My 34 3 window coupe build
Discussion in 'The Hokey Ass Message Board' started by Cragar, Jul 30, 2014.
  1. ss34coupe
    ss34coupe
    Listen to Kenny. That is one cool 34 three window!
  2. Cragar
    Cragar
    I agree it is a cool 3 window but so is this ImageUploadedByH.A.M.B.1409041946.183719.jpg
  3. thommoina33
    thommoina33
    Alliance Member
    from australia
    Cragar, look even better with 4'' out of the roof and no fenders, ha ha
  4. Cragar
    Cragar
    Here is a bit of a up date on the coupe first the tail shaft loop it took along time to make and I wasn't shaw if it would look any good so I kept on walking away from it ImageUploadedByH.A.M.B.1413228460.547040.jpg ImageUploadedByH.A.M.B.1413228477.138268.jpg . And then I started on the floor and subrails ImageUploadedByH.A.M.B.1413228566.935507.jpg ImageUploadedByH.A.M.B.1413228589.162109.jpg
    thommoina33 likes this.
  5. Cragar
    Cragar
    ImageUploadedByH.A.M.B.1414627306.081282.jpg . A bit more of the floor done
  6. thommoina33
    thommoina33
    Alliance Member
    from australia
    Nice work mate, why aren't you at work?
  7. Cragar
    Cragar
    I am at work just waiting
  8. thommoina33
    thommoina33
    Alliance Member
    from australia
  9. Cragar
    Cragar
    All right Thommoina just go you some updates here we go it has changed a lot since my last update ImageUploadedByH.A.M.B.1434358009.798774.jpg I found some very ordinary repaid on both quarters and both cowls ImageUploadedByH.A.M.B.1434358202.721955.jpg so I cut all that out ImageUploadedByH.A.M.B.1434358329.408357.jpg
  10. thommoina33
    thommoina33
    Alliance Member
    from australia
    Keep going, I know you've got more pics.
  11. Cragar
    Cragar
    Braced the body and started to remove the roof incert that was screwed over and leaded in ImageUploadedByH.A.M.B.1434358706.207707.jpg ImageUploadedByH.A.M.B.1434358737.531048.jpg It looked like brand new as you can see
    kiwijeff and thommoina33 like this.
  12. Cragar
    Cragar
    You are a slave driver Thommo So next it was of to the sand batters ImageUploadedByH.A.M.B.1434358944.790510.jpg ImageUploadedByH.A.M.B.1434359008.169688.jpg home and primed and at this point I am very happy found on more surprises now it's time to start putting it together stressful ImageUploadedByH.A.M.B.1434359282.320472.jpg
  13. 63Compact
    63Compact
    Keep the posts coming
  14. Cragar
    Cragar
    I made the last part of the floor I had to raise it to clear the nine inch ImageUploadedByH.A.M.B.1434359544.409992.jpg I got the rust repair panels and of course they weren't long enough so I made them longer ImageUploadedByH.A.M.B.1434359714.786180.jpg I put a new back panel in ImageUploadedByH.A.M.B.1434359836.131931.jpg
  15. Cragar
    Cragar
    There is more but can't over do it
  16. dirt t
    dirt t
    Thanks for the update! lookin good.
  17. Cragar
    Cragar
    Next I repaired the wheel wells on both quarters ImageUploadedByH.A.M.B.1434400474.313325.jpg ImageUploadedByH.A.M.B.1434400545.674483.jpg firewall next make it look like it should even if it has a cut out ImageUploadedByH.A.M.B.1434400822.063107.jpg ImageUploadedByH.A.M.B.1434400859.717276.jpg
  18. Airborne34
    Airborne34
    from Texas
    That is a cool car. I love the fact that the roof hole is near perfect. Would you mind posting a few pictures of how you braced the body? I'm at that point, need to replace a poorly installed "*****in" floor and expect to find some hideous repairs along the way. Thanks
  19. Cragar
    Cragar
    Here are some pics of the bracing I used the pics aren't the best as I was not real proud of the bracing but it seemed to work ImageUploadedByH.A.M.B.1434429938.065620.jpg ImageUploadedByH.A.M.B.1434429987.152158.jpg ImageUploadedByH.A.M.B.1434430030.710687.jpg the front bars went to a bar that ran across the body just under where the dash would be the engine lifter I used so I could lift it by my self and adjust it to get the balance right hope this helped as I don't have any more pics as the bracing has long gone if I can help any more just sing out good luck airborne 34 could you put up a pic of your coupe
  20. Cragar
    Cragar
    Next was to finish the tow board and the tunnel ImageUploadedByH.A.M.B.1434431120.392435.jpg then the right hand dash and steering column ImageUploadedByH.A.M.B.1434431313.769457.jpg
  21. Airborne34
    Airborne34
    from Texas
    Very nice bracing job. Like the spreader idea. Mine will be with the doors on so, I'll fab a combination of this design. Thanks!!
  22. 63Compact
    63Compact
    Keep it coming what you've done is bound to help someone else
  23. Cragar
    Cragar
    Time to change from ****y seat to boot lid or as you guys call it a trunk lid ImageUploadedByH.A.M.B.1434486968.266617.jpg now doors I had some door skins rolled up from the swage line down so I attacked the doors ImageUploadedByH.A.M.B.1434487163.991056.jpg
  24. dirt t
    dirt t
    Is that converting from a rumble seat to a deck lid? (Smiling)
  25. Cragar
    Cragar
    Yer something like that dirtyT [emoji2]
  26. Cragar
    Cragar
    Spent a bit of time on the doors repairing the frame I took the bottom repair panel of and redid it put the doors back on and wow they fit a little better but still a long way to go ImageUploadedByH.A.M.B.1434765222.597456.jpg I have all ways wanted a set of Real rodders wheel but to get a set here in Aus was way to dear so when I saw his set for sale here I had to have them ImageUploadedByH.A.M.B.1434765454.241540.jpg ImageUploadedByH.A.M.B.1434765481.048271.jpg
  27. timwhit
    timwhit
    The car is looking really good! Anxious to see the next update. Tim
  28. Angry Frenchman
    Angry Frenchman
    you have no fear!! awesome job man!
  29. Cragar
    Cragar
    Thanks Timwhit & angry
  30. Cragar
    Cragar
    Started putting in some patch panels ImageUploadedByH.A.M.B.1434920138.202553.jpg ImageUploadedByH.A.M.B.1434920164.876528.jpg next was the cowl and rocker panels ImageUploadedByH.A.M.B.1434920253.339078.jpg
