Projects My Apache...
Discussion in 'The Hokey Ass Message Board' started by Shane Spencer, Sep 15, 2012.
  1. Shane Spencer
    Shane Spencer
    honestly the only thing that worries me is the seat. the kick and the headliner insert seem fairly simple and will be done with the same color tuck n roll, or pleat, idk what the proper term is. i MAY do door panels on the lower half of the door but im still not sure. ill probably just leave the steel door. also what kind of sewing machine is used ? is there a decent unit i can buy that wont break the bank ?
  2. Shane Spencer
    Shane Spencer
    my vin was below the blue tag idk if thats normal or not ? it just fell off at some point. either way the old cab is long gone so ill need to do a vin tag at some point
  3. chaddilac
    chaddilac
    What are you running for a drive shaft? One piece or a two piece... We've got a two piece and I'm trying to figure out how to make the mount for the center yoke. I don't know how much strength it needs, I figure it's just holding it solid so it doesn't need a whole lot of reenforcement? Am I correct?
  4. Shane Spencer
    Shane Spencer
    im runnin a one piece. im not sure how much strength they really need. you may be better off having a one piece made and byp***ing the center mount situation. especially if the shaft is old or possibly out of balance or needs ujoints. money involved in making a mount and new components for the shaft may equal a new one piece. local driveshaft guy here can make a one piece or shorten/lengthen any shaft with all new joints for around $80 balanced and good as new
  5. chaddilac
    chaddilac
    Wow! I had no idea they were that inexpensive? We pulled the motor from a 81 chevy long bed and I wanted to keep the driveshaft from it cause we already had it and didn't need to buy another. So I was just going to shorten the second section of it and use it. I believe the u-joints are good. Hmmm... Might have to drop by the driveshaft guy and get a price now! thanks GG!!
  6. 1959apache
    1959apache
    Try to avoid a huge driveshaft shop, they have a waaay higher shop rate and they take waay too long. I go to the junk yard and find the ends I need, the right shaft size bring it to my guy down the street and he does everything for $40.00, including stripping down everything and putting some black enamel paint on it and does it right in front of me (usually 30 minutes to an hour).
  7. 1959apache
    1959apache
    It is normal, that is how mine is set up and wasn't touched since I took them off. Have you checked the parts places yet to see if they sell the blank tags? I swore that they did.
    But I have been wrong in the past (deluxe door trim lmao)
  8. six pack to go
    six pack to go
    from new jersey
    Getting insurance money and I might have it sold as-is by the end of the week.. still ****s man, the car was solid!
  9. 1959apache
    1959apache
    That appears to be a pleat. You need a machine that can sew through foam up to one inch. Search on the hamb for decent machines. Also there are tricks to gluing this stuff and different brands of glue.
  10. Shane Spencer
    Shane Spencer
    that was a *****in ride man, ****s the tree got er that bad !!!
  11. Shane Spencer
    Shane Spencer
    i had the shop i go to make a custom front and rear shaft for a 97 ***mins i had. he used some pretty beefy **** to support all the torque that thing was pushing out. i think for EVERYTHING brand new including slip yoke he charged me like 260 for both shafts. and they were monsterously strong, turn around time was a day. i think he quoted me $70 or $75 to redo the one for my apache. and that was with the cost of a new end to accept the proper u joint for the 9 inch. its really not as expensive as youd think if you find a good shop
  12. Shane Spencer
    Shane Spencer
    ill have to get in touch with you on that as well as the welding tips. ill get ahold of you one of these days ! haha i wont be starting on the patch panels for another few weeks. holidays are about to empty my wallet something fierce !!!! :eek::D
  13. 1959apache
    1959apache
    Yeah it will empty your wallet pretty damn quick, but my wife went out of her way to order some parts for the truck for Christmas :D even though we really don't have the extra scratch for it. I have the hookup for 10% off too if you order through cl***icparts.com (Parts America) and actually have some lower door hinge pocket patch panels for you if you need/want them, they would be very discounted of course, maybe we can do some horse trading.
    Yeah, weren't you supposed to call me early this week?... liar!
  14. Buzznut
    Buzznut
    Yeah, one piece is the way to go with these trucks. I had my existing driveshaft shortened 1.25 inches (the posi 10" has a longer pinion ***embly than the 12 bolt I had before). I also needed a new slip yoke for the M22 and replaced the pinion u-joint as well. $110 into the whole thing including balancing....not a bad price.
  15. Shane Spencer
    Shane Spencer
    Yeah my family is hooking me up with a lot of small stuff for the truck for christmas. The nickel and dime type ****, idk exactly what but i keep seeing small boxes of parts at yhe door
    Sent from my DROID device using the TJJ mobile app
  16. shadams
    shadams
    Hmm, well mine was about $335. Complete shaft thought with ****er super duty joints and new yoke. They had it done and at my door step in 2 days though, so I guess it was worth a little extra. N
    Nice work on the front frame horns, I thought about doing mine but didnt. Maybe later on down the line.
  17. Shane Spencer
    Shane Spencer
    Thanks shadams, also check your local autoplus parts dealer. They sell a brand of ujoint that is same quality as ****er just packaged as an off brand. I cant remember what there called, its a blue and yellow box
  18. Shane Spencer
    Shane Spencer
    Totally off topic but today was kind of all over the place. Family is super excited, got the tree up in the house, and hit the local town xmas parade. Its officially full holiday mode here. On the other end i found out my friend billys father p***ed. We grew up together and just knowing his dad is the same age as mine is kinda surreal. It ****s . And me and my buddy are only 20, just wayyyy to soon for a parent to be p***ing away. He was only 51 i believe....... Idk, just strange. We were almost like brothers when we were younger, and now the dude who was always around at our football games or whatever just isnt there anymore. Send your prayers out to his family......
  19. shadams
    shadams
    Damn that ****s. My Dad had a heart attack at 49....luckily my brother was with him and got him to the hospital pretty quick and no major damage was done but it really make you think. Sorry to hear that...
  20. six pack to go
    six pack to go
    from new jersey
    Sorry to hear Shane, keep yer head up and be there for your buddy... Hes gonna need ya.. I too lost 2 friends this year, 34 and 39 years old... ****s big time!
  21. Buzznut
    Buzznut
    My father p***ed away at 53 years old...9 years ago. Losing someone when they are so young and you still need time with them is one of the hardest things to accept. He will deal with this pain a lot over the next year, and even though it gets easier, that wound never completely heals. Remembering the good times and listening to others tell me stories of how my dad positively affected their l lives helped a lot. Just being there for him and understanding that there will be times that he breaks down without warning is the best thing a good friend can do.
  22. Shane Spencer
    Shane Spencer
    Thanks fellas, hes tough as nails. just a little overwhelmed right now........
  23. Shane Spencer
    Shane Spencer
    Also has anyone got a chance to check the crossmember to cab floor clearance ?
  24. Buzznut
    Buzznut
    It's pouring here...literally flooding everywhere, including about 2 inches of water standing under my truck. As soon as I can get on a creeper and roll under there I will.
  25. Shane Spencer
    Shane Spencer
    Hell, its not that serious lol. Dont drown urself for a measurement man !
  26. Shane Spencer
    Shane Spencer
    Arts and crafts time !!!!! Lmao. Heres my basic notch design. Im gonna pick up steel for this tomorrow hopefully. Also jamco ****ed up my order so im just gonna build a set of lowering blocks. The inner box plates will triangulate out to the outer flange edge on the crossmember like you see in the second pic. I am 2.5 inches above the rear crossmember which will keep me below the bed wood. The front notch may be shorter depending on floor clearance
  27. 1959apache
    1959apache
    Which one is it again, I said I would do it and I can... the rear one right???
  28. chaddilac
    chaddilac
    That'll never hold!! More duck tape!!! :D
  29. Shane Spencer
    Shane Spencer
    The one under the rear of the cab. Like right under the gas tank area
  30. Shane Spencer
    Shane Spencer
    I figured some elmers glue and popsicle sticks would add to the strength, dont hate !!!! Haha :)
