
    from O.C. Baby
    I love the fact that you repaired the case. That's what a Hotrod guy would have done in the past! Mostly cause the cars were built on a budget...
  11. OoltewahSpeedShop
    OoltewahSpeedShop
    You mentioned that the frame was a TCI. I wonder if the frame is close to a stock '33-34? The reason I ask is that 90% of the aftermarket frames you find are designed for the MII stuff. Just wondering if you had to modify your buggy spring crossmember to make it fit the frame?
    You made it look really easy..... Just wondering how everything went together.
    Kevin
  12. wow, this is great.
    bye bye street rod, hello hot rod.
  13. JustplainJ
    JustplainJ
    from so.cal.
    OK, I got trans case repaired and put back together....
    so in the morning I will get the flywheel, press. plate and trans in...
    with paint on trans case you can't tell it was repaired....
  14. JustplainJ
    JustplainJ
    from so.cal.
    Kevin, front cross member was long and had to be trimmed for box frame rails....
    but other then that everything seems to fit all the stock 34' stuff.....
  15. He He He... that's cl***ic!
  16. Bad Bob
    Bad Bob
    from O.C. Baby
    What made you choose that blue? Just curious...
  17. JustplainJ
    JustplainJ
    from so.cal.
    ford color!!!!!!!!!
  18. Bad Bob
    Bad Bob
    from O.C. Baby
    Good answer,my friend!!!! hahaha!
    This is just an amazing transformation! Can't wait to see the before and after pic's together!!!
  19. DeadFast 33
    DeadFast 33
    from Santa Cruz
    Best use for tupperware I've seen in a long time!!
    FLIP
  20. JustplainJ
    JustplainJ
    from so.cal.
    today we got inner fender aprons so I installed them.... they will need some work to get them right. got the trans in and will make rear trans mount when I get some mounts at pomona this weekend.
    motor and trans need to to moved back about an inch, I will try and get that done tomorrow.
    it's a shame the old owner cut the **** out of the floor and firewall!
  21. METSHAPER
    METSHAPER
    from SOCAL
    great car! and cool thread....
  22. hotrodjeep
    hotrodjeep
    '34 at Viva next year?
  23. what an awesome transformation!!!!!!!!!!!
  24. Last edited: Apr 23, 2010
  25. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    Very cool ,nice job I like it.
  26. JustplainJ
    JustplainJ
    from so.cal.
    yea it's nice having that 3" set back biult into the firewall....
    your car is going to be Bad ***!
  27. Jkustom
    Jkustom
    Man, how did I miss this up till now??
    Awesome job J.. Im jealous.. Looking forward to more updates.
  28. JustplainJ
    JustplainJ
    from so.cal.
    well my hood showed up from texas on sat. morning.... what a huge let down! the drivers side top is un usable along with the side I called the guy I bought it from said he would make it right we'll see.
    so I was at pomona on sunday(today) found allmost perfect hood for $300, $175 less then the one from texas..... found org.window frame so it was a good swapmeet day.
    here's p***.side hood after 6 hrs of metal finishing on sat....
    the hood top on right is from texas left is the one I bought today see anything wrong?
    the new window frame
    the new hood...
    the front window crank installed
    the window hinges..
    door gl*** regulators
  29. Bad Bob
    Bad Bob
    from O.C. Baby
    Looks great with the hood on Jim....It just keeps getting better!!!!
  30. Harms Way
    Harms Way
    Can you work any faster on it ?,..........:D At this rate you should be driving it in a week or so. You do nice work,... looks great !
