Projects My 40 Ford Pickup Build
Discussion in 'The Hokey Ass Message Board' started by mj40's, Nov 3, 2010.
  1. Roothawg
    Roothawg
    Tell us how you are really feeling......
  2. cvstl
    cvstl
    from StL MO
    The louvered hood looks great!! (as does the whole project)
  3. otas
    otas
    Lmao.... A black 40 is hard to beat....
  4. mj40's
    mj40's
    I had a request for a photo of the radiator mounts. Stock frame mount with poly plastic block.
  5. kgp50
    kgp50
    Thanks for the detail. -Ken
  6. Mart
    Mart
    Enjoying following this build.
    Is the rad mount finished?? Or just mocked up? - Ideally you could use a longer bolt with a bit more rubber below the frame, and some sort of lockung nut - a Nyloc or two nuts locked together.
  7. mj40's
    mj40's
    It's just mocked up for now. Orginally they were mounted with a spring to allow for movement on ruff roads. There is also a bracket that mounts to each side from the radiator to the inner fender panels to keep any movement forward and into the fan.
  8. mj40's
    mj40's
    I just couldn't stand the G***er look. Don't get me wrong I love g***ers but not on this one. I picked up a set of 350# springs and installed them today and put the dropped spindles back in. Much better now. I have spring action now and it sets at 7.5" from the grill chin to the pavement. By the time I get all of the additional weight added and it settles it should be just right. With the 375# springs, two big guys could not budge the front end before. That was not going to change so I made the changes and we are happy now.
    Before: 375# springs with stock spindles
    Now: 350# springs with 2" dropped spindles
  9. Outback
    Outback
    from NE Vic
    Looking good!
  10. mj40's
    mj40's
    I slowed down a little over the holidays. The wiper kit has been giving me fits. Cheap kit and the wiper towers will not work right. P***enger side works but drivers side will not mesh with the gear. I need to find some cable driven towers off a MG/Jag or something British. I have been putting off putting the dash in until I got them fixed. So today I installed it to work out some wiring issues. I know it will have to come back out but at least I get to see it in place. The radio head will go in the speaker area and the rest under the seat. Won't even know it is there when the grill is in place.
  11. 40Standard
    40Standard
    from Indy
    I love the way this project is coming together. keep the pics coming. thanks
  12. otas
    otas
    where did you get the radio? looks great.
  13. mj40's
    mj40's
    It's from Custom Autosound. A new unit out called a Secretaudio SST. Hideaway Audio Solution. Has the control head with the base unit to be mounted in the dash or under the seat etc. I did buy mine off ebay for $20 cheaper and no shipping.
    http://www.customautosound.com/
  14. mj40's
    mj40's
    I added a little more trim to it today. Now I need to get started on working on my gauge cluster.
  15. 45_70Sharps
    45_70Sharps
    That thing is looking awesome.
    I've enjoyed all the postings!
  16. b-bob
    b-bob
    I have been watching, hoping to see you mount the rest of the front sheetmetal. I have a '39 coupe and i know it can be tough to align it all up. I'll just wait till you get there.
  17. Damn, looking better everyday! What size front tires are you running?
  18. ChefMike
    ChefMike
    Looks like nice work ! I am working on a 47 Ford Pickup! we have our work cut out for us !
    Happy New year!
  19. mj40's
    mj40's
    I will be starting on that soon. I had to work on the front spring problem first. That seems to be solved and ready for a quick alignment.
    They are 205/65/15's from Diamond Back
    Yes we do and hope to have this one ready for spring cruising. Thanks to all, mj40's
  20. mj40's
    mj40's
    Here is how the speaker grill works.
  21. b-bob
    b-bob
    Thanks, i will be watching, i am still blocking the body. I am subscribed.
  22. Monkey
    Monkey
    from Owasso, OK
    So that's what they are supposed to look like when they are done right! Very nice build! Loving it. All I have is this hunk of junk...
    kiwijeff likes this.
  23. hotrod40coupe
    hotrod40coupe
    I noticed that you mentioned that you were having problems with your windshield wipers. Are you scratch building or using a kit. If you are using a kit, what brand is it so I don't have the same problem.
  24. mj40's
    mj40's
    I used the “It's a Snap” kit, which is no longer being made. Motor is a Delco Remy unit and all looks good but the wiper transmissions seem to be the weak point. On one of them I can't get the gear to mesh with the drive cable. Is the Ez Wire unit any better or maybe the Specialty Power Windows (SPW). they all look the same but quite a spread in pricing.
  25. mj40's
    mj40's
    I haven't forgot you guys and gals. While waiting for parts to come in I spent a couple days putting this gauge cluster together. I use trimmed late model 12v donors for the gauges and speedo from another donor. I may do a build thread on these as well. I think this is the 4th cluster I have put together and love the stock looking idea. I have one in my black truck too.
  26. Pinstriper40
    Pinstriper40
    That gauge cluster is brilliant! (and your dash looks very nice as well!) I'd love to know how to do that!
  27. TomT
    TomT
    Man, you are moving right along! My truck project has stalled while I get my other 2 cars straightened out - I hope to be back on it sometime this spring.
    I would love to find out more on the gauge cluster build - very, very nice indeed. I started one by using 2 1/8" 12-volt gauges for the gas, oil, temp, and volts but I was stuck on the speedo. I do have a couple 40 speedos I could use but then they are not all black faced. I know there are some black faced decals I could use but I always thought there should be something out there I could retrofit - I just could never find one ....
  28. Looks like the gauges in my 86 Ford truck.
    Excellent work!
  29. okiedokie
    okiedokie
    from Ok
    Wonderfull cluster, please do a thread.
  30. cavisco
    cavisco
    That speedo looks like it is from an early '70s Mopar. Duster, Dart?
