Projects My AV8 flathead build.. blown...
Discussion in 'Traditional Hot Rods' started by hotrodderhaag, Jan 28, 2013.
  1. Rust n' Chrome 99
    Rust n' Chrome 99
    well, friday night cruise nights start soon I believe, they are like every friday night and they block off like 3-4 city blocks and you park right downtown. its alright, I always get there mad late and miss most the stuff. But now since my schedule has changed I could make it up there sooner. Might hit up a few of them this year. I'll ask my friend that lives there what the scoop is.
  2. hotrodderhaag
    hotrodderhaag
    Received a call saying all my throttle linkage , and the stromberg overhaul kits are all on back order till end of June! Now WTF am I gonna do. No one has em on stock that are genuine stromberg parts
  3. daddio211
    daddio211
    Get in touch with UncleMax here on the HAMB. His website is www.97-express.com.
    Sent from atop my toilet using the TJJ app for Android.
  4. uncle max
    uncle max
    Daddio... Cruising with the Tidy Bowl Man again, eh?
  5. daddio211
    daddio211
    C'mon Max, you can't tell me you haven't done some porcelain piloting in between building carbs! Just promise me you washed your hands before building mine!
  6. hotrodderhaag
    hotrodderhaag
    Max I emailed you
  7. hotrodderhaag
    hotrodderhaag
  8. Carter
    Carter
    What, no clutch dumping, sod throwing, full throttle runs across the lawn?:D
    Good job, buddy.
    Sent from my DROID device using the TJJ mobile app
  9. hotrodderhaag
    hotrodderhaag
  10. hotrodderhaag
    hotrodderhaag
    A hahahahaha. If it had brakes , itd be like Saturday night a mercer raceway :)
  11. daddio211
    daddio211
    GET IT SIDEWAYS!!!!!
  12. Rust n' Chrome 99
    Rust n' Chrome 99
    gotta love the test drives with no brakes, been there done that. congrats
  13. hotrodderhaag
    hotrodderhaag
    Yea I just couldn't resist.. Had to take it out for a spin.. Ordered some more parts today so hopefully in a week or so il be on blacktop..... More than just what's in my driveway
  14. Hotrodmyk
    Hotrodmyk
  15. brian55lvr
    brian55lvr
    from ma
  16. woodbutcher
    woodbutcher
    :D Hi HRH.Looking good.
    Good luck.Have fun.Be safe.
    Leo
  17. sidevalve8ba
    sidevalve8ba
    That's a super exciting moment when you get to move it under it's own power for the first time. You'll never forget it. :D
  18. roseville carl
    roseville carl
    Congrats she looks and sounds great!!!
    keep on keepin on
  19. hotrodderhaag
    hotrodderhaag
    Thanks alot guys. I had to take a few days off from working on it. I was starting to get in a rush and nothing gets done correctly when your rushing. We're having a big family cook out July 4th and I wanna drive it there. That's usually what the whole family does is drive there old cars.. So it's a nice day with about 20 or so cars there . One good solid weekend once my parts come in and ill have it road worthy, as long as the motor runs good after I rebuild the 97's .
  20. brian55lvr
    brian55lvr
    from ma
    nice!:)
  21. looks awesome, congrats on such a sweet set up....
  22. hotrodderhaag
    hotrodderhaag
    I want to thank uncle max for the carb kits. I got both carbs completely overhauled. I replaced the emulsion tubes and that was alot of the issues. They were plugged solid. The car runs sooooo perfect now and doesn't get hot. The timing Is perfect and it fired right up like It never has. I'm so happy with it. I got the car wired today including mounting the factory battery box. Which the box worked out perfect cause it fits just like factory just on the p*** side . Perfect. All I need is a master cylinder and some throttle linkage and we are road test ready !!!
  23. hotrodderhaag
    hotrodderhaag
  24. hotrodderhaag
    hotrodderhaag
    The #6 screws to remove emulsion tubes. I had to hunt high and low for these things [​IMG]
  25. pinkynoegg
    pinkynoegg
    man that thing looks, and sounds, awesome!
  26. hotrodderhaag
    hotrodderhaag
    I used muriatic acid to clean the carbs after they were all dis***embled. It worked so so well. I used a cup of acid to two gallons of water and all the parts came out shiney new !
  27. hotrodderhaag
    hotrodderhaag
    I wired the car yesterday. I found I had the original batter cables from the 36 ford this engine was pulled from.. They were like new. They are 10 strands of heavy copper wire. After shortening them , soldering on new heavy duty ends. The car cranks over like 12 volt. I'm really happy with that
  28. Saxon
    Saxon
    from MN
    Just needed some tlc then. Nice work!
    Carbs look great and it's idling a lot better now. I run a max97 carb on my 38' and it runs excellent and doesn't leak. It can sit for weeks and will fire right up. Not always my luck when it comes to carburetors for some reason.
    Man it is coming together!
  29. Rust n' Chrome 99
    Rust n' Chrome 99
    looks and sounds sweet, congrats.
  30. travj31
    travj31
    from Western PA
    great job... love it
