My 50 Ford project
Discussion in 'The Hokey Ass Message Board' started by Mikeys World, Aug 13, 2010.
  1. Mikeys World
    Mikeys World
    from Scappoose
    This is my 1950 Ford Project Phantom Convertible, it was a 4 month build, Sits on a S-10 Ch***is with power steering and disc brakes, powered by a TPI Tuned Port injection small block from an Iroc Z-28 followed by a 700R4 ******. It is actually 50 pounds lighter than the donor Iroc was so its a screamer.
    It gets looks, thumbs up and comments every time I take it out.
    I'm considering selling it and moving onto the next project but I keep changing my mind. I'm not even sure where to start on the price if I did
  2. StanDaManTX
    StanDaManTX
    from The South
    I can kinda dig it
  3. 4Door54
    4Door54
    from Nor*Cal
    Eh. Not my taste.
  4. hombres ruin
    hombres ruin
    I dont get it.looked better stock
  5. mrkling
    mrkling
    I have the same set-up in my 50 Shoebox. I got rid of the MAF and put a MAP sensor on it. The only problem is when it gets real hot, it stumble a bit. I think the hot air off the radiator is affecting the fuel air ratio. I've been looking for a cold air intake set up. Looking at yours, I think I just found a solution.
  6. mrkling
    mrkling
  7. ffr1222k
    ffr1222k
    mrkling, did you change to the speed density computer (I am sure you did, just asking).
    On my TPI swap I mad a cold air box and piped over to it. I am still MAF though.
  8. Stefan T
    Stefan T
    from Sweden
    You should chop it and fix the rear edge of the coupe and move it forwards so it get better lines and the car will look verry good after this things
    /Stefan
  9. 60galaxieJJ
    60galaxieJJ
    i laughed really hard when i saw the overhaulin sticker
  10. mrkling
    mrkling
    I use an Accel Gen 6 ECM. It has its own wiring which uses a MAP sensor. It also eliminates the cold start injector. I'm looking for an intake boot so I can fab up a cold air intake. I'm new to the fuel injection game, but its actually not that difficult.
  11. Buddy Palumbo
    Buddy Palumbo
    I'm not much of a Chevy-in-a-Ford guy , but I like shoeboxes , and I like convertibles/roadsters , so I guess I'd rock it . At least your 'box is driving , lol !!
