Projects My beater '57 Chevy
Discussion in 'The Hokey Ass Message Board' started by choppachris, Jul 24, 2013.
  1. choppachris
    choppachris
    I give up, what is E/mp?
  2. shemp
    shemp
    Alliance Vendor
    Looks Boss with the Keystones.
  3. 65PANELRAT
    65PANELRAT
    Nice score! Congrats!
  4. choppachris
    choppachris
    Ah, racing cl***, non-factory equipment.. Took me a little while. 8)
  5. FritzJr
    FritzJr
    "I give up, what is E/mp?"
    NHRA cl*** from the mid-sixties. Cl*** "E" modified production. A 57 with a hotted up 283 would run that cl***.
  6. CDJerger
    CDJerger
  7. dynaflash
    dynaflash
    from South
    Better try the 2" dropped spindles first. Then cut springs if you need more. But 2" drop is probably all you will need. Mine has 2" dropped spindles and I have to be carefull of parking against curbs and speed bumps already. Would not want it any lower
  8. I've ran dropped spindles, an one cut coil on my daily, for 15yrs now.
  9. lewk
    lewk
    from Mt
    That looks like a great car to start with. The keystones are cool too. I like post cars with lower trim levels. Your 210 will look good. I'd love to turn up a 150 some time.
  10. EastSidePoncho
    EastSidePoncho
    beater?! For a beater it sure is nice.. Can't wait to see what you do with it!!
  11. 57 HEAP
    57 HEAP
    2X.
    I have 2 inch drops now and have hit a few curbs, not good. Also your exhaust will hit speed bumps if you aren't careful. The exhaust is lowest where it p***es under the ****** bellhousing frame horns.
  12. dynaflash
    dynaflash
    from South
    Yes I am working to get my exhaust up a little. I have a 68 style bell housing and Patriot headers so I am hopeful the I can pull the piles up a little. Mine are about 6" off the ground. Also with the 2" dropped spindles you have to be careful when turning into a driveway. When the tire is turned and you hit the bump it will make the tire rub the fender. Looks super cool but there is a price to pay. And again I have stock springs. No cut coils
  13. dynaflash
    dynaflash
    from South
    Pipes up not "piles"
    Sorry about that.
  14. choppachris
    choppachris
    I'll try the spindles first before I cut a coil then. I also have 225/70r14's in the front now, but want to go with 205s.
  15. choppachris
    choppachris
    Mine look just like yours. This is my setup, only difference is my spindles have 4 holes in the square flat backing area, one in each corner. Nothing in the top holes, however.
  16. choppachris
    choppachris
    So i'm cleaning and lubing my caliper, decided i'd paint the caliper and the painted part of the Keystone wheel, when I notice for the first time that I have two 15"s and two 14"s. Ha! I didn't notice before cause it has both 14"s on the left side, and both 15"s on the right. All four tires are different sizes, so I didn't look close, just figured i'd buy a new set.
  17. tjet
    tjet
  18. Deuces
    Deuces
    Screw that ****!!... I'd add some leaf springs on it with a straight front axle.. :D
  19. 51 Leadsled
    51 Leadsled
    from NC
    Nice ride!!
  20. NINE INCH
    NINE INCH
    Well then...Welcome to the Beater 57 Family. There's alot of us here.
  21. t-buckethead
    t-buckethead
    from texas
    Nothing wrong with a beater,got one too...
  22. alanwoodieman
    alanwoodieman
    Damn guys!! knew I shouldn't have looked on the hamb tonight, now I got to tell the wife I want another car!! I have had over a dozen 57's all but one of them 2 door post and I want one AGAIN
  23. 57 HEAP
    57 HEAP
    Up state where? My Pop was from Simpsonville, his sister is in Greenville, the only cousin is in NC.
  24. chevy54man
    chevy54man
    from NC
    Congrats on getting your dream car! Have a blast with her!
  25. choppachris
    choppachris
    Got a new bench seat style shifter stick for my Hurst shifter and adjusted the linkage today. Finally pulled it out of the garage and took it around the block for the first time, and man is this thing bad***!!! It easily lights up both rear tires from a roll in 1st and 2nd, and pulls real hard throughout the others! I looove this car. I have alot of slack in the steering wheel tho, and it is hard to turn left, but easy to the right.. All ball joints, tie rod ends look and feel great, no slack there.. Guess it's time to save up for a new manual steering box.
  26. original spindles are tapered, bearings are somewhat expensive- least they are for my 55... best to replace them with new ones when doing the disc swap, then you can just order them dropped anyhow... cl***ic chevy club (back when they were good) did a couple tech tips on swapping brakes with mid 70's GMs check their online site and see if you can find the article if you are looking to do it on the cheaper side
  27. dan31
    dan31
    black widow material;)
  28. tbm1949
    tbm1949
    the guy probably swapped out the wheels before putting the car up for sale.
  29. Hdonlybob
    Hdonlybob
    Good for you !!
    Looks good and solid too !
