My 34 PU Project
Discussion in 'The Hokey Ass Message Board' started by Retribution, Jan 4, 2010.
  1. Retribution
    Retribution
    from Western PA
    Here are some photos of the engine. You can see the radiator is now installed. If you look closely you can see the fan is to high so, a custom fan mount will have to be made to lower it.
  2. Retribution
    Retribution
    from Western PA
    Here you can see a few more photos of the front & rear suspension
  3. Retribution
    Retribution
    from Western PA
    Sebastian
    Here are more detailed photos of the bed that you saked for.
  4. Retribution
    Retribution
    from Western PA
    Ch***is Video
  5. Retribution
    Retribution
    from Western PA
    Bed Detail Video
  6. Sebastian.A.G
    Sebastian.A.G
    from argentina
    Hi, thank you, thank you very much for the help and pictures, and you pick up this very good.
    regards
  7. Retribution
    Retribution
    from Western PA
    No problem, if you have any questions, you know how to contact me.
    Thanks
  8. Retribution
    Retribution
    from Western PA
    The ch***is is nearly complete. Everything is tack welded and the bed is set into position. In one of the photos you can see cardboard, this is the mock up of the fuel tank. I hope to have it off the ch***is table soon.
  9. Retribution
    Retribution
    from Western PA
    More Photos
  10. Retribution
    Retribution
    from Western PA
    The engine mounts are tack welded in as well.
  11. Sweet Cheeks
    Sweet Cheeks
    Dude, your making nice progress!
  12. Retribution
    Retribution
    from Western PA
    Here is the video.
  13. Retribution
    Retribution
    from Western PA
    Work on the steering is all complete. Steering box is mounted, links installed. Bones finally attached to the ch***is with bung for additional strength. Hope to get the brakes on the spindals soon.
  14. thunderbirdesq
    thunderbirdesq
  15. dirtbag13
    dirtbag13
    very nice work and attention to detail
  16. TMunster
    TMunster
    from Las Vegas
    wow! what a great thread, have really enjoyed the pics and constant updates! great work
  17. Retribution
    Retribution
    from Western PA
    Here is the drive shaft tunnel. First a tube frame was made. Then a cardboard template for the sheet metal and finally the sheet metal. Starting to come together.
  18. Retribution
    Retribution
    from Western PA
    And for the "Pièce De Résistance" my shift knob. Its a br*** knob with the Thirty Years Of Progress Coin laid into it. Now it off to the platers. I am having one plated in Nickel to match my 34 PU color scheme.
    Three of these were made and 2 may be available?
  19. Retribution
    Retribution
    from Western PA
    Hello Everyone,
    On to the cab modifications. If you remember, it's Chopped 5", Channeled 4" and Stretched 10".
    Still unsure how much stretch is going in the door and how much in the cab so, I've been playing around with the stretch in Photoshop and I think 6" in the door and 4" in the cab is visually good to maintain proportions.
  20. Retribution
    Retribution
    from Western PA
    A few more photos.
  21. Retribution
    Retribution
    from Western PA
    Some Video
  22. hasty
    hasty
    Looks really good! Engine sounds good too.
  23. Retribution
    Retribution
    from Western PA
    As you might see the fan is too high so, the plan is to lower it. The alternator is going to be moved up and over in front of the carb.
    The cardboard is the floor template and the lines are where beads are going to rolled for rigidity.
  24. Retribution
    Retribution
    from Western PA
    Here you can see the undercarriage. Everything is tucked up but, I think the grille might have to be shortened a little.
  25. Retribution
    Retribution
    from Western PA
    One more video!
  26. HarborKustomSpeedShop
    from Olalla, WA
    Wow, Very nice. Love the tube work...
    whats the purpose of the "torque arm" on the ******?
    Justin
  27. Retribution
    Retribution
    from Western PA
    It's to stabilize the transmission. Some folks have said, flatheads with modern transmissions experience clutch chatter when engaging.
  28. Retribution
    Retribution
    from Western PA
    Moving right along on the cab body. As I mentioned before the 34 is getting a 10 inch stretch (6" in the door, 4" in the cab). Here you can see the 4" panel with beadlines tacked into position. The door jam is also in position. If you look at the rear bottom of the cab corner, it has been redone including a new beadline which follows the channeling on the rear of the cab.
  29. Retribution
    Retribution
    from Western PA
    Well I'm sure those of you building a 34 know how hard it is to find door hinges if not impossible. These hinges were fabricated using one of the original hinges as a template. When I got the 34 cab, it only had one outer door hinge part and all four inner cab parts. Now I have a complete set of hinges.
  30. Retribution
    Retribution
    from Western PA
    Here is some video of the 4 inch stretch added to the cab.
