right from a stop it has a bad hesitation. any advice would be great anything u can think of will be considered. i need this fixed and feel its just adjustment? any help would be great thanks your pal mark
Sounds Like Accelerator Pump Is Not Pumping Enough Im Not Real Sure On These Carbs But Holleys Have Different Ramps,shooters,even Larger Pumps Your Adjustment For It Is Right Behind Your Idle Solinoid Its A Bolt With A Spring On It Loosen It A Little At A Time It Should Get Better Later Bill
Does the vehicle hesitate when in park? if it does then its carburation problem, but if its doing it when in gear or under load I would check the ignition system. PM me if you have any Questions....
