Projects My Apache...
Discussion in 'The Hokey Ass Message Board' started by Shane Spencer, Sep 15, 2012.
  1. Shane Spencer
    Shane Spencer
    thanks sqrlnts. hey guys, does anyone know if the 58/59 gmc grilles are pot metal or stamped steel ?
  2. Shane Spencer
    Shane Spencer
    Didnt have time to get wire today. Started the blocks, for the top spring ****** that sticks up, im gonna drill and tap a hole for a grade 8 bolt. Weld the bolt inside the block and cut the bolt head off leaving the unthreaded part as the spring ******, and then cap off the ends of the block. Heres a pic of driveshaft clearance, the shaft will actually have more clearance than in the pic
    Sent from my DROID device using the TJJ mobile app
  3. Saxman
    Saxman
    They're stamped steel.
  4. Shane Spencer
    Shane Spencer
    Thanks saxman, and i dig your shift knobs
  5. Saxman
    Saxman
  6. Shane Spencer
    Shane Spencer
    Knocked out the blocks. Welded the bolt inside the block and capped off the ends. Cut the bolt head off and cleaned everything up nice. Notches r done as well. This is the final ride height for the *** end. U can see the axle tube almost rides right where the old framerail was. Heres a few shots off the finished *** end
  7. chaddilac
    chaddilac
    Diggin it homie!!!!!
  8. n847
    n847
    Damn...**** looks stout!
  9. six pack to go
    six pack to go
    from new jersey
  10. thatredcaroutside
    thatredcaroutside
    from Decatur,AL
    Here's what I did on my 57. I used the ends of the crossmember where they were riveted in , cleaned them up and welded them to my notched crossmember. Just tapped it in and bolted it up to the sides and flange area.
    I mounted the rear leaf spring brackets on top of the frame and swapped sides. Step notch with 3 seperate boxing plates and a few leafs out and I'll make my lowering blocks/spring perch to final ride height after final mock up. I used stock upper shock mount and I'm using the front shocks they are 2 inches shorter.
  11. Brog
    Brog
    I read this from the beginning good stuff man. I might be close to your age also? Anyways love the *** draggin' stance, mine will be opposite and be s****ing in the front haha.
  12. Shane Spencer
    Shane Spencer
    Thanks fellas, and im 20 y/o brog.....
    I threw a fender and bedside on for a quick look. Have about 4 1/2 inches under the rears of the fenders. Its only a half inch lower than my vw that i drive now and i neverrr s****e so thats cool. Also the rake right now isnt bad at all. I may drop the front an inch or so
  13. tjet
    tjet
    Looks good. I would add some gussets if you got enough room. Prob not needed, but I like to overkill things
  14. shadams
    shadams
    Daaaaammmn dude, looks good. Love the block idea, going to have to steal that one as I want to lower mine a couple more inches and have 1 3/4" springs. Nice job!!
  15. Shane Spencer
    Shane Spencer
    thanks fellas, and tjet i was thinking about it but decided not to. the crossmembers in the back are 1/4 wall box and the notch is strong as **** too. if i bag it in the future i may box the rails and fish plate where the notches meet the framerail. we will see.... the problem with a gusset right there is the bed wood. minus the notch, im gonna be running the stock height bed floor which would hit those gussets
    also, on a side note i have to notch the front bridge bar on the notch. it will have clearance issues on the rear. just barely tho, only about 1/8" is needed
  16. sqrlnts
    sqrlnts
    Good work Green! What are your plans for the bed area, as far as covering the step notch? Keep it up.
  17. Shane Spencer
    Shane Spencer
    The floor will be stock style wood with a bump to cover the notch. My dads a pretty bad*** woodworker so we will figure something out when we get there
  18. n847
    n847
    Are you gonna use a mustang gas tank? Or did I miss that already? My buddy had an apache and the tank cap set low enough that he made a piece of removeable trim at the end of the bed and 12" of the center strip of wood slid right out to access the gas cap. It was pretty slick.
  19. dubie
    dubie
    it would be cool to see an old wooden keg split in half and used as a tub to cover up a C notch
  20. Shane Spencer
    Shane Spencer
    Im keepin the stock in cab tank, and dubie...... That is an awesome idea
  21. Buzznut
    Buzznut
    Hell, anything period correct for that matter would look cool sitting there as a permanent fixture. Stick and old beat up Snap On tool chest or foot locker over the left C-notch, weld it into place and make the lid functional. Find something else for the other side....
  22. Shane Spencer
    Shane Spencer
    I like that idea too, got the bridge bars in the way tho
  23. Buzznut
    Buzznut
    Can you relocate the cross bars down slightly? Maybe put them midway down on the notch (just below the floor level) and then gusset the ends, with the gussets running up toward the top of the notch. I honestly don't think they have to be exactly where you put them to be effective.
  24. Shane Spencer
    Shane Spencer
    Well the rear bar is the upper shock mount. The front i need to notch, or i may cut the middle out and angle it back to the rear bar
  25. Shane Spencer
    Shane Spencer
    And if i moved the bars down the front would hit the 3rd member
  26. Shane Spencer
    Shane Spencer
    so i went to the shop and just sat and looked at the bridge bars..... they just flat arent gonna work. i have a new design in my head that i think will work great. it ****s, i had the notch done by my buddy before i learned how to weld and i didnt really have everything ready to mock up and check for issues at the time. but what are you gonna do....
    how the bridge is now......
    my new design highlighted in white. this will eliminate the front bar from having clearance issues with the 3rd member and also kick the rear bar back about an inch and a half to give it tons of room. this will make the "hump" in the bed floor about an inch and a half longer front to back, but i can live with that....
    heres a pic of how high the notch will interfere with the floor. should only be about 5 inches of a hump in the floor. itll keep the bed very useful
  27. n847
    n847
    Pardon the OT truck but I think you could do something along these lines but with a 50 gallon drum, then line-X it. Or use an old air compressor, or something along those lines.
    Or just let it be what it be! Come up through the floor and dissapear back into it! It is a machine let it look like one...LOL
  28. Shane Spencer
    Shane Spencer
    Its not a bad look at all but my notch is so small and only comes up through the floor like 5 inchez so i think a small hump in the wood floor will look best and also keep the most bed space
  29. chaddilac
    chaddilac
    Do this....
    BTW... that column done yet? :D
  30. chaddilac
    chaddilac
    That tag say... After Meth? :D
