My 9 inch is leaking!
Discussion in 'The Hokey Ass Message Board' started by red baron, Feb 12, 2010.
  1. red baron
    red baron
    from o'side
    All bad jokes aside, I have a ford 9 inch rearend in my car, what tip or tricks/things to watch out for, do you guys have for replacing the pinion seal? I have done several on GM diffs, and wasnt sure how similar it was! And yes i did a search but didnt find anything on pinion seals....
  2. a.y1320
    a.y1320
    Make sure the vent is not blocked. The pressures generated inside have to vent somewhere, usually the pinion seal.
  3. bulletproof1
    bulletproof1
    from tulsa okla
    get it good and clean and buy good parts...also make sure the yoke is not grooved.if it is ,the best way is to replace it,but you can get a redi-sleeve to install over the seal surface of the yoke....most GOOD parts stores will have it....
  4. el Scotto
    el Scotto
    from Tracy, CA
    ....they'll do that when you beat on it too hard....
  5. X2, been there.
  6. Von Rigg Fink
    Von Rigg Fink
    from Garage
    some how i knew this was ***ming:eek:
  7. Deuce Roadster
    Deuce Roadster
    I don't think a pinion seal will FIX THIS ...
  8. Yeah, you're going to need a tube of JB Weld and some duct tape too.
  9. el Scotto
    el Scotto
    from Tracy, CA
    That is an awesome picture!!
  10. railroad
    railroad
    A lot of up front leaks are confused to be pinion seals. You might include putting silicone sealant on the splines of the pinion gear prior to installing the yoke. You will also need a small amount between the nut and yoke.
    It works.
    good luck,
  11. Ian Berky
    Ian Berky
    Tell me about it!!!!:mad: I had mine rebuilt last week and about 10 min. ago i realized that the p***enger side axle seal is leaking!!!!:mad: the inside of my tire is soaked and the brakes probably!!! Im PISSED!!! BTW, its a 57 chevy rear end!!
  12. flynbrian48
    flynbrian48
    Had a guy once show up in the ER with that same problem. His solution was a rubber band, which solved the leak problem, but lead to a whole nuther rather nasty problem, which we won't go into here, but suffice to say he no longer had a big 9 inch...:eek:
  13. Penicillin will fix that----
  14. THE SPEED ADDICT
    THE SPEED ADDICT
    x3, me to! releaving the pressure stop my leak.
    extra note: if ya pull the yolk and seal, put some silicone sealant on the front of the yolk before pressing it back on. The splines on the shaft and yolk can also leak.
  15. flynbrian48
    flynbrian48
    LOL, not if the last couple of inches falls off!
  16. sixpac
    sixpac
    from Courtenay
    say good night ****
  17. Blades
    Blades
    from Chicago
    An s-10 will solve that problem.
  18. red baron
    red baron
    from o'side
    i knew this was gonna happen! hahaha
  19. Hotrodbuilderny
    Hotrodbuilderny
    I'm with the vent guys. usually I find people bolt there brake hose to the axle tube using a regular bolt instead of the hollow bolt with the hose fitting
  20. humpie
    humpie
    make sure the pinion nut is torqed to spec.(i think 220 ft.lbs.)if not it will leak:eek:
  21. hate to hijack this thread but what the hell happened to that poor diff?
  22. Hotrodbuilderny
    Hotrodbuilderny
    Do not torque the pinion nut to 220 ft lbs of torque pinion should require approximately 24 inch pounds of drag when new, and a slight drag with used bearings ,
    but it's going to be tough to read with the rear ***embled. if you don't know what you are doing you are better off taking it to someone who does.the only time you should torque the pinion down is if they used a spacer instead of a collapsable sleeve but even then it is done to a preload
  23. big creep
    big creep
    hahahahahahaha!
  24. vintagehotrods
    vintagehotrods
    Nine inch rears have a crush sleeve that determines your ring and pinion set-up so when you remove the yoke to replace the seal you don't want to tighten the pinion nut any more than it was originally installed. I would use a beam type or clicker torque wrench to determine the present torque setting before removing the nut and when replacing it tighten it the same amount or just slightly more. As has been said before remove the seal, check the the yoke for a groove, clean the area and replace the seal with a small amount of grease in the seal lips. Use a thin film of silicone on the outside of the seal before driving it in and again in the splines and threads of the pinion before installing the yoke. Tighten the nut to the same or slightly more torque than before. If you don't have a torque wrench you can also use a punch or chisel to put a mark on the the nut and the end of the pinion so you can line them up when you tighten the nut (I've used this method on a rear end that I have 50K miles on).
  25. nutajunka
    nutajunka
    I had one leaking one time and tryed clearing the vent and all it did was run everyone out of the room...Mmmmm, maybe the wrong brand of pork-n-beans?
  26. GTS225
    GTS225
    Check the tires..........off-road 4X4 stuff. I'd have to guess he dropped the nose onto a rock and started the fracture, then torqued it up a batch to finish the job.
    Roger
  27. RichG
    RichG
    dropped on a rock? You'd have to SLAM it on a rock...that's some wild carnage right there! I've seen the axles twist off in one that had a locker-both axles! This is ********!
  28. 55chieftain
    55chieftain
    If your doing a pinion seal get the "Benda" neoprene pinion seal. Named after the Ford engineer that designed it, Ford motorsports, summit or jegs has them. And pack the backside of the seal with vasaline to keep the spring from coming out when it's installed.
  29. shortbed65
    shortbed65
    from ne Ill
  30. Hotrodbuilderny
    Hotrodbuilderny
    Before you fry your bearings go to Richmond gears site and read how to install
    gears, there is no magic ft lbs number, every crush collar acts differently if you had an 8 3/4 0r dana type rear that uses a shim you could tighten to a ft lb measurement, but 9 inch rears use a collapsable sleeve and once you go to far you throw it out and start over
