Projects My Apache...
Discussion in 'The Hokey Ass Message Board' started by Shane Spencer, Sep 15, 2012.
  1. Shane Spencer
    Shane Spencer
    Im actually thinking about doing a battery door in the floor like the 47-54 ad trucks, i wont be ablt to crawl under the truck either since its riding low. The area where the battery is would put the door right in front of the bench seat on the p***enger side floor. whats your opinion on the exhaust being close to the battery ? The pipe will have to snake between the battery, trans crossmember and trans. i can rebuild the trans crossmember for more clearance. Hows your exhaust routed?
    Sent from my DROID device using the TJJ mobile app
  2. Shane Spencer
    Shane Spencer
    And thanks man, i tried to make it look cool even though no one will ever see it. Idk. At least ill know its there haha
  3. Buzznut
    Buzznut
    I'm planning on building a heat shield out of sheet metal. I will make it so that it sits about an inch below the tray so that the shield takes the brunt of the heat and then the air that p***es over the top of the shield and under the battery dissipates the heat. I may also make the shield wrap around the front to protect the battery from debris...particularly rocks.
    I'm also installing an x-pipe, so the exhaust won't exactly p*** directly under the battery...it will go under the rear engine / trans bell-housing cross member and straight back about 8 inches then angle at about a 45 toward the underside of the M22 rear output shaft / front driveline yoke and then after the x-pipe it will angle back toward the rear corner of the cab and then straighten back out to be in line with the straight front section (it will never go outside the frame rails). At the cross member just behind the cab I will have a hanger installed and then have the DynoMax mufflers installed right after that. It will then go up and over the rear axle and turn out angled slightly toward the left and right sides of the bed (respectively) and then be salami cut about 8 to 10 inches past the axle. I don't want it visible and I don't want the sides isolated to the left and the right away from each other. I also don't want it pointed down because that will create dust clouds and piss other hot rodders off.
  4. Shane Spencer
    Shane Spencer
    I like the heat shield idea. I can either redo my crossmember if i have to or modify the headers to give me more area to snake the exhaust around. Im just running longtubes for the 81 camaro clip. The way my headers are the exhaust will run more alongside the battery than under it. Id rather have the exhaust sit higher though, the truck will be really low when its all said and done. Wanna trade muncies ? Hahha :)
  5. Buzznut
    Buzznut
    M22's are great, but the close ratio aspect is a bear on long hauls. I have an M21 wide ratio also and wouldn't think twice about running that one as well. Sure the M22 is the supposed holy grail, but I think any M20, M21 or M22 is worth having and using.
  6. Shane Spencer
    Shane Spencer
    I thought the only wide ratios were m20's ? Unless you put an m20 gear set in a 21? But yeah i agree any muncie is a pretty killer trans. 22 has the cool straight cut gear whine lol
  7. Shane Spencer
    Shane Spencer
    Finished the battery tray itself, just gotta do the tiedown now......
  8. 1959apache
    1959apache
    looks damn good, nice fab skills. Do you have some pictures of the truck recently?
  9. Shane Spencer
    Shane Spencer
    Thanks dude. Its just the rolling ch***is right now. With the motor in it, still gotta mock in the muncie
  10. ChefMike
    ChefMike
    very nice work !
  11. Buzznut
    Buzznut
    I'm remembering wrong...apparently I'm not getting any younger. It's an M21, that's all I care about.
  12. Shane Spencer
    Shane Spencer
    Heres the completed battery tray and tiedown. Ill put some sort of lock washer on as well. I cut heads off two bolts and welded the studs to the tray. I just need to mount it to the framerail....
  13. Shane Spencer
    Shane Spencer
    Speaking of muncies, whats the bolt/thread aize on the 4 bolts to the bellhousing ?
  14. Buzznut
    Buzznut
    I know I used a 3/4 wrench and socket on them, I'm not sure if they're 9/16 or 5/8... I replaced them with new grade 8 bolts, so I'll look for my old ones and get back to you.
  15. Shane Spencer
    Shane Spencer
    there 1/2 i believe. i got new grade 8's and the 1/2 looks good just the thread size is off. i read online 1/2 13 x 1.75" long
  16. Buzznut
    Buzznut
    Sounds right. The stock cast bellhousing has threaded holes on the top, but the bottom holes aren't. You'll have to nut them on the back (inside the bellhousing) with a lock washer. In order to do that you have to take a normal 3/4 socket and grind it down quite a bit to be able to fit it over the nut. I've talked to other guys and they've had to do the same...
  17. Shane Spencer
    Shane Spencer
    all 4 of mine are threaded.... i believe mines a 55 p*** car bellhousing. at least thats what it was sold to me as:rolleyes::D
    also i may take the battery tray, flip it on to the outside of the framerail and run the 47-54 battery door in the floor. having battery cables and spark right next to the fuel line just sketch me out for some reason, even though i doubt anything would go wrong. this will also solve my exhaust clearance issues
  18. Buzznut
    Buzznut
    A door would work better in that location anyhow...if you cut a hole in the floor that close to the trans cover you'd probably lose a lot of floor integrity.
  19. Shane Spencer
    Shane Spencer
    Yeah when i mentioned putting the door in the floor earlier i forgot to mention flipping the box to the outer rail. That would be pretty weak in the trans area
  20. 1959apache
    1959apache
    You should have a decent amount of room on the frame rail. Why do you want to cut the floor up? I agree that wherever you cut it you are going to really weaken the floor.
  21. shadams
    shadams
    I bought a drop out/down battery box for mine, seems like that would be easier than cutting the floor.
  22. Shane Spencer
    Shane Spencer
    Itll just be easoer access to the battery, instead of wrestling with it through the transmission hole, one door and the battery is right there, and easily up and out. It cant be that weak if the ad trucks came stock like that for 7 years. Itll be on the p***enger floorboard between the front cab mount and the raised seat rail that runs across the floor
  23. Shane Spencer
    Shane Spencer
    Im not sure if ill have clearance for a drop down box to work, id have to measure. Also i have to cut the floor anyway for a patch panel so i figured why not do it while im at it
    Heres a few pics of a 55 with the door in the floor...
  24. Buzznut
    Buzznut
    Looks clean and makes sense...I like it. It's food for thought and I may go that route if my current set-up proves to be a PITA.
  25. Shane Spencer
    Shane Spencer
    Yeah man it really looks pretty simple and alot easier to get the battery up and out if need be.....
  26. chaddilac
    chaddilac
    Dig that batter box... what's the door off of?
  27. Shane Spencer
    Shane Spencer
    So before i decided to run the gmc dash i had planned on keeping the stock chevy dash, and grafting in the center dash grille and clock from a 51 chevy car. Now that im not running the chevy dash and he gmc profile is different i cant run the grille but i may still run the clock bezel on top. The dash will be gloss black and all the knobs, ashtray, and other misc items will be chrome. I think the chromed clock housing would look sick on a black dash. Herez a pic of the chevy car dash center section i planned to use, a quick look at the clock on the jimmy dash, and the battery box on the outer frame. It sits on the camaro clip very nicely, almost like it was made for it lol
  28. dubie
    dubie
    that battery box fits without hitting the step inside the cab? Nice looking work going on there
  29. Shane Spencer
    Shane Spencer
    Yea its about 1/4 inch clearance, this is also another reason i like it. The front cab mount, frame rail, and cab step create a " housing " that kinda protects the battery. Plus its away from exhaust heat and all
  30. dubie
    dubie
    oh yeah, that would be the perfect spot to keep it away from exhaust heat. Looks like a great location. I'm keeping mine on the firewall on the 56 but the wifes 58 GMC will be a relocated battery box
