my 59 OT short bed step side...project
Discussion in 'Off Topic Hot Rods & Customs' started by ALLDONE, Apr 30, 2025.
  1. ALLDONE
    ALLDONE
    got this as kinda shop truck...302/auto... been working on it slowly... got the dual lake pipes done.... and most ly cleaning... IMG_5065.jpg IMG_5066.jpg IMG_5067.jpg
  2. ALLDONE
    ALLDONE
    wondering the best way to lower the front????? mustang 2???
  3. ALLDONE
    ALLDONE
    this is one of those trucks that a guy is best to just let it be..talk about upening a can of worms...getting it lowered is gonna be a major process... I got the seat over getting restored.... new foam and covered... 1000 bucks....WTF... might need to go back in the upholstery business...
  4. ALLDONE
    ALLDONE
    up date...exhaust is done new seat in... starting on lowering.... new problem... some one did a power cross steering... and yep.... everything is gonna hit if lowered.. thinking the real way to do this is start over... there seems to be a lot of ways to skin this cat...wonder whats the best and easiest??? getting rid of the steering box and leafs springs??? then what???
  5. pprather
    pprather
    Note your May 1 post regarding lowering.
    ALLDONE likes this.
  6. ALLDONE
    ALLDONE
    I'm guessing it's a hill and I still can climb alittle...was looking for an easier path over the mountain...
  7. chevy57dude
    chevy57dude
    Just about a rust free truck, nice. Those 2 barrel SBF's were so understressed, they'd run almost forever.
  8. ALLDONE
    ALLDONE
    did the bent main leaf lowering... worked the rear bumper, got it up and closer... put 50 truck tail lights...kinda on the back burner.. 302 starts and runs good...put chrome valve covers...and new air cleaner...
    chryslerfan55 and JohnLewis like this.
  9. ALLDONE
    ALLDONE
    it's offical.... shop truck/ parts runner....
    IMG_5441.jpg IMG_5442.jpg IMG_5443.jpg IMG_5444.jpg IMG_5445.jpg IMG_5446.jpg IMG_5447.jpg IMG_5448.jpg IMG_5449.jpg
  10. ALLDONE
    ALLDONE
    Well, none of the gauges work,... so that was my project goal...oil pressure was easy...new copper line and done....gas gauge.... kinda easy... cleaned up the wire connectors...and the wire to the sending unit...temp gauge... PITA...got it to work I think...I barely goes off the cold though.... so Thougt maybe the sending unit on the 302 doesn't match the gauge???? so I ordered a 1959 stock one.... we'll see...now here where the work started.... the amp gauge..how I fix them is take them out and put a volt meter.... but... I wanna know why it don't work...that and they are wired in series... some time you un hook them and some thing else stops working.... like charging the battery..so first thing... load test battery with it running...14 volts....next... try to get to the back side of the gauge.....rigatony wire mess under the dash... and elect tape wrapped... so finally made room to get to test gauge.... no volt either side... checked with it off, key on, and key on running...... nothing..so after about 4 hours of cutting tape I find the end of the wire...hooked to nothing.....WTF....I could have just un hooked the gauge.... the other wire went to a multi spade plug.... got no idea to what.... I have a china speedway volt meter gauge in the cabinet....black face...so easy peasy...right???? wrong...the gauge was a hare too big to fit the hole.... soooo.... now I need to file the hole to fit the new gauge,,,can't use my right arm for much yet and too dangerous for a power tool with my left...so spent about 30 min. try'n to file it by hand left handed..the dash piece is stainless to add to the **** show....so new gauge in.. one wire to key on power... and one to ground... start it up.... hell yeah... shows 14 volts.... so now ... all my gauges work...proud great grandpa right now... so unlike most here... I had to wait for my grand kids to have kids to be great..
    Okie Pete likes this.
  11. ALLDONE
    ALLDONE
    so looking at this, I have a 59 with 58 grille and 60 hood???
    ottersea and Okie Pete like this.
  12. ALLDONE
    ALLDONE
    progress... welded up all the holes in the body...new carb and pointless dist. and plug wires...
