My 54 chevy shuts off after I drive it for 30 minutes
Discussion in 'The Hokey Ass Message Board' started by rocknroll54, Oct 20, 2014.
  1. rocknroll54
    rocknroll54
    Hello guys. I have a 54 chevy belair with the 235 motor. last week I replaced the intake/exhaust manifolds and gaskets. And I got the carburetor rebuilt. I took the manifolds to machine shop to get resurfaced. The carb was tuned. Anyway I drove it Friday night for the first time and after driving it for 30 minutes it shut off. Once I turned it on to drive it I had to keep my foot on the gas and other foot on the break in order to drive it back home. You guys have any idea what's causing that. Any info would be appreciated thank you.
  2. 49ratfink
    49ratfink
    I would check the nut that connects the steering wheel to the gas pedal.
    Fender1325 likes this.
  3. You did not say WHY you had to replace manifold gaskets and do the resurfacing and have the carb rebuilt.
    Was this stalling out a concern BEFORE this work was done ?
    It sounds like you may be experiencing a vapor lock condition. Are you familiar with vapor lock?
  4. rocknroll54
    rocknroll54
    My old exhaust manifold was cracked. So I replaced it along with the intake manifold. And while I was at it I got the carb rebuilt.
  5. Rusty O'Toole
    Rusty O'Toole
    Sounds like idle jet clogged up. Did you put on a new fuel filter?
    How does it run now? Is it still balky or did it cure itself when it cooled off?
  6. Again, was this "stalling out concern" there, before the mentioned work was performed?
  7. rocknroll54
    rocknroll54
    It wasn't stalling out before. I had back fire and exhaust leak before the work was performed.
  8. rocknroll54
    rocknroll54
    I researched what vapor lock means.
  9. engine138
    engine138
    from Commack NY
    Does your manifold still have heat riser in it could be stuck. Those manifolds had exhaust heating up the intake to prevent vapor lock. May want to install a kit from tom Langdon.
  10. rocknroll54
    rocknroll54
    I checked my heat riser and it is not stuck. It is all intact.
  11. henry29
    henry29
    Sounds like trash in the gas tank getting sucked up in the fuel line, has the tank been cleaned?
  12. Had a similar problem with my Plymouth flathead 6 after installing Langdon headers and his heat riser replacement kit. Turned out the problem was fuel pump and line too close to the front header. Built a shield for the fuel pump and it helped a little. Then I used header wrap on the headers and the fuel line. No problem after doing this.
