My 53 chevy
Discussion in 'The Hokey Ass Message Board' started by briansbodyshop, Aug 25, 2010.
  1. briansbodyshop
    briansbodyshop
    from Paducah ky
    This is with jamco 4" drop leafs and 3" blocks..The rearend is hitting the frame..gonna have to c-notch and remove the blocks....
  2. briansbodyshop
    briansbodyshop
    from Paducah ky
  3. xhotrodder
    xhotrodder
    Do those perches have enough room for the u-bolts to stay in place when you put movement and a load on them. From this angle it looks like it is almost on the edge. Just concerned for your safety.
  4. briansbodyshop
    briansbodyshop
    from Paducah ky
    The perches have a recess in them for the u bolts to sink down into. Thats a good question.. Since this setup is stock on the 53 rearend im gonna say it is safe.. The perches moved on the original rearend and I had to weld them solid after setting my pinion angle..I could always weld a small tab on the edge just to be certain the u bolts wont come out...
  5. The_Monster
    The_Monster
    what I really like is that youre lowering it without bags. At least thats what it looks like! haha! Im not a hater on bags, but theres something really cool about being commited to a low stance, and it seems a bit more traditional to me. Just thinkin out loud :)
  6. Kool49
    Kool49
    Very nice build , thanks for all the detailed pics. Great job :D
  7. briansbodyshop
    briansbodyshop
    from Paducah ky
    Thanks.. No bags for me on this one..As it sits in the pics, it is a little too low for the suspension to travel..Im gonna have to c notch the frame to give my tubes a few more inches of clearance. I may have to cut some off my blocks to make it all work....
  8. briansbodyshop
    briansbodyshop
    from Paducah ky
    C-notching the rear for clearance
  9. briansbodyshop
    briansbodyshop
    from Paducah ky
    I welded a brace on the bottom of frame rails to keep everything from moving during cutting and placing of c notch
  10. briansbodyshop
    briansbodyshop
    from Paducah ky
    4" pipe cut in half
  11. briansbodyshop
    briansbodyshop
    from Paducah ky
  12. briansbodyshop
    briansbodyshop
    from Paducah ky
    disasembled front for new springs
  13. briansbodyshop
    briansbodyshop
    from Paducah ky
    Jamco front springs. measured 4" shorter than stock
  14. briansbodyshop
    briansbodyshop
    from Paducah ky
  15. briansbodyshop
    briansbodyshop
    from Paducah ky
    This is the car without lowering blocks.. This is only the jamco 4" drop leaf springs and my modifications to the rearend perches which added another inch of lowering..The c-notch in the frame gives me a total of 3" or clearance now to the frame..Without shocks on it will not bottom out.. With the lowering blocks installed, this thing would bottom out and the pumpkin hit the floor pan....This stance is perfect for me now.. 7 inches from the ground at the back of the front fenders and 6 1/2 from the bottom of the front quarters....
  16. Budro35
    Budro35
    Wow!! The stance is killer and just looking at that last picture I am not real sure if the chop would kill that look! Please keep us posted on a fantastic build! :eek:
  17. briansbodyshop
    briansbodyshop
    from Paducah ky
  18. briansbodyshop
    briansbodyshop
    from Paducah ky
    Thanks.. I believe 2.5" in the front and 3" in the rear would be just enough of a chop to make this thing POP... My dad only chopped his 35 tudor sedan 2" and it made a huge difference in the look...
  19. briansbodyshop
    briansbodyshop
    from Paducah ky
    here is a pic of my dads 35 with only 2" of chop
  20. rebstew187
    rebstew187
    Glad to see another Ky guy working on some stuff. Keep up the good work. She's lookin' good!
  21. Tin Can
    Tin Can
    nice detailed build, Lots of 53/54 builds on here and every one has its own style
  22. The_Monster
    The_Monster
    This is so cool! This is definately the way Ill be doing mine. Thanks a lot for the killer step by step tech. Still a totally driveable stance. I really like the fact that youre committed to the height and not going with bags. I like bags, and the detailed engineering they take to work correctly makes them a work of art in their own right. But Im just diggin the alternative to lowering blocks and cut springs. Seems kinda cheap and dirty now that I see this. Its like the smart and safe way of lowering a car. I know this is not a "new" or ground breaking discovery, but I dont hear a lot of guys going this route. Great job and perfect stance.
    I personally wont be choppin my top cause I think this car lowered and unchopped looks *****in!! This is my new wallpaper for inspiration :)
  23. briansbodyshop
    briansbodyshop
    from Paducah ky
    WOW!!!!! Thank you for the kind words!!!!!:D
  24. briansbodyshop
    briansbodyshop
    from Paducah ky
    Frenching headlights..These are 54 bezels. They are longer than 53. I didnt like the grooves in the center so I filled them...
  25. briansbodyshop
    briansbodyshop
    from Paducah ky
  26. briansbodyshop
    briansbodyshop
    from Paducah ky
  27. briansbodyshop
    briansbodyshop
    from Paducah ky
  28. briansbodyshop
    briansbodyshop
    from Paducah ky
  29. blanco
    blanco
    from canada
    Good job man, coming along nicely... cheers
  30. Smokey2
    Smokey2
    Hey, Did "Coke" Come-Up w/any Sponsor monies??, 4 that one photo?
    ...doc... Nailed it!, "damn, you aren't wastin' any time, gettin' GOING!
    Appreciate all the Photos...Keep'um ***ing.........
    __________________________________________
    I have a hard time livin' with My Wife!, But, I'd Never tried it HIS!!
