My 37 GMC build
Discussion in 'The Hokey Ass Message Board' started by r.s.s., Feb 24, 2009.
  1. r.s.s.
    r.s.s.
    from Alberta
    Well I guess this is the start. I'll probably be making very slow progress but I thought I would post anyway.
    The "new" frame (sort of). I can't wait to dive in. :D
  2. budd
    budd
    your off to a get start.
  3. Johnny C.
    Johnny C.
    A pile of iron and a welder is a good place to start. Slow or not just keep posting.
  4. r.s.s.
    r.s.s.
    from Alberta
    Well I got a little bit done over the last 2 nights, I just finished up my frame table/jig "legs" (aka sawhorses) and got my steel off the ground. now I just have to convince some people to get some stuff out of the shop so I can set up. slow and steady right?
  5. Looks great so far, maybe a bit more of a chop?
  6. r.s.s.
    r.s.s.
    from Alberta
    I got a little bit done tonight. I got my rails tapered, I'll weld the fillers in on the weekend. and I built some stands that "rest" on my frame table. I'll use them for welding up my 9" after find one, and I cut it down. and I'm sure I'll find other uses for them at some point. oh and I brought my front cross member to the shop too. I'll see how much me and my buddy can get done on the weekend. it's starting to get hard to sleep at night :)
  7. budd
    budd
    whats the wheels for?
  8. model-a-fan
    model-a-fan
    from Kentucky
    I don't like the grill. JK, keep at it.
  9. Still needs more of a chop.
  10. r.s.s.
    r.s.s.
    from Alberta
    Budd, the wheels are so you can rotate the piece without it rolling away or towards you when welding.
    You'er right chopped51 it needs about 3.5" off the top (it's stock right now).
  11. 3.5 is a start. How about 5" ??
    You plan on leaning the pillars or stretching the roof?
  12. r.s.s.
    r.s.s.
    from Alberta
    5" might be a little much with the way the windsheild comes up in the center. plus it will have a 4" channel. I'll see how much chop I can get away with once I get the cab on the frame, get a floor in it, and mount a seat. I'm undecided whether I'll be leaning the posts or stretching. I guess I will cross that bridge once I get to it.
  13. Yes if your doing a 4" channel that might be cuttung it a bit tight. It will come down to seat choice and your size.
    I always say if your chopping you may as well go for broke. 7" on my car and 5" on the truck. Still a lot of head room in the truck and I'm 6'5".... but I never channeled it.
  14. r.s.s.
    r.s.s.
    from Alberta
    Here is a shot of what me and a buddy got done on Saturday. everything is cut and capped. Another full day and I'll have a full perimeter frame. Then I'll be onto mounting the engine and ****** as well as mocking up the cab to start the channel.
  15. r.s.s.
    r.s.s.
    from Alberta
    Me and my buddy busted our ***es on Saturday and this is the result. Next up is mounting the motor and trans.
  16. r.s.s.
    r.s.s.
    from Alberta
    Went to a swap meet this morning and scored an original "Canadian" Vega steering box. Then on the way back I pulled a 9" with a limited slip at the wreckers. Its been a good day. looking to pick up a rear 4 bar next week and start on mounting the cab motor/trans and rearend.
  17. r.s.s.
    r.s.s.
    from Alberta
    Cleaned up the housing in preperation for the 4 bar and narrowing. Couple pics for ya.
  18. Johnny C.
    Johnny C.
    Great job. Your frame looks good.
  19. moon man
    moon man
    great start... looks real good.
  20. r.s.s.
    r.s.s.
    from Alberta
    Thanks guys. Hopefully I can get my motor/****** mounted this weekend, then it's onto the cab floor.
  21. r.s.s.
    r.s.s.
    from Alberta
    I picked up my rear 4 bar, brake booster, and my buddy gave me a wishbone to split. I also ordered my wheels from Jason at Early Wheel/Bear Metal Kustoms today. Thanks again Jason. Now i'm just waiting on my magnum 5" drop axle and I'll be in serious business. I can see some late nights ahead.
  22. r.s.s.
    r.s.s.
    from Alberta
    Got a little more done today. Trimmed and set the cab on the frame and mounted the motor and trans. Going to narrow the rear end tomorrow and order up some new axles on Monday. Next round I should have the 4 bar and rear end mounted :D. Heres a pic, cause I know we all love the pics.
  23. r.s.s.
    r.s.s.
    from Alberta
    Got the rear end narrowed today. Hopefully have some new axles within a couple weeks. By then if all goes well, I might have a roller.
  24. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    Ryan,
    Got your wheels back from the powdercoater today and going on UPS truck today.
    Jason
  25. r.s.s.
    r.s.s.
    from Alberta
    Thanks Jason. Can't wait to get them mounted.
  26. r.s.s.
    r.s.s.
    from Alberta
    Things have been going pretty well just waiting on parts, but there is still plenty to do with what I've got so far. Got my cab and doors blasted and now I can realy see what I have to work with. Got the rearend mounted and coilover crossmember in yesterday, did a bunch of grinding and now I'm ready to start on the cab floor. Also got my bigs and littles in (600/750) and my wheels (thanks again Jason). on to the pics. :D
  27. r.s.s.
    r.s.s.
    from Alberta
    I got a box!!!!!!:D Had to take the whole works and busted up my knee in the process but i finally found one, WOO HOO!!!:D
  28. Mr48chev
    That is a pro welder trick that is often used by guys who do sanitary welding on stainless tubing. Makes it easy to lay a really nice bead on round tube.
    I like where this is going R.S.S. It looks like you have a serious plan going on there.
  29. Captain Zoom
    Captain Zoom
    from Idaho
    Hell ya man, a much better find than what I had to start with
  30. PAPASMURF
    PAPASMURF
    That bed looks a lot better than the one I'm starting with. Good score, I like your build man.
